2012 Charger RT Transmission Valve Body Needs Replaced - Dodge Charger Forums
Charger Problems/Assistance (2011 +) You having problems with your Charger? Check and see if it is a common problem and get answers here.
post #1 of 41 Old 04-10-2013, 07:21 AM Thread Starter
chargermaxx
Senior Member
chargermaxx's Avatar
(Thread Starter)
Question 2012 Charger RT Transmission Valve Body Needs Replaced
So on Monday I was driving the car normal to the local store and noticed during a shift change a clunk as if it missed a gear. Kinda weird in an automatic but following accordingly my check engine light came on. I lost all power as if the car was left in neutral. Had to pull into the center of the road and turn the car off. Started back up and drove fine after. Little scary to lose power on the highway with the kids in the car and traffic all over the place at rush hour. Went straight to the dealer where they put me in a rental and read the check engine light. Came back as incorrect gear ratio. So now they have contacted Dodge engineering and they recommend they replace the valve body due to possible debris causing this error. They were unable to duplicate this problem but as a precautionary measure they going to replace it and all new fluids/ filter. I barely have 6000 miles on the car and it is not modified besides a lmi hammer intake. At the time I was not even driving hard but was in auto stick mode.
Has anyone else seen this problem happen with our cars or older ones? I thought it was limp mode but the dealer has said other wise. As well I have numerous electrical problems with this car since I've bought it. Nothing major that they haven't been able to fix until now that it becomes a safety issue!!
chargermaxx is offline
post #2 of 41 Old 04-10-2013, 07:36 AM
Stevens12
Senior Member
Stevens12's Avatar
Good luck getting it fixed. Hopefully the dealer figures out the issue. I've not had any kind of issue like that... and hope I don't either.
Now my rear speaker deck vibrates when I crank the tunes... its really annoying.. lol
Current 2013 Dodge Charger SRT8, Corsa Extreme exhaust, 20% window tint, AEM drop in filter
Stevens12 is offline
post #3 of 41 Old 04-10-2013, 07:53 AM Thread Starter
chargermaxx
Senior Member
(Thread Starter)
Thanks for the reply. And I'm hoping the same thing that this fixes the issue and it doesn't arise again at a later point. Thank you 100k warranty!
I haven't had any troubles with any rattling besides the sun-glass holder that everyone complains about..
post #4 of 41 Old 04-10-2013, 07:56 AM
Stevens12
Senior Member
Stevens12's Avatar
I don't have that issue...lol Didn't even hear/read about that one. I hate rattles and vibrations... I've had the car in twice for the rear deck rattling when songs with base come on. It's going back again... see if there's anything else they can do.
Good luck
post #5 of 41 Old 04-10-2013, 08:08 AM Thread Starter
chargermaxx
Senior Member
(Thread Starter)
Let me know if they come up with anything at the dealer. So if this becomes an issue I can get it fixed as well.
post #6 of 41 Old 04-10-2013, 08:41 AM
hskr
Senior Member
hskr's Avatar
Send a message via AIM to hskr Send a message via Yahoo to hskr
This is exactly why manufacturers provide warranties. **** happens.
Brian
hskr is offline
post #7 of 41 Old 04-10-2013, 10:04 AM
michiganpat
Senior Member
michiganpat's Avatar
my 2011 did something similar last year. What it turned out to be was a broken support bracket for the valve body. what happens is sometimes when the torque converter clutch breaks/beds in, it creates some debris, which can cause valves in the valve body to stick....they stick until enough pressure builds to release them, and that violent release can break this support bracket. it's not a common problem, but it is a known one. the tranny guy at the dealer knew exactly what it was when I brought it in before they even did the diagnostics/visual inspection, and the bracket needed was on national backorder, but they were able to get one through a transmission rebuilder that apparently buys all of chrysler's stock of this part when they become available.
the service manager said mine is the 4th car they've seen at the dealership with this problem since the LX's were introduced in 2005. the other 3 were all charger cop cars.
Chrysler's warranty procedure is to replace the bracket, and flush and inspect the transmission (and repair any other damaged items, like if the internal tranny speed sensor was damaged, etc). if it happens again, you get a new torque converter. of the 3 other cars that the dealer saw with this problem, only 1 came back a second time with the issue and needed a new converter.
they had my car for 2 or 3 days, IIRC.
'11 Toxic Orange Charger R/T
'06 Dodge Grand Caravan
'76 Plymouth Duster
michiganpat is offline
post #8 of 41 Old 04-10-2013, 12:18 PM Thread Starter
chargermaxx
Senior Member
(Thread Starter)
Quote:
Do you know if they replaced the valve body as well when they did the service? The dealers parts dept says sometimes they come with the bracket when they order the valve body sometimes they don't. They say there gonna have to wait til it gets into see.
They were not familiar with this problem at all that's why they called dodge directly. Hopefully someone over there knows what they are talking about lol.
post #9 of 41 Old 04-10-2013, 01:59 PM
michiganpat
Senior Member
AFAIK no, they just did a full transmission flush. sounds like there's actual warranty service procedures for the specific problem I had written up by corporate, and replacing the VB isn't part of it.
post #10 of 41 Old 04-10-2013, 02:49 PM Thread Starter
chargermaxx
Senior Member
(Thread Starter)
Well I'm hoping they don't take it apart and notice the bracket is broken and have to hold it up to order that in as well. Unless the VB assembly comes with the bracket.
Maybe due to the check engine light code there is a different service procedure who knows...
  Dodge Charger Forums > Dodge Charger Models (2011 - Up) > Charger Problems/Assistance (2011 +)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
"06 Charger SE 3.5" CEL P2767 & P0700 Part NUmber for Valve Body? 87vertgt General Charger Discussion 0 07-06-2012 01:01 PM
2012 Chrysler 300, Dodge Charger Get 8-Speed Transmission, 31-MPG AutoGuide.com Dodge Charger News 3 09-14-2011 08:05 AM
Short Runner Valve. What Is It & Have You Replaced Yours? DaBlackPearl V6 Specific Discussion 29 08-11-2010 01:22 AM
Bad body valve on 06 charger? trez Charger Problems/Assistance 21 10-01-2009 03:24 PM
2006 3.5 Charger SE with 38,000 miles needs new Valve Body wado1 Charger Problems/Assistance 15 10-14-2008 08:04 PM
You may post new threads
You may post replies
