Removing the rear seat - Dodge Charger Forums
V6 Specific Discussion This area is for discussion about V6 powered Dodge Chargers.
post #1 of 16 Old 04-22-2007, 11:16 AM Thread Starter
phillyphill39
Member
Send a message via Yahoo to phillyphill39
(Thread Starter)
I have a 06 charger se, and i need to know to remove the backseat so that i can get to the rear speakers so install new ones. I have already taken the seat cushion off, i just cant get the back part off. Does anyone know how to do that. The service manual doesn't tell you how to take it out.
Thank you
phillyphill39 is offline
post #2 of 16 Old 04-22-2007, 11:23 AM
J Weezy
Banned User
J Weezy's Avatar
the back should be to hard to get off, have you take out all 6 bolts?
-Justin
J Weezy is offline
post #3 of 16 Old 04-22-2007, 11:26 AM Thread Starter
phillyphill39
Member
(Thread Starter)
where are the other bolts. i took off the 2 at the bottom and i can lift it up but it seems to still be attached in each corner by something. and ive looked everywhere and still cant find anything
post #4 of 16 Old 04-22-2007, 11:32 AM
Knarley
Supporting Member (Lifetime)
Knarley's Avatar
Send a message via Yahoo to Knarley
Move your front seats all the way forward. Get in the back. One side at a time, drive one of your knees into the front of the seat at the center of where someone would sit. Push as hard as you can toward the trunk. Put both your hands in the crack behind one of the seats, and pull up toward you with very steady, firm pressure at a 45 Degree angle. You will hear a pop when it releases. Move over to the other side and do the same thing. There are two u-shaped wires (about 1 1/2") that go into a slots on ether side at the front. The seat is nothing more than a big pad that is cliped into place. Hope this helps out.
Knarley is offline
post #5 of 16 Old 04-22-2007, 11:34 AM Thread Starter
phillyphill39
Member
(Thread Starter)
aight if it works thank you if not then thank you
post #6 of 16 Old 04-22-2007, 11:40 AM
The Tran
Senior Member
The Tran's Avatar
i stuck my hand at each corner and felt for the clip. then i took a long flat tip screwdriver and pushed down on the clip while pulling on the seat. then pull up and out.
The Tran is offline
post #7 of 16 Old 04-22-2007, 11:47 AM Thread Starter
phillyphill39
Member
(Thread Starter)
argh im still having trouble with this. why couldnt they just put fold down seats in all of the cars.
post #8 of 16 Old 04-22-2007, 12:06 PM
The Tran
Senior Member
The Tran's Avatar
the clips are in the far corners. like at 9 and 3 o clock. pull the corners forward and stick you hand down and feel for a metal clip piece. once found push down with a large flat head.
The Tran is offline
post #9 of 16 Old 04-28-2007, 06:04 PM
BT1024
Senior Member
BT1024's Avatar
Quote:
"Seat Removal":
Here's the details, see the attached picture and refer to these steps:
Step #1: On each corner of the rear lower seat, pull up hard, until you hear it pop out of the car floor (it has metal loops that "plug" into the floor) - then remove the lower seat so that you can get to the "nuts" in step #2.
Step #2: loosen the "nuts" on Bolt #1 and Bolt #2 enough so that the seat can be tilted forward when you push down the Metal spring clips in Step #3.
Step #3: Push down Spring clip # 1, by sliding a long flat-head screw driver between the rear upper seat and the trunk wall (it takes some Trial and error), until you feel the metal spring clip go down - then tilt/pull that part of the seat forward - insert something between the trunk wall and the upper rear seat, to keep it from popping back in. Then do the same for Spring Clip #2.
Step #4: Then, once you are sure that the spring clips are dis-enganged, lift the upper rear seat (part) up, out and then tilt down. You can't go to far with it because of the attached seat belt straps.
.... And that is it
BT
BT1024 is offline
post #10 of 16 Old 04-29-2007, 05:01 AM
BIGGCharger
Senior Member
BIGGCharger's Avatar
need to mark this for future use, thanks guys
1st Supercharged V6 Charger
BIGGCharger is offline
  Dodge Charger Forums > Dodge Charger Discussion > V6 Specific Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
How to remove the rear seat? FLBEARCUB Interior Discussion/Modifications 4 07-12-2014 01:26 PM
Removing Leather Seat Upholstry Darko1912 Interior Discussion/Modifications 2 06-19-2008 01:38 PM
Ipod and rear seat DVD 1BadBanana Interior Discussion/Modifications 7 09-07-2007 02:29 PM
Rear Seat Brackets. The Tran Interior Discussion/Modifications 8 04-21-2007 04:12 PM
My new rear seat video system... GoingHemi Interior Discussion/Modifications 11 02-25-2006 01:18 PM
You may post new threads
You may post replies
