Tie Rod vs Tie Rod Ends (Difference) - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 15 Old 02-18-2014, 12:00 PM Thread Starter
Brittny
Junior Member
(Thread Starter)
Took my car to an auto shop for an oil change & tire rotation and no more than 30 minutes later I get a call saying my Tie Rod Ends need replacing and that vehicle shouldn't be driven. Of course I ask them not to touch a thing.
I began searching online for Tie Rods, Tie Rod ends if my car needs inner and outer, if it even requires both, etc. Long story short they are asking over $500 for 3.4 hours of labor. I was able to find the exact brand (Moog) inner and outer ends for $111 through o'reilly.
Guys help me out. I honestly don't know what I'm doing or looking for $500 seems excessive
I drive a 2007 Dodge Charger V6 3.5L...i think i do know that it is RWD for sure.
Brittny is offline
post #2 of 15 Old 02-18-2014, 12:51 PM
06supercharger
Senior Member
06supercharger's Avatar
It's likely you do need tie rod ends, these cars go thru em like crazy, but $500 is a bit excessive. Find another shop or go to someone who's mechanically inclined. Not a huge deal to replace em.
Current - 06 Ram 1500 Laramie. TRX off road package, loaded. Stock so far.
Gone, never forgotten. 06 RT - Pred 93 CAI tune, K&N Drop In, Flowmaster Super 44's, Eibach pro kit, reso delete, drilled and slotted Baer rotors, Baer ceramic pads ,blacked out EVERYTHING .
KEEP CALM AND CHIVE ON ....
06supercharger is offline
post #3 of 15 Old 02-18-2014, 01:31 PM Thread Starter
Brittny
Junior Member
(Thread Starter)
Thank you so much for the info. Is it safe to assume that Tie Rods and Tie Rod Ends are the same things?
Brittny is offline
post #4 of 15 Old 02-18-2014, 01:41 PM
ColdSteel
Senior Member
ColdSteel's Avatar
Quote:
Nope. The tie rod is the metal rod that the inner and outer tie rod ends thread onto. The inner connects to the steering rack and the outer has the ball joint that allows the wheels to turn.
2008 R/T -Demoulded, Debadged, Daytona grille, Predator
Mopar CAI, Tinted Windows SLP Loudmouth II, BT Catch Can, BT Shift Insert
Matte Black SRT Replicas - <tires worn out>
Stock wheels with Firestone Winterforce tires
ColdSteel is online now
post #5 of 15 Old 02-18-2014, 01:55 PM Thread Starter
Brittny
Junior Member
(Thread Starter)
Quote:
Mindblow! This makes sense though. I did ask the folks at the shop this same question they insisted that the inner and outer rods needs replacing. I'll guess they meant the TIE ROD ENDS.
Brittny is offline
post #6 of 15 Old 02-18-2014, 02:35 PM
06supercharger
Senior Member
Tie rod ends are the outer rods. If they said you need both, then you need the inner and the tie rod end. And again, these cars eat em up, so I'm sure they're not bull****ting you. But you can do much better on the price. Last time I had em done I got full sets from rock auto and had my shop put em in since it was cold as hell. Charged me around $200 for labor. Killed me to pay for something I have done myself, but still better than freezing my nuts off.
post #7 of 15 Old 02-18-2014, 05:27 PM
Eleanor
Senior Member
Eleanor's Avatar
Go woth moogs, replace all four. You can do it yourself with a jack and basic tools very easily. Then take it for an alignment. I did mine in under two hours and I also did a ball joint at same time.
Black 2006 SXT - CAI, NOESP Mod, Tinted Tails, Tinted Windows, Pioneer AVH-X3500BHS.
Eleanor is offline
post #8 of 15 Old 02-18-2014, 05:44 PM
PlumCrazyDaytona
Supporting Member (Lifetime)
PlumCrazyDaytona's Avatar
Send a message via MSN to PlumCrazyDaytona Send a message via Yahoo to PlumCrazyDaytona
Use Moog, do it yourself. Now if your are doing your tie rods....do both lower ball joints at the same time to save yourself sometime and headache...the ball joints will fail next so replace them and be done for 50k
6.1 Intake manifold,SRT MAX cam on 112lsa, CNC Inertia Heads milled,mopar TCM,blue tops, 3000 Edge converter 3.91 Getrag, Kooks LongTubes, catless mids and SLP Loud Mouth II, powerbond undrive pulley, 170 tstat, , R1 crossdrilled/slotted rotors, HAWK Pads,eibach lowering springs,dampners,sways mopar strut braces, razors edge sub frame connectors #157 of 1400 ACES IV Quantum Blue Lubricants PB 1/4 12.38@110.66
PlumCrazyDaytona is offline
post #9 of 15 Old 02-18-2014, 06:30 PM
D's 08 RT
Senior Member
D's 08 RT's Avatar
Smile
Use the Moog problem solver greaseable parts.
The car must be raised and put on jackstands or on a lift to proceed
This is the outer tie rod end
This is the inner and the tool required to remove it
You have to remove this boot on the rack to gain access
Take a measurement before removing outers (for rough toe setting)
You're going to need this tool to release the tie rod ends
Then you can remove the outers with a pair of adjustable wrenches. Then remove the boot clamps, you may have to replace the inner with a narrow hose clamp. But If you're careful the inner one can be reused. remove the boot ,then place the tie rod tool (from HFT)with the crow foot on the inner and break loose with a 1/2" drive breaker bar or long handle ratchet
Installation is the reverse, Torque the inner to MFG spec or spec provided by moog, reinstall the boot/clamps, install the new jam nut/tie rod end and adjust to measurements taken before removal. Place the tapered studs in the spindle, tighten,torque to spec, install cotter key. Put the wheels on lower the car and go get an alignment.
If you need pics on how to change the tension strut or the lower ball joint I can post those up too, the tension strut is pretty easy, but the lower ball joints are a PITA unless you have the correct Miller tools (and a torch) to remove them., D
'08,R/T, R&T, Mopar CAI,strut brace & rear air diffuser,Diablo 91oct CAI tune,BT catch can,waterneck,fuse box,strut & underhood covers,Jet 180* t-stat,RE hood/trunk strut covers,Painted ABS cover,radiator shroud,tank & firewall,Stainless braided lines,3Gs engine cover inset,22" staggered Lexani lx-15wheels,UAS,Accuair,Progress sways, Koni shocks,BWoody end links,SPC UCAs front, JHS Adj. rear camberlinks,BFX HID 6000k Hi/Lo beams &3000k fogs,flashtech halos,Tinted windows,Tinted tails,Sequential tail lights,VDI doors, Red led interior & trunk lights,Billet pedals,Hurst billet shifter,R/T logo trunk liner,Flowmaster super 40s,Blastin' bobs resos,4" stainless DW tips .
D's 08 RT is offline
post #10 of 15 Old 02-18-2014, 06:33 PM
Eleanor
Senior Member
Eleanor's Avatar
Dont need lift or jackstands. A simple 2 ton floor jack gets it done
Eleanor is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Tags
tie rod-tie rod ends-help
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Tie Rod Ends - Question? ChargerSG Wheels/Tires/Brakes/Suspension 8 01-29-2014 11:22 PM
replace tie rod ends deltafrce Wheels/Tires/Brakes/Suspension 21 09-17-2012 11:21 AM
Tie Rod ends Shot!!!! ChargerSXT2007 Charger Problems/Assistance 32 10-04-2010 04:56 AM
Moog Tie Rod Ends 40valves Charger SRT-8 Discussion 0 03-31-2010 11:15 AM
Tie rod ends scatpackmopar Wheels/Tires/Brakes/Suspension 3 08-31-2009 02:02 PM
You may post new threads
You may post replies
