Oil Pressure PSI ? 5.7 hemi - Dodge Charger Forums
post #1 of 12 Old 03-19-2007, 04:07 AM Thread Starter
Mecha
Senior Member
Mecha's Avatar
(Thread Starter)
notced today my Oil Pressure PSI.
warmed up and at idle im at 15-16 psi
at cruise and accelerating im at 45-48 psi
is that the same some of you are getting with your 5.7 hemi?
Mecha is offline
post #2 of 12 Old 03-19-2007, 04:33 AM
PRoBLeMz
Senior Member
PRoBLeMz's Avatar
your in the norms
Dodge Challenger 392 SRT8(Green w/Envy) Mods soon to follow!
All names changed to protect the Innocent
PRoBLeMz is offline
post #3 of 12 Old 03-19-2007, 06:13 AM
arfur
Supporting Member (Lifetime)
arfur's Avatar
Looks good to me...
Don't Hassle the HOFF
Arf - expert in
and
arfur is offline
post #4 of 12 Old 03-19-2007, 06:24 AM
Black R/T R&T
Senior Member
Black R/T R&T's Avatar
That is the range mine was at too. When I switched to Royal purple, 5w20, idle went up to about 21-23, and I have seen 60 under acceleration.
2015 Charger Scat Pack, Bright White
Mods: 275/40/20 Pirelli P Zero's
2013 Charger R/T MAX, Bright White -- Sold
2006 Charger R/T R&T, Black -- Sold
Black R/T R&T is offline
post #5 of 12 Old 03-19-2007, 08:29 AM
HemiChemi
Senior Member
HemiChemi's Avatar
Mine are usually a bit higher, but yours seem OK. I see low 20s at idle and high 50s cruising.
Inferno R/T+R&T, EVIC; 6-disk CD; Sirius; UConnect; Protect Gp; front and rear spoilers, Daytona grille and insert, R/T emblem and hidden trailer hitch.
There are 10 possibilities:
you either understand binary, or you don't.
HemiChemi is offline
post #6 of 12 Old 12-15-2014, 07:09 PM
PAMUNOZ
Junior Member
PAMUNOZ's Avatar
2007 RT here. My oil pressure usually hovers at 55p range regardless on whether I am idle or not. The odd time I see it go down to lower levels but not often. I just turned on my car about 2 mins ago and the oil pressure is 53p, and I am just idling. Hope that's not cause for concern for me.
PAMUNOZ is offline
post #7 of 12 Old 12-15-2014, 08:42 PM
Ddaddy
Ddaddy's Avatar
Garage
This might be a new record...revived a 7-1/2 year old thread!
BTW, your oil pressure is just fine.
Name:	Zombie thread 1.jpg
2006 Charger SRT-8
1969 Dart GTS 340
2012 Chrysler 300C Hemi
All V8 Mopars!
Ddaddy is offline
post #8 of 12 Old 12-15-2014, 09:21 PM
PAMUNOZ
Junior Member
PAMUNOZ's Avatar
LOL I actually google searched the topic... took me right back to this forum/topic! Anyway thanks good to know. Whew.
PAMUNOZ is offline
post #9 of 12 Old 01-18-2015, 07:52 AM
abdul aziz
Junior Member
oil pressure senor
i have 2006 chrysler 300c hemi RWD i live in saudia arabia before 2 days i changed the oil sensor due to code and oil leakage from sensor. on old sensor she was giving me 200-250 kpa after warming the car but after changing the sensor she's is giving me 70-80 kpa. is it normal? on full acceleration she is doing 350-400 kpa. please help me
abdul aziz is offline
post #10 of 12 Old 01-18-2015, 01:33 PM
370 HEMI
Supporting Vendor
370 HEMI's Avatar
Quote:
The rule of thumb here is 10 lbs of oil pressure per 1000 rpm.
Since you are at 200-250 kilopascals we would convert that from kpa to psi
so 200 x .145 = 29 psi to 300 x .145 = 43.5 psi.
80 kpa x .145 = 11.6 psi in idle is still fine.
400 kpa in full acceleration is 400 x .145 = 58 psi.
5,500 rpm x 10 psi per 1000 = 55 so you are fine!
Regards,
Brian
BND Automotive LLC
440-821-9040
www.bndautomotive.com
More Power, More Torque, Better MPGs - It's "Rocket Fuel For Your Car"
Custom Designed & Custom Blended "ALWAYS beats off the shelf brands"
Better cooling, better protection without all "The Gunk"
370 HEMI is online now
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
First Oil Change to Royal Purple - lost oil PSI at idle REB Performance Discussion/Modifications 33 11-01-2010 07:45 AM
Oil Pressure budoinst Charger SRT-8 Discussion 5 08-21-2006 06:30 PM
oil pressure johnrx Charger Problems/Assistance 12 02-21-2006 10:18 PM
The Max Inflatable pressure posted on my R/T is 51 PSI! Butter06 Performance Discussion/Modifications 35 12-02-2005 08:27 PM
Oil Pressure moparfan Charger SRT-8 Discussion 11 10-29-2005 10:43 AM
You may post new threads
You may post replies
