Timing Chain RECALL 2009-2012 - Dodge Charger Forums
post #1 of 24 Old 02-12-2014, 11:36 AM Thread Starter
sublime 781
Senior Member
sublime 781's Avatar
(Thread Starter)
Customer Satisfaction Notification P01
Engine Timing Chain and Chain Guide
Models
IMPORTANT: Some of the involved vehicles may be in dealer used vehicle inventory. Dealers should complete this repair on these vehicles before retail delivery. Dealers should also perform this repair on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process.
Subject
Repair
2009-2012 (LC) Dodge Challenger
(LD) Dodge Charger
(LX) Chrysler 300
NOTE: This recall applies only to the above vehicles equipped with a 5.7L Hemi engine (sales code EZD or EZH), automatic transmission (sales code DGJ) and rear axle ratio 3.06, 3.73 or 3.92 (sales code DMP, DME or DMH) built from August 04, 2008 through July 10, 2012 (MDH 080406 through 071008).
The engine timing chain guide on about 50,800 of the above vehicles may fracture. A fractured engine timing chain guide could cause the engine timing chain to break. A broken engine timing chain will result in severe engine damage.
The engine timing chain, timing chain tensioner and timing chain guide must be replaced. Customer Satisfaction Notification P01 Engine Timing Chain and Chain Guide Page 2
Part Number Description
CBPRN291AA Engine Timing Chain Package
Each package contains the following components:
Quantity Description
1 Chain, Engine Timing
1 Guide, Engine Timing Chain
1 Tensioner, Engine Timing Chain
1 O-ring, Oil Pick-up Tube
1 Gasket, Engine Timing Cover
NOTE: Order two heater tube O-rings separately listed below for each repair.
53013736AA O-ring, Heater Tube (order two per vehicle)
Each dealer to whom vehicles in the recall were assigned will receive enough Engine Timing Chain Packages to service about 5% of those vehicles.
Part
07 Daytona R/T Sublime #781 "Frankie" stein stock
2010 Furious Fuchsia Challenger
sublime 781 is offline
post #2 of 24 Old 02-12-2014, 09:14 PM
lowriderman3
Senior Member
lowriderman3's Avatar
Just seen it on FB.
"They Were Just Jealous That My Charger Pulled More Kitties Than A Bowl Of Milk"
lowriderman3 is offline
post #3 of 24 Old 02-12-2014, 10:21 PM
PlumCrazyDaytona
Supporting Member (Lifetime)
PlumCrazyDaytona's Avatar
Send a message via MSN to PlumCrazyDaytona Send a message via Yahoo to PlumCrazyDaytona
Is this an upgraded part? or is there bad chain out there?
6.1 Intake manifold,SRT MAX cam on 112lsa, CNC Inertia Heads milled,mopar TCM,blue tops, 3000 Edge converter 3.91 Getrag, Kooks LongTubes, catless mids and SLP Loud Mouth II, powerbond undrive pulley, 170 tstat, , R1 crossdrilled/slotted rotors, HAWK Pads,eibach lowering springs,dampners,sways mopar strut braces, razors edge sub frame connectors #157 of 1400 ACES IV Quantum Blue Lubricants PB 1/4 12.38@110.66
PlumCrazyDaytona is offline
post #4 of 24 Old 02-13-2014, 07:55 AM Thread Starter
sublime 781
Senior Member
(Thread Starter)
all the parts are upgrades, the most affected are Challengers for some reason. There have been a lot of broken chains and destroyed motors. Parts plus tuning possibly.
post #5 of 24 Old 02-13-2014, 09:25 AM
PlumCrazyDaytona
Quote:
Got a link to verify that? The VVT engines are different from the MDS engines. If a better chain and tensioner is available some of us might want to make a swap
post #6 of 24 Old 02-13-2014, 09:33 AM
WTFO09R/T
Senior Member
WTFO09R/T's Avatar
Ill be calling my dealer ASAP!
Name is brad
All GO FAST and NO SHOW
Bolted, Geared, and Bottle Fed
"If one day speed kills me, do not cry because I died smiling"
WTFO09R/T is offline
post #7 of 24 Old 02-13-2014, 10:05 AM
WTFO09R/T
Senior Member
WTFO09R/T's Avatar
Well, dealer is putting a new chain and tensioner on my car. I'm willing to bet it will be the chain and tensioner from the 392.
post #8 of 24 Old 02-13-2014, 10:47 AM Thread Starter
sublime 781
Senior Member
(Thread Starter)
Quote:
MDS only not affected, pre 2009. MDS with VVT 2009 and up affected. Parts do not interchange. these are the latest upgraded parts and Dodge will put them in for free.
Google search Challenger timing chain and you will find all the info.
post #9 of 24 Old 02-14-2014, 05:22 PM
SuperTrooper169
Senior Member
SuperTrooper169's Avatar
Hmmm so my '09 R/T with the 2.65 gears is not effected but ones with 3.06s and on up are? How does that make any sense? Should I still call my dealer and find out?
Hemifever 93 Tune // LMI CF Hammer Intake // JBA Silver Ceramic Shorty Headers // JBA Highflow Mid-Pipes // Corsa Xtreme Catback // JET 180į T-Stat // BT Oil Catch Can // TranZformer Shift Kit // STP Wheels // MOPAR Stage1 Springs // Koni STR.T Orange Shocks // RotorPro Police Package Rotors // Centric Posi-Quiet Pads // Petty's Garage Strut Tower Brace // Hurst Comp Stick // OEM Style HID Projectors // MOPAR Bright Pedal Kit // MOPAR Rear Diffuser // MOPAR Hood Struts // Pro Motor Stripes Graphics // Shaved Door Moldings
SuperTrooper169 is offline
post #10 of 24 Old 02-14-2014, 08:45 PM
Cuts2TheBone
Senior Member
Cuts2TheBone's Avatar
So are the srts not effected??
Please disregarded. Didn't fully read the description.
Always looking for a good run
2012 Charger SRT8 Blue Streak Pearl
12.53@ 110! Stock
Goal - Low 11s with just a Procharger..no DRs.
2009 Tored Charger SRT8 - Gone but not forgotten.
Cuts2TheBone is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Timing Chain jafawh1 Performance Discussion/Modifications (2011 +) 4 10-21-2013 11:14 PM
Timing Belt or Timing Chain? epoy V6 Specific Discussion 9 08-17-2010 09:58 AM
Timing Belt..Chain.. REDNECK Charger General Charger Discussion 16 11-02-2007 06:19 PM
Timing chain tensioner BLWN HMI General Charger Discussion 4 06-06-2007 09:33 PM
Timing Belt or Chain.. CountryLad Charger Problems/Assistance 10 06-15-2006 10:59 AM
You may post new threads
You may post replies
