OIl Press and lifter noise - Dodge Charger Forums
post #1 of 20 Old 09-01-2006, 08:42 AM Thread Starter
mtcraigco
Senior Member
(Thread Starter)
OK so my Daytona runs 18-20PSI at Hot Idle, goes to 45+ at operating revs and such. Seems I have a bit off lifter "click" both hot and cold but only at dead idle.
I am thinking about going with a slightly heavier oil (Castrol Syntec 10w-40) but the owners manual says to run 5w-20 or the MDS may not work properly.
I have the 8yr-80k mile warranty and it's a "Certified" car, so if it pukes a lifter, it's dodge's problem, but it bugs me!
I also thought about some Lucas Synthetic additive. I have used it before and think it's a pretty good product.
Does anybody else have a noisy lifter or two? What oil is everybody else running?
Am I just being WAY to anal about the lifter noise?
More iritated than concerned about it, a little feedback please?
2006 Go Man-Go Daytona, #0023-4000, (mods)Inertia Motorsports heads/SRT MAX cam, AFR gauge, JBA CAT delete pipes/shorties, dual Magnaflows, Pro Torque 2800 stall converter, Diablo Predator, Custom CAI, 180 t-stat, NO ESP switch...bring it baby!
mtcraigco is offline
post #2 of 20 Old 09-01-2006, 09:22 AM
arfur
Supporting Member (Lifetime)
arfur's Avatar
Re: OIl Press and lifter noise
I have a little lifter/injector noise - not worried about it. I would use the oil advised by the manufacturer TBH - especially as you have the extended warranty. You don't need to put additives into a good quality synthetic oil IMHO. I am running Mobil1.
I think you might be worrying over nothing, but if it is bugging you that much, try popping it into the dealer and get them to adjust the tappets?
Don't Hassle the HOFF
Arf - expert in
and
arfur is offline
post #3 of 20 Old 09-01-2006, 11:14 AM Thread Starter
mtcraigco
Senior Member
(Thread Starter)
Yeah, It's still on the oil the dealer put in when they serviced it on receipt from daimler-chrysler. I'll go to a correct weight full synthetic at the first change.
I too think I am worrying over nothing, I tend to think every little noise is a catostrophic engine failure waiting to happen... BUT then I go and HAMMER on it anyway...!!!
I just wanted to make sure nobody was goin' to say they puked a rod or something 500miles after hearing a similiar noise.
Besides, I'm old school with a capital "O" and am not accustomed to injector popping noises and such. Now that I think about it it's possible it's an injector that's a bit noisy.
Just consider me paranoid..
post #4 of 20 Old 09-01-2006, 12:36 PM
RTjunkie
Senior Member
RTjunkie's Avatar
You're probably hearing the infamous "Hemi-Tick". These engines do have quite noisy lifters and valvetrains. If you pull the engince shroud off, the noticability increases substantially.
-Nate
'06 Silver Steel Charger R/T|R\T
RTjunkie is offline
post #5 of 20 Old 09-03-2006, 11:32 PM
MotorCity Muscle
Senior Member
MotorCity Muscle's Avatar
i thought the lifters and cams were supposed to make a distinctive sound anyways...
GONE - 2006 Brilliant Black Charger SRT8 Options I & II
"I am serious...and don't call me Shirley"
NOW - 2005 Midnight Blue Jeep Grand Cherokee Limited 5.7 Hemi
Still Hemi-fied, and Loving It!!!
MotorCity Muscle is offline
post #6 of 20 Old 09-04-2006, 06:58 AM
nCHARGE
Senior Member
nCHARGE's Avatar
Location: S.E. PA........(The birth of my 1st healthy grandson Dylan, is my true treasure from God. Amen)
That noise has bothered me since day one. Everyone says its normal, and we have to live with the imfamous HEMI tick. If I knew for sure that a heavier oil would help I'd do it. If all I lost was MDS its not a big deal for me, just as long as no other damage came along with the use of 10-30 or 10-40 oil.
06 Inferno Red Crystal Pearlcoat R/T
View>
<Here
View>
<Here
View>
<Here
nCHARGE is offline
post #7 of 20 Old 09-05-2006, 08:10 PM Thread Starter
mtcraigco
Senior Member
(Thread Starter)
I dropped a quart of Lucas full synthetic and it quieted down for a bit, along with a corresponding rise in Oil Pressure. Once everything got mixed good and the engine/oil went through several heat cool cycles and got ****genized well.....the noise came back just like before.
I wouldn't recommend going with heavier oil as just adding the Lucas raised my pressure to 50psi at idle and 70psi at cruise and under accelleration. Once it all settled down it;s back to 20 at idle and 45 or so at cruise.
A heavier weight oil would not settle down and that's WAY too much pressure if the pump/oiling system is not designed for it.
SSSOOoooooooo..............learn to love the "Hemi Tick!"
post #8 of 20 Old 09-15-2006, 03:04 PM
xcrider
Junior Member
Could it be the MSD decoupling the lifters that you are hearing at idle? Anyway that is what I keep telling myself what it is.....
Inferno Red R/T Window tint, remote start, headlight mod, mudflaps, seat belt chime mod
xcrider is offline
post #9 of 20 Old 09-15-2006, 03:16 PM Thread Starter
mtcraigco
Senior Member
(Thread Starter)
Never thought of that. Mybe so. Anyway, now that I know it's a common thing, I'm not going to worry about it. The noise goes away as soon as the rear tires light up!! Hooray for my S/C Flashpaq!
post #10 of 20 Old 09-15-2006, 03:19 PM
Crazy_luck
Senior Member
Crazy_luck's Avatar
Send a message via AIM to Crazy_luck Send a message via Yahoo to Crazy_luck
Quote:
MDS does NOT function at idle. The paramters do not exist - one of the parameters is oil pressure - it needs about 45psi oil pressure before it will engage.
Crazy_luck is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Lifter Noise nCHARGE Charger Problems/Assistance 61 02-03-2015 06:42 PM
Press Links ONLY!!! GLHS837 Picture/Media Post 6 01-10-2012 08:21 AM
MDS Lifter JasonB General Charger Discussion 3 06-27-2006 08:00 AM
The Press Roast DAYTONA_R/T Off-Topic 0 05-01-2006 05:49 PM
The Day Maybe Here Just Got A Press Release KMPX2 General Charger Discussion 15 08-19-2004 10:12 AM
You may post new threads
You may post replies
