Front end rattle - Dodge Charger Forums
post #1 of 24 Old 05-02-2013, 09:15 AM Thread Starter
Jonny
Supporting Member (Lifetime)
Jonny's Avatar
(Thread Starter)
Front end rattle
UPDATE:
I replaced the tension struts, WHAT A DIFFERENCE!!!!! I can feel the difference in so many ways.
No creaking in the steering wheel, no rattling down the road, no creaking over bumps (new development, the bushings were deteriorating rapidly.)
If you are experiencing this, this is likely your problem!
Original post:
Front end rattles, small bumps, big bumps, just randomly.
Not a nasty clunk, it's a light to moderate rattle.
Replaced outer tie rods a couple ten thousand miles ago.
New sway bar bushings last year.
Put the car on a jack, nothing obvious like when the tie rods went.
Best way to check for loose stuff? Suggestions?
I am the Stig
2010 R/T DWBlue, 2800 PI stall, Homemade CAI, JBA headers and mids, SLP LMII catback, Custom tune by Diablotoona, 180 T-stat, 3.06 Getrag.
Jonny is offline
post #2 of 24 Old 05-02-2013, 09:50 AM
Wyoo
Senior Member
Wyoo's Avatar
hey Jonny seen this old post from Ddaddy and throwing it your way http://www.chargerforums.com/forums/...d.php?t=151800 and also suggest checking strut bolts and bushings good luck
Wyoo is offline
post #3 of 24 Old 05-02-2013, 03:25 PM
Yuro
Senior Member
Yuro's Avatar
Jonnyyyy budddyyy wutsup how r u todayyyy. Im sending u on an adventure ok? Bear with me, lets hope u understand my fancy descriptions.
Pop the hood open, right at the hood latch there are 2 overlapping plastic covers, take them off, they pop off easily if you angle them towards you i think. Stick your hand in there, you should be able to fit it via one side, and navigate your hand to a piece of plastic that is on the driver's side of the radiator. Apply light pressure and see if that's what is rattling about with slight wind force. If it is, well idk whats next, we find a way to strap it down or remove if not needed?
Searched the location of it and it seemed to be related to some picture of the "chilly air mod" lemme know sup.
TorRed or NoRed!
"WTFO" Sponsored
WTFO weaponry:
Strut Bar V 2.1
"Being a good fiend is like being a photographer, you have to search for the right moment!"
Yuro is offline
post #4 of 24 Old 05-02-2013, 05:06 PM Thread Starter
Jonny
Jonny's Avatar
(Thread Starter)
Appears to be the sway bar bushings (isolators) yet again.
Parts on order.
Jonny is offline
post #5 of 24 Old 05-05-2013, 01:40 PM
Yuro
Senior Member
Yuro's Avatar
Rile us up why dont ya
Yuro is offline
post #6 of 24 Old 05-05-2013, 06:45 PM Thread Starter
Jonny
Jonny's Avatar
(Thread Starter)
I already tried the strut tower brace, that was tight. The rattle isn't a body component, you can feel it in the SOTP and steering wheel. It's a suspension component, for sure.
I lubed and re-aligned the sway bar bushings, which temporarily quieted the rattle.
Jonny is offline
post #7 of 24 Old 05-07-2013, 08:45 PM Thread Starter
Jonny
Jonny's Avatar
(Thread Starter)
...and today I replaced the sway bar bushings.
...and today it still rattled.
FuG.
Could it possibly be that engine mount that's cracked/broken, that I have yet to replace?
What bushings go in the front end, and how to check them without dismantling the whole front end?
Jonny is offline
post #8 of 24 Old 05-07-2013, 08:57 PM
Yuro
Senior Member
Yuro's Avatar
Let me know where this is at, i may have same thing. Did u check what i suggested?
Yuro is offline
post #9 of 24 Old 05-08-2013, 04:24 AM
sector 2
Senior Member
sector 2's Avatar
Jonny....I can bet it is either a ball joint, or more than likely the bushing on the tension strut is fried. It will rattle and drive you up the wall I know. Real easy to check and change. Let me know.
2013 Charger R/T
Gone and missed...2007 RT
"We sleep soundly in our beds because rough men stand ready in the night to visit violence on those who would do us harm."--George Orwell
sector 2 is online now
post #10 of 24 Old 05-08-2013, 05:29 AM Thread Starter
Jonny
Jonny's Avatar
(Thread Starter)
Yuro, checked those things you suggested, that was not it.
Sector 2, thanks, I'll check those next!
Jonny is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
front end rattle halfasteddie Wheels/Tires/Brakes/Suspension 1 12-22-2012 03:47 PM
Rattle in front end fixed! brently04 Charger Problems/Assistance 0 07-23-2011 11:57 AM
Front End Rattle SXT 3.5L BMacM65 Wheels/Tires/Brakes/Suspension 1 06-27-2010 10:02 AM
Front-end rattle zman Charger SRT-8 Discussion 3 05-18-2007 08:00 PM
KW V2 Install - Front Rattle! ARGH! shocker Charger Problems/Assistance 5 09-25-2006 04:06 PM
You may post new threads
You may post replies
