Gasoline Smell? (Moved) - Dodge Charger Forums
post #1 of 17 Old 04-16-2007, 03:21 AM Thread Starter
PastorC
Senior Member
PastorC's Avatar
(Thread Starter)
Wondered if anybody else has had this problem? Every once in a while I get a strong smell of gasoline, not consistant just random. Plus I'm getting around 10 mpg in the city, Ive got a lead foot sometimes, but not bad enough to warrant this kind of MPG! I took my car into the service dept, the mgr said that they couldnt find anything by hooking up the comps and that for them to look further that they would have to smell the gas fumes themselves. Told me to bring it straight to the service dept next time I smelled the fumes. But of course it only happens when Im on the other side of town and by the time I get to the dealership the fumes have ceased to be. I didnt get this bad of gas milage when I first got the car, the fumes started showing up around 4000 miles and the mpg has gotten worse the more miles I rack up. Ive got about 7000 miles on her now.
Any help anybody?
Thanks,
PastorC
06 Inferno Red RT: Predator/180 Tstat/Zoomers/K&N CAI/Hancook Ventrus 275/40/R20 with Platium Twin Twist Rims/Rear SRT Style Spoiler/20% Tint/Rear Rockblockers/Trenz & T-Rex Grills/JDM Projector Halo Headlights/Billet Pedals/Custom Embroidered Mats/Red LED Interior Lights
"Pray Hard, Drive Fast"
PastorC is offline
post #2 of 17 Old 04-16-2007, 05:22 AM
Banana2302
Member
Banana2302's Avatar
I am in the boat. service says 'bring it in as soon as it happens'. Well after about 20 minutes, the smell is gone. Someone said they had a bad O2 sensor go, and I asked about that, but the service guys said it would show up on the diagnostics; which they said they did, but nothing showed. I also noticed under the engine cover what looked like water spots around the right side fuel rail. Specifically arourd a part that looked like a fule pressure regulator, but I don't know, perhaps it leaks or bleeds off on occasion? It hasn't happened for a while, but the last time was when I nailed it for about 5 secs then let off quickly.
Banana2302 is offline
post #3 of 17 Old 04-16-2007, 07:25 AM
ducvw2004
Senior Member
ducvw2004's Avatar
Quote:
Not to change the subject, but where did you get the cool shaker hood?
"If you choose not to decide you still have made a choice"
Proud member of the
. Come on down and join us!
ducvw2004 is offline
post #4 of 17 Old 05-03-2009, 10:36 PM
Manannan
Junior Member
I developed the same problem last Summer driving down from the Rockies. I heard a pop towards the back end and smelled fumes intermittently for the rest of the drive to CA. It turned out to be a cracked fuel tank (!) which was not covered by warranty as the dealer considered it must have been caused by an accident.
Manannan is offline
post #5 of 17 Old 12-30-2010, 11:21 AM
Mikecrad
Junior Member
Mikecrad's Avatar
Have had the same problem as you guys with the raw gas smell, as well as the smell dissipating by the time they get it up on the lift at the dealer. Even though it is a very intermittent problem, I usually notice it more after I have had to brake hard to come to a stop when I have a full or near full tank of gas. I couldn't find any visible leaks prior to taking it to the dealer. After talking to several people, one advised that there is a large round disc or plug, for lack of a better description (I don't know the technical name for the part), through which the fuel line and other things go into the gas tank from the top, and that there is an O ring around it that may have gone bad. This seems to make sense. Sudden braking on a full tank of gas could cause gas to leak pass the O ring and onto the top of the tank. At my earliest opportunity, I'm going to do several hard brakes and try and get the car in the garage and up on jack stands to see if I can feel anything wet on top of the gas tank before the gas evaporates and the odor dissipates. Since some of the posts on this problem are a little dated, I was wondering if any of you got the problem resolved on your cars and it turned out to be what I am referring to.
Mikecrad is offline
post #6 of 17 Old 12-30-2010, 01:24 PM
Requiem478
Senior Member
I've noticed the smell occasionally, but I really just think its because of the aftermarket exhaust. Since I bought the car used I can't vouch for the quality of the installers work. But I mean with 5" tips (borla) and no cats what else could it be? I thought that bad 02 sensors just decreased gas mileage (could be wrong). If its something else let me know so I can get it fixed when I take my car in for service.
Requiem478 is offline
post #7 of 17 Old 12-30-2010, 01:31 PM
R/T Beast
Senior Member
Quote:
Quote:
Originally Posted by GLHS837 View Post
Why? This is not normally a thing that need service. I know when I pulled my Neon SRT-4s tank for the Stage 3 upgrade somewhere over 50K, the sock was dirty, I mean stained, but otherwise perfect. Unless you know for a fact that its clogged, I wouldn't even bother.
Now, heres the good part, if for soem reason you need to. You dont drop the tank at all. Pop up the bottom back seat cushion. See those two flaps in the sound insulation? Flip one up. the fuel tank access is there, you can remove the cover and then remove the pump/regulator/level sensor, filter sock.
Maybe remove the rear seat before you try your test, see if any fuel is sloshed out there.
R/T Beast is offline
post #8 of 17 Old 12-31-2010, 06:18 PM
Mikecrad
Junior Member
Mikecrad's Avatar
Thanks for the advice. I've never had the rear seat or cushions out. Have only pushed the rear seat backs down when I needed to haul something long in the car.
Quote:
Mikecrad is offline
post #9 of 17 Old 12-31-2010, 07:55 PM
R/T Beast
Senior Member
No problem. Figured that would be the most logical thing to do, since your going to see if it's leaking there.
post #10 of 17 Old 01-03-2011, 12:14 PM
Mikecrad
Junior Member
Mikecrad's Avatar
Unhappy
Pulled the back seat out and found the two flaps that you were talking about that allowed access to the fuel tank, but no leaks there. Also found quite a few others posts on this site, under different threads than this one, where several other Charger owners are having the same problem. So far, can't find where anyone has posted a solution that has worked for anyone.
Mikecrad is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Gasoline?? blacksax1 Performance Discussion/Modifications 4 07-25-2006 04:12 PM
MMT in gasoline InferAl General Charger Discussion 3 07-03-2006 12:45 PM
Gasoline Grade? javola Performance Discussion/Modifications 28 05-21-2006 09:51 PM
Ethanol Blended Gasoline whiskey General Charger Discussion 23 05-06-2006 08:08 AM
Gasoline Question Rob_in_Korea Charger SRT-8 Discussion 6 11-09-2005 07:23 AM
You may post new threads
You may post replies
