07 hemi wont hold steady idle rpm - Page 2 - Dodge Charger Forums
post #11 of 61 Old 04-30-2013, 05:17 PM
KJA88
Member
KJA88's Avatar
TPS sensor perhaps.
KJA88 is offline
post #12 of 61 Old 04-30-2013, 05:22 PM Thread Starter
hotbird
Member
(Thread Starter)
Quote:
Originally Posted by KJA88 View Post
TPS sensor perhaps.
That is the first [place I would look on a older car.
But this car is drive by wire. No TPS
Just has a Accelerator position sensor and the throttle body internals.
Any one have a code scanner that shows data (pids) willing to look at something for me?
I need a 5.7 hemi drive by wire owner to look at a few pids for me to see if what I have is normal or if my Pedal sensor is bad..
The pedal has 2 sensors one reads say 14.6 at idle and the other reads about half of the first say 7.3 but the second sensor reads 0 then 7.3 then 0 this is with out pressing the pedal at all.
Im thinking this reading might be why my the idle goes up and down, because the sensor it reading up and down.
But I cant find anywhere how to test the pedal or if this is normal or not.
If it was a cheap part I would get it just to see but its like $150-250
hotbird is offline
post #13 of 61 Old 05-02-2013, 05:17 AM Thread Starter
hotbird
Member
(Thread Starter)
any one have any ideas?
hotbird is offline
post #14 of 61 Old 05-02-2013, 10:22 PM
Yuro
Senior Member
Yuro's Avatar
Hmmm... Have you tried any type of cleaner just in case? What RPMs does it idle at when in drive. Can you adjust the throttle control thingy like on older cars? When my cars egr made me start stalling out my dad would adjust something with the screwdriver and it would send more fuel in and idle higher...
Check the coil packs are working correctly.
TorRed or NoRed!
"WTFO" Sponsored
WTFO weaponry:
Strut Bar V 2.1
"Being a good fiend is like being a photographer, you have to search for the right moment!"
Yuro is offline
post #15 of 61 Old 05-02-2013, 10:26 PM
Yuro
Senior Member
Yuro's Avatar
Btw are those holes in the air box near the coolant reservoir?
Yuro is offline
post #16 of 61 Old 05-03-2013, 06:47 AM Thread Starter
hotbird
Member
(Thread Starter)
Quote:
No holes just the plastic melted some. not sure why.
It makes me wonder about the history of this car.
I cleaned the throttle body spot less front and back and it made no change.
I guess I could block off the egr just to rule it out.
I see no adjustments on the throttle body.
I am going to try a new Accelerator pedal assembly to rule that out also.
hotbird is offline
post #17 of 61 Old 05-03-2013, 06:49 AM Thread Starter
hotbird
Member
(Thread Starter)
How do I check the coil packs?
hotbird is offline
post #18 of 61 Old 05-03-2013, 06:59 AM
MoparMuscle
Senior Member
MoparMuscle's Avatar
What rpm is it idling at?
2006 Dodge Charger 5.7L V8 R/T R&T
-Mopar CAI/Jet 180/ BT Catch Can
-SLP Loudmouth 1 Catback
-JBA Titanium Coated Shorty Headers
-JBA High Flow Catted Midpipes
-93 Octane/MDS Delete/ Dyno Tune by FASTLANE
-322 RWHP/ 359 RWTQ
MoparMuscle is offline
post #19 of 61 Old 05-03-2013, 05:15 PM Thread Starter
hotbird
Member
(Thread Starter)
Quote:
You mean when its not reving up and down? About 800-900 I think
hotbird is offline
post #20 of 61 Old 05-03-2013, 06:02 PM
MoparMuscle
Senior Member
Quote:
I mean how erradic is the rpm moving up and down? When you first turn on your car it will take a min for the rpm to reach about 650. Mine gradually settles from about 950 rpm to eventually the normal 650 and even when it goes down it never just sits constanly at 650 it revs between 650 and 675
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
06 r/t wont go faster than 40 miler per hour, wont go into 2nd gear, check engine on eggsandbacon Charger Problems/Assistance 8 02-15-2011 07:57 PM
Fuel Saver Mode Goes On and Off 3-times in a row at 65 mph steady bradrulz General Charger Discussion 4 02-02-2011 11:47 AM
Daytona or Hemi owners engine rough idle ? go-mango Charger Problems/Assistance 39 05-28-2008 01:07 AM
stock idle? and idle after cai chris shades Performance Discussion/Modifications 0 11-15-2006 10:43 AM
You may post new threads
You may post replies
