Help! Check engine light after car got stuck in ice. - Dodge Charger Forums
General Charger Discussion General Discussion about the Dodge Charger.
post #1 of 9 Old 03-19-2007, 03:44 PM Thread Starter
waverip
Member
waverip's Avatar
(Thread Starter)
Help! Check engine light after car got stuck in ice. - UPDATE
Backing my car down my driveway, my brakes locked up and I ended up across the street in my neighbors driveway.
Due to sleet theirs about 4 inches of ice in each driveway. It took 30 minutes of rocking and such things to get out of my neighbors driveway. My car is currently halfway up mine but I now have a check engine light.
Any advice?
waverip is offline
post #2 of 9 Old 03-19-2007, 03:49 PM
Darkstar
Member
Take it to the dealer and let them pull and diagnose the codes.....Louie
Darkstar is offline
post #3 of 9 Old 03-19-2007, 04:09 PM
TripleTransAm
Senior Member
TripleTransAm's Avatar
I'm betting it's a software glitch. Rocking the car back and forth violently might have resulted in a brief situation where the PCM or TCM was misaligned with what the tranny was actually doing (since the tranny is still hydraulically actuated... there's always a certain amount of lag between what the PCM or TCM are ordering and what's actually happening in the tranny).
I'm betting the code will show something like "gear disagreement" or "invalid speed signal" or some other "help, I've lost track of what the heck was going on in the tranny" type of error. Let us know.
/Steve
1987 Pontiac Trans Am GTA
1998 Pontiac Trans Am WS6
1978 Pontiac Trans Am
1978 Pontiac Trans Am 4-speed SE
2006 Daytona R/T Tor-Red (59 of 200 - Canadian)
2016 Dodge Charger R/T R&T
TripleTransAm is offline
post #4 of 9 Old 03-19-2007, 04:30 PM
kawi14ninjaman
Senior Member
kawi14ninjaman's Avatar
I know exactly what this is. I was stuck in the snow a month back, and had a similar thing happen. I took it to the dealer and they said that its hals brake control and that there is a TSB out on it. Take it there and they will have it back to new in an hour or less. All they do is re-flash hal. Thats what they told me anyways.
06 silver steel r/t, 06 ninja zx14
Borla 112 cat-back exhaust. Mopar lowering springs.
60'--- 2.083, 1/8--- 9.046@77.27mph
1/4----14.047@99.65mph
NEW Times! Byron dragway 10/27/07
kawi14ninjaman is offline
post #5 of 9 Old 03-19-2007, 04:43 PM Thread Starter
waverip
Member
waverip's Avatar
(Thread Starter)
Well. The car is still stuck in the middle of my driveway. I'll be taking it in the morning. I have a new dilemma.
The driver sides window is stuck halfway I'm going to assume that I was the primary cause of this. I can recall shutting my door just a tad bit roughly after my 20 minutes of rocking back and fourth.
Man, it's just not my day.
This is why angry people can't have nice things . Window is all covered now, BUT! It just started to hail/sleet again.
YIPPEE!
waverip is offline
post #6 of 9 Old 03-20-2007, 09:59 AM
Zandian
Senior Member
Zandian's Avatar
I had a similar problem and it was two codes. One was something to do with the wheel alignment (can't remember, thought it related to steering wheel alignment sensor.) The second was some sort of transmission warning saying that it had kicked into some protected mode while I was working back and forth trying to get out.
I read and cleared the codes with my Superchips Flashpaq and no problems since.
Zandian
Zandian is offline
post #7 of 9 Old 03-20-2007, 10:09 AM
banannaman
Member
Quote:
happened to me too, this is what they said and had it back in a few hours.
*********2006 Top Bananna 1545/4000*********
banannaman is offline
post #8 of 9 Old 03-20-2007, 10:30 AM
LILGTO
Senior Member
LILGTO's Avatar
Previous stuck in the snow info
Any advice?
Quote:
Originally Posted by LILGTO
Got stuck in the snow trying to get into my drive this evening as we are having a pretty good storm here in Ohio. Started rocking the car back and forth and forgot to turn off the ESP. I then shut the ESP off and rocked some more. Got it unstuck but noticed the OBD engine light is on. Car seems fine though. I think that the car just needs to recycle itself to get the light to go off. Can anyone advise about this OBD light? Will it recycle or do I need to get the dealer involved? Appreciate your thoughts. Thought I read a thread on this one before, but could not locate one.
Here is what went down with the Engine light. The problem code was: P0573 = Cruise Control/Brake Switch A Circuit High. Decided not to pull FUSE 11 just to see what the car would do on its own. Drove the car to work with the light on for 3 days, or 3 driving cycles. During this time frame, the CRUISE could be turned on, but would not set. On the 4th morning when I started the car up, no more engine light! The CRUISE also started to work as normal. Other than CRUISE not working for those 3 days, the car ran great with no additional problems or symptoms. Stupid light!
2006 Dodge Charger Daytona R/T (5.7L - 345 CID) - DOB: 4/27/06 @ 19:00 hrs - $35,010.00
1979 Pontiac Firebird Trans Am (T/A 6.6 - 400 CID) - DOB: 3rd Week of February, 1979 - $8,217.55
1965 Pontiac LeMans Hardtop Coupe w/GTO Option (6.5L - 389 CID) - DOB: 4th Week of February, 1965 - $3,279.98
Tor Red # 0069 - 2000
LILGTO is offline
post #9 of 9 Old 03-20-2007, 11:53 AM
ManGO
Senior Member
ManGO's Avatar
did the same thing, got the same code, lost cruise for 4 days, Forgot to buy a tshirt!
Former owner of GoMango! #2633
ManGO is offline
  Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Check Engine Light - How to Check Codes PikeBoy98 V6 Specific Discussion 27 01-11-2016 09:38 AM
Check Engine light came on?? SXT=3.5L=250hp Charger Problems/Assistance 36 08-26-2007 08:50 PM
check engine light STMhellion505 Performance Discussion/Modifications 1 11-20-2006 07:09 AM
Check Engine Light On torkin Charger SRT-8 Discussion 2 09-27-2006 07:05 PM
check engine light hitman Charger Problems/Assistance 10 03-07-2006 09:01 AM
You may post new threads
You may post replies
