3 in. exhaust? - Dodge Charger Forums
Performance Discussion/Modifications Discuss any performance modification in this section.
post #1 of 16 Old 11-09-2013, 06:35 PM Thread Starter
Daytona#2103
Senior Member
Daytona#2103's Avatar
(Thread Starter)
3 in. exhaust?
So im looking into doing my exhaust. Im really trying to avoid paying someone to do it for me. My plan was to get long tube headers. Coming right off the header collector would be 3in exhaust cutouts then exhaust tubing to where the stock ehaust comes. 3in cats then straight piping to the rear into 3in inlet and 5in oulet tips. Description might be confusing but tell me what you think if it makes sense. Here's a picture of what I'm trying to do.
2006 Daytona Top Banana
#2103. K&N CAI, GTS head and tail light covers, shocker TRAIN HORN
, tail light hide-away strobes, grill strobes, red led footwell lights, 25% tints back and 30% in front. yellow painted calipers, stock daytona rims painted black, KOOKS LT headers, SLP LM1, QTP low profile cutouts, razor's edge front and rear strut bars, diablosport trinity, billet tech oil catch can, decepticon emblems, Go Rhino pushbar, Adrenaline Lights Led Light Bar.
Last edited by Daytona#2103; 11-09-2013 at 06:52 PM. Reason: adding a pic. and change the wording of a sentence
Daytona#2103 is offline
post #2 of 16 Old 11-09-2013, 10:51 PM
ccagle
Senior Member
ccagle's Avatar
Your stock exhaust you're tying into isn't 3", it's 2 1/2 I believe. So you'll have that restriction. In addition, buy earplugs. You'll need them.
Sent from AutoGuide.com App
ccagle is offline
post #3 of 16 Old 11-09-2013, 11:09 PM
Ddaddy
Supporting Member (Lifetime)
Ddaddy's Avatar
Garage
Bigger isn't better. Larger diameter tubes will lose scavenging efficiency and you will lose performance.
Why do you think you want larger pipes?
2006 Charger SRT-8
1969 Dart GTS 340
2012 Chrysler 300C Hemi
All V8 Mopars!
Ddaddy is offline
post #4 of 16 Old 11-10-2013, 11:05 AM Thread Starter
Daytona#2103
Senior Member
(Thread Starter)
I know the stock exhaust is 2.5in. Im gonna be redoing the whole exhaust to 3in. The cutouts will be for track use and show only. And yes, I plan on getting ear plugs. I started my car once with only the headers on and it was loud!
post #5 of 16 Old 11-10-2013, 11:15 AM Thread Starter
Daytona#2103
Senior Member
(Thread Starter)
I don't think I would lose power with 3in pipes, in my opinion. Wouldn't the exhaust flow better? I figured I would keep the diameter 3in. because thats the diameter of the header collectors. If I put a reducer to 2.5in. wouldnt that cause restrictions to the flow? Im just going on my own logic and my auto mechanics instructor who used to be in racing (I think drag racing) really likes the idea.
post #6 of 16 Old 11-10-2013, 11:29 AM
RT_HEMICHARGED
Senior Member
3" is a little bit overkill especially with the older 5.7L. I'm doing SRT shorty headers on mine which have either a 2.75 or 3" collector area, to 3" cat-less mid pipes, to 2.75" stock SRT catback on my R/T with the newer 5.7L. From what i've been told even this is a little overkill, but oh well. You should be fine with that setup, however it's going to be LOUD LOUD LOUD all the time.
Bigger exhaust piping isn't always better. It comes a point in time where it's just overkill. Exhaust systems work on scavenging. The exhaust pulses work in such a way that one pulse is used to help pull the other out away from the engine. By needlessly increasing the size of the piping, you are changing the rate at which the exhaust pulses can effectively scavenge and therefor hurting performance in some aspect. Will you make more power with this system compared to stock, the way you have it planned out currently? Yes. Would you make more power with this same setup, but in a 2.5" trim? Probably.
There are times where it is necessary to increase the exhaust diameter, such as instances of larger displacement engines, forced induction, etc.
2011 Dodge Charger R/T Plus - SOLD
2013 Dodge Dart Rallye Multiair Turbo - SOLD
2012 Chrysler 300 SRT8 - The new whip
RT_HEMICHARGED is offline
post #7 of 16 Old 11-10-2013, 01:34 PM
Jonny
Jonny's Avatar
Stock exhaust on your car is actually 2 1/4"
It is 2 1/2" at the mid pipes forward, but from where the mid pipes meet the x pipe (Black arrow) on back, it's 2 1/4"
Unless you have drastically increased the incoming air flow, adding a 3" exhaust will hurt your exhaust's ability to scavenge the charge out of the cylinders, reducing power.
You WILL lose power, unless you are making about 450hp right now...
Stock exhaust cuts down 1/4" after the cats, that's pretty normal for any exhaust. You want your gasses to flow fast enough to suck the fresh charge into the cylinders, but not be impeded. Correct size for the Charger with 350HP works out to.... 2.25-2.5"
I am the Stig
2010 R/T DWBlue, 2800 PI stall, Homemade CAI, JBA headers and mids, SLP LMII catback, Custom tune by Diablotoona, 180 T-stat, 3.06 Getrag.
Jonny is offline
post #8 of 16 Old 11-10-2013, 03:37 PM Thread Starter
Daytona#2103
Senior Member
(Thread Starter)
Well, with where everyone seems to be goin, I'll probably put a 3in to 2.5in reducer after the cutouts. Now with that settled, lets talk cats and X/H pipe. Does it matter the placement of the cats? Are they fine where I have them in the pic I drew or...? And whats the difference between an X and H pipe? Is it really the same thing just different in that one's an X and the other's an H? I forgot to draw it in the pic but I would have an H pipe right after the cats.
post #9 of 16 Old 11-10-2013, 03:55 PM
RT_HEMICHARGED
Senior Member
H and X pipes both basically do the same thing. They equalize the exhaust scavenging of both sides. X pipes are usually a little more efficient at doing so and often give you higher peak HP numbers. Also, X pipes give you more of a raspy race car exhaust note, where as H pipes give you more a deep old school muscle car growl. The chargers come with X pipes from the factory, and that's what I would leave on there since I like the raspy rumble of the X-pipes. The cats you want as close as possible to the header collectors, otherwise they're not going to work that well, and you'll get a catalyst inefficiency CEL. As it is you'll probably get one with longtubes anyway, unless you run a California legal converter and use some oxygen sensor spacers.
post #10 of 16 Old 11-10-2013, 04:04 PM
Yuro
Senior Member
Yuro's Avatar
I did this with an SRT Magnaflow catback. Didnt dyno, but i felt the loss of torque. I countered this loss with a huge MoparCAI intake tube, and replaced the(in my opinion) restrictive Mopar one filter with a Spectre Cone filter, removed the driver's side radiator plastic so that more and colder air would be forced into the filter compartment. Cruised better and got back the torque I had lost as I felt. I thinnk 2.75 would be optimal, 3 inch may prove better for future modding though... let us know whatsup tho!
as for x pipes and whatnot, since u have a daytona version u may have a wider exhaust, u may have the beefy xpipe, i would leave that on. And the resonators
matter of fact go 2.75 all the way to the resos from the x pipe. No drone, smooth sound, and performance
TorRed or NoRed!
"WTFO" Sponsored
WTFO weaponry:
Strut Bar V 2.1
"Being a good fiend is like being a photographer, you have to search for the right moment!"
Yuro is offline
  Dodge Charger Forums > Dodge Charger Discussion > Performance Discussion/Modifications
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
american racing headers on stock exhaust or AR exhaust worth it? charging_bull Charger SRT-8 Discussion 1 06-04-2013 12:53 AM
Wtb/looking for a stock r/t exhaust or mopar/borla dual exhaust DeLEON Texas 0 01-06-2012 12:04 PM
FS: Raleigh, NC - Hemi Charger R/T Dual Exhaust Converted to 3.5L V6 SE/SXT Exhaust dan50 Parts For Sale/Wanted 10 10-20-2009 11:29 AM
Good 5.7L Intake/Exhaust Setup (CAI, Headers, Exhaust) baRTch06 Performance Discussion/Modifications 7 11-09-2008 08:13 AM
Wanted, Daytona Exhaust or RT Exhaust w/ R&T For Sale in SoCAL FistFullofDollars Parts For Sale/Wanted 2 11-28-2007 02:50 AM
You may post new threads
You may post replies
