Stalling issue resolved with new Chrysler lifetime fuel tank warranty! - Dodge Charger Forums
post #1 of 200 Old 02-14-2014, 01:08 PM Thread Starter
Ddaddy
Supporting Member (Lifetime)
Ddaddy's Avatar
Garage
(Thread Starter)
US ends probe of Chrysler engine stalling
Feb 14, 9:03 AM (ET)
DETROIT (AP) - The National Highway Traffic Safety Administration has closed an investigation into engine stalling in some Chrysler cars after the company extended the fuel tank warranty.
The probe covered nearly 154,000 Chrysler 300, Dodge Charger and Dodge Magnum cars from 2006. The cars have 5.7-liter or 6.1-liter V8 engines.
Investigators checked more than 1,200 complaints and found 299 in which the fuel system allowed gas tanks to be over-filled. That caused the cars to stall when stopped or at low speeds.
The problem was traced to a fuel shut-off device that can stick open when exposed to high-ethanol gasoline. Chrysler updated the part in new cars and guaranteed it for life in cars now on the road.
The agency said Friday that the problem is a low risk to safety.
2006 Charger SRT-8
1969 Dart GTS 340
2012 Chrysler 300C Hemi
All V8 Mopars!
Ddaddy is offline
post #2 of 200 Old 02-14-2014, 01:59 PM
GLHS837
Super Moderator
GLHS837's Avatar
Wait, so if my car ever suffers the overfill leading to the tanks becoming useless, ever, its covered?
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
GLHS837 is offline
post #3 of 200 Old 02-14-2014, 02:10 PM
Ron380
Senior Member
Ron380's Avatar
Garage
I sure wish that covered the problematic ball-valve in the RAM fuel tanks! Look for "fuel overflow" on any Dodge Truck forum! IF the previous owner had taken the truck in to get this looked at (under the 3/36 warranty) it would have been fixed free! Me, I'm outa ruck.
I can "guesstimate" fairly well how much fuel I need to fill it, so I can do the first 2/3rds or 3/4's using the "lock" tab on the pump. Then I have to stop the flow for a minute, then continue v e r y s l o w l y until the pump shuts off. Otherwise it spews gas all over the ground.
2007 TorRed SXT/AWD: Gone, but not forgotten.
2015 Subaru XV Crosstrek
2007 Ram 1500 4x4, 4.7l V8.
Ron380 is offline
post #4 of 200 Old 02-14-2014, 02:13 PM Thread Starter
Ddaddy
Ddaddy's Avatar
Garage
(Thread Starter)
Quote:
That's what they say. All existing vehicles on the road with this design issue will be covered for life.
It makes sense since it saves them the cost of recalling all of them and only have to fix the ones that come in for repair. I also suspect that if it's fixed once, it will never need to be fixed again since they have redesigned the part at issue.
Ddaddy is offline
post #5 of 200 Old 02-14-2014, 02:36 PM Thread Starter
Ddaddy
Ddaddy's Avatar
Garage
(Thread Starter)
From another source...
February 14, 2014 at 8:46 am
Chrysler extends fuel tank warranties on 153,000 older cars
David Shepardson
Detroit News Washington Bureau
Chrysler is extending warranties on fuel tanks in more than 153,000 older vehicles over complaints of engine stalling at low speeds, the government said Friday.
The National Highway Traffic Safety Administration said Friday it is ending its investigation into 153,817 2006 Chrysler 300, Dodge Charger and Magnum vehicles equipped with 5.7L and 6.1L 8-cylinder HEMI engines after receiving nearly 300 reports that the engines may stall refueling when the vehicle is stopped or traveling at low speeds.
The safety agency said the problem didn’t represent a serious risk to auto safety and said Chrysler’s solution was adequate.
NHTSA’s decision came after last month when Chrysler and a supplier developed a solution to the problem and extended lifetime warranty coverage on the vehicles’ fuel tanks, NHTSA disclosed in a document posted Friday.
NHTSA said the multifunction control valve fuel shutoff float integrated into 19-gallon fuel tanks can swell in a stuck open position allowing an overfill condition.
“This condition causes fuel to enter into the purge line which may result in engine stall after refueling. Chrysler's investigation determined that the problem was related to dimensional changes/swelling of the float when exposed to fuels with high ethanol content,” NHTSA said. “Chrysler and its supplier, Stant, developed new fuel soak test requirements to address the condition and extended the warranty period on 19-gallon fuel tanks to lifetime coverage.”
NHTSA said there were 299 unique reports indicating that the fuel system allowed an overfill condition after refueling, and the predominant failure mode identified involved stalling when stopped or traveling at low speeds.
“The condition that is causing the majority of stalling incidents in the subject vehicles occurs at a stop or low speed and allows the vehicle to be restarted immediately. The condition represents a low risk to motor vehicle safety and is adequately addressed by Chrysler's extended warranty,” NHTSA said.
Ddaddy is offline
post #6 of 200 Old 02-14-2014, 06:52 PM
Part Deux
Super Moderator
Part Deux's Avatar
How about NHTSA?
http://www-odi.nhtsa.dot.gov/cars/pr...h&summary=true
Going to move this and sticky it
aka THO.R
Quote:
Originally Posted by 08 Stoned Charger View Post
I have a name for the 3 new mods...............Druken Purple Pirates!!!
Quote:
Originally Posted by Daytona606 View Post
American Muscle, like a pit bull. Big but not large, well defined, explosive power, in it till the end. The cat will give it go and zig and zag, but in the end the pit bull will always catch the cat – the outcome is never good for the cat.
Part Deux is offline
post #7 of 200 Old 02-14-2014, 07:16 PM Thread Starter
Ddaddy
Ddaddy's Avatar
Garage
(Thread Starter)
Quote:
Originally Posted by Part Deux View Post
How about NHTSA?
Cool, thanks! Good call on adding the NHTSA link.
Ddaddy is offline
post #8 of 200 Old 02-14-2014, 07:23 PM
Part Deux
Super Moderator
Part Deux's Avatar
This is why I always recommend people file complaints with NHTSA. Enough complaints come in and they start an investigation. Nothing gets an OEM more "excited", than the NHTSA knocking at their door saying, we think there's a problem here.
post #9 of 200 Old 02-14-2014, 09:18 PM
mnunes
mnunes's Avatar
I've added a link to the "Everything" thread on this, too.
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #10 of 200 Old 02-16-2014, 07:13 AM
TB88
Senior Member
Great news. I wonder what the letter will tell owners to do?
TB88 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Best price on Chrysler lifetime extended warranty? HODaytona297 General Charger Discussion 20 07-05-2011 01:11 PM
Fuel Pump Modules - stalling at 1/4 tank Zandian Charger Problems/Assistance 0 01-20-2011 08:26 AM
Car stalling issue resolved..... SD_SRT8 General Charger Discussion 2 11-19-2009 04:07 PM
Chrysler Dropping Lifetime Warranty ! richd General Charger Discussion 20 09-18-2009 10:53 AM
Should I buy the Chrysler Extended Lifetime Warranty? spikescharger General Charger Discussion 7 04-12-2008 10:59 AM
You may post new threads
You may post replies
