Anyone Install SRT 8 Brembo Brakes on a Daytona? - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 6 Old 05-16-2007, 10:47 PM Thread Starter
Dtona 0420
Junior Member
Send a message via AIM to Dtona 0420 Send a message via MSN to Dtona 0420 Send a message via Yahoo to Dtona 0420
(Thread Starter)
Cool Anyone Install SRT 8 Brembo Brakes on a Daytona?
Has anyone installed the Brembos from a SRT 8 on a Daytona? If so, any issues to deal with? I noticed the Brembo kits list a non SRT kit and a SRT kit..whats the difference in them?
Will the Daytona 18" wheels fit with the Brembos installed ?? or is it time to spend some more bucks??
TC
Dtona 0420, the mod bug has bitten hard since I got this thing....
Dtona 0420 is offline
post #2 of 6 Old 05-16-2007, 10:49 PM
Ruff n Tuff RT
Banned User
Ruff n Tuff RT's Avatar
if this is possible im gonna have to do it
Ruff n Tuff RT is offline
post #3 of 6 Old 05-16-2007, 11:39 PM
spenosk8er
Senior Member
spenosk8er's Avatar
Send a message via AIM to spenosk8er
You might have to get a bigger rim, im not sure if they will fit... not sure though.... from what I remember the brake stuff on the SRT's is completely different than all the other models, so a lot needs changing out
mod list...
spenosk8er is offline
post #4 of 6 Old 05-17-2007, 02:10 AM
Junior
Senior Member
Junior's Avatar
Yeah, my Dad (Meister) did this on his 300C - Brembos off an SRT - I can check with him for specifics, but it was much more than just the brakes. You'll need a fair bit of front-end parts; spindles, etc, IIRC. Also need new wheels. His are 18s - Borbet wheels - but they're the only 18's I've ever heard of that will clear the big Brembos.
You can PM him here or on LXforums, or post here (he's right next door... ) I'll try to relay for you, if it helps.
Another option is the big brake kits from Wilwood, or aftermarket Brembos - they'll bolt on without replacing any other front end components, but I think you still need to do wheels...
HTH
- Click above for my Hemi Registry page -
Junior is offline
post #5 of 6 Old 05-17-2007, 03:02 AM
jasonface
Senior Member
jasonface's Avatar
I'm in the middle of this exact brake swap (I have a Charger RT with R+T) . Doing the Hotchkiss sways and KW V1's at the same time. Finished the front left today, should have the front right and rears done by Friday. The SRT8 brake swap requires the front spindles and rear "knuckles" off of an SRT8 to replace your standard components. The Brembo calipers from the SRT8 mount differently than the stock RT and Daytona items, so that's why you have to change the suspension components too. The SRT8 Brembos will not fit under a 18" Daytona wheel (at least on the fronts, the rears are somewhat smaller, so they might fit, don't know for sure). If Brembo lists a kit for the Charger RT and Daytona, my guess is the calipers are smaller and the rotor is kept to the stock RT sizing to allow this to fit. The SRT8 rotors are only appx .5" larger, but the calipers are much larger than the stock calipers on the RT or Daytona. The biggest thing so far in this swap that F'd with me was getting the ball joints loose. There is a rubber grease boot in between the control arm and spindle, as well as between the tie rod and spindle. You can't just drive a pickle fork in there to pop the ball joints, you'll tear up the rubber boot. I finally figured out that a small two-finger pulley puller would grab the spindle, while tightening the puller you can then tap on the joint with a hammer and they will pop loose.
jasonface is offline
post #6 of 6 Old 05-18-2007, 12:27 PM
Feros
Senior Member
Feros's Avatar
Quote:
great info. keep us informed on this.
"The Beast"YELLOW the fastest color "TRADED for 14 Challenger"
Top Banana #2448 NC TAG "1M FASTR"
315.7 RWHP 322.8 RWT
Wifes
TRADED 06 Dodge Charger SE VA TAG "GEEK GRL" Beauty mods See
Feros is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Brembo brakes: Fact or Fiction? Fishkzor Wheels/Tires/Brakes/Suspension 81 08-30-2008 02:57 PM
Are These The Brakes From An SRT? KevinRoss General Charger Discussion 44 01-02-2007 06:28 PM
All Chargers have Brembo brakes??? Fishkzor Wheels/Tires/Brakes/Suspension 12 10-19-2006 11:01 AM
SRT-8 Brakes daytonaR/T Performance Discussion/Modifications 5 09-15-2006 05:53 PM
SRT-8 Brembo setup for sale on ebay Fast56k Charger SRT-8 Discussion 4 07-24-2006 01:50 PM
You may post new threads
You may post replies
