Winter MPG on 2006-up 5 spd 5.7 Chargers? - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
  #1
Old 02-26-2013, 08:49 AM
Cruel Intentions Cruel Intentions is offline
Senior Member
Okay, looking to compare MPG notes with other 2006 & up 5 spd 5.7 ltr Dodge Charger owners. I have noticed a significant change in MPG since the gas changeover from summer to winter gas and since the weather change in October. So I wanted to find out what other owners are getting.
Year: 2006
Fuel being used: 87 octane
Current Mileage: 57,000
Type Of Tires being used: Winterforce Snow
Current Driving Pattern: city 30% hwy 70%
Current MPG average "actual" (not computer computed): 14.0 MPG
  #2
Old 02-26-2013, 09:54 AM
Jonny's Avatar
Jonny Jonny is offline
Senior Member
Lifetime Supporting Member
My Charger: 2010 Charger R/T
Usually get 20mpg
The winterForce tires, same as mine, are killing your mileage.
I'm getting 15.
It is more the tires than the gas, but the gas has an effect too.
I've switched over the tires and noticed an immediate improvement with the same tank of fuel.
__________________
I am the Stig
2010 R/T DWBlue, 2800 PI stall, Homemade CAI, JBA headers and mids, Flowmaster catback, Custom tune by Diablotoona, 180 T-stat, 3.06 rear gears.
  #3
Old 02-26-2013, 03:34 PM
MoparRT's Avatar
MoparRT MoparRT is online now
Senior Member
My Charger: 2006 R/T Black
I use 93 octane and I get a solid 18.5mpgs with the stock goodyear tires on it. 26k on the clock.
Just put in an octane boost with my last full tank of 93. I would never put 87 in my tank. Honestly I would never put in lower than 91. It comes out to be a $2-$4 difference between a full tank of 87 compared to a full tank of 93.
__________________
Debadged/Demolded. Tinted Tail Lights/Corner Markers. Superchips Flashpaq Performance 91 Tune. K&N Drop-In Filter. AACStyle Amber Colored CCFL Oracle Halos. Blacked out Grille. Custom R/T Grille Badge. Hurst Shifter. BT Oil Catch Can. BT Hood+Trunk Badge. Blastin Bobs 5db Resonator Delete Mandrel Bent w/SSR Tips.
  #4
Old 02-26-2013, 04:39 PM
Jonny's Avatar
Senior Member
Without a tune you are not doing any good using anything above 89. (It will actually give you less power and MPG using a higher octane than needed)
As far as the octane boost, what are you hoping that will do?
Very few of them raise the octane more than a few points. A point is .1 octane, so using a booster that raises the octane 5 points may take you fuel from 91 to 91.5 They put some harmful stuff in most of those, too.
I was running 87 with a tune for 87, in my area the price differential has been more like $8/tank between 87 and 93. Finding 91 around here is rare. 87, 89 and 93 predominantly are what's available.
Switched over to my 93 tune today.
__________________
I am the Stig
  #5
Old 02-26-2013, 05:15 PM
MoparRT's Avatar
Senior Member
Re: Winter MPG on 2006-up 5 spd 5.7 Chargers?
The manual right in your glove compartment suggests no lower than 89 octane fuel. That being factual, in my life I've been taught "high performance" vehicles call for high performance care. Which is why we run Synthetic Oils, or some members of the forum run the ACES fuel addatives.
It's just common practice for me, my family has owned powerful V8's forever. If the fuel is finer (thinner?) then naturally the gas will be of better quality and won't gunk up injectors and will burn cleaner providing better throttle response and more power. 93 with an octane boost is to clear the system because there isn't a higher octane available than 93, except close to racetracks.
It's more important WHERE you get your fuel rather than WHAT fuel you get. ExxonMobil and Shell are the best places. So my answer why run 93... For overall performance and health of my car, so it lasts longer.
That's just my opinion, you don't have to agree with it, I'm alright with what I'm doing.
Sent from my DROID X2 using AutoGuide.Com Free App
__________________
  #6
Old 02-26-2013, 08:05 PM
Jonny's Avatar
Senior Member
Read your manual again. It says 87 is acceptable, 89 preferred.
The following is my opinion, based on experience:
Synthetic oil is no better than dino oil, this, based on years of having used oil analysis done with all kinds of oils. Walmart conventional "Supertech" is the cheapest oil you can buy, and performs remarkably well past 6k miles in my car. I generally use a full synthetic, for about 8k+
Fuel additives: The manual states not to use fuel additives. Many high performance publications, (That aren't benefiting from the makers of such product i.e. sponsorship/advertisement/partnerships) that additives are a waste of money and generally do more harm than good. No comment on the ACES other than I've tried it myself... I no longer use it.
Octane has ZERO relationship to cleaning ability. It is a measure of the resistance to detonate/knock. The higher the compression ratio, the higher octane you need. If you advance spark timing, you effectively increase compression ratio (not mechanically), and require a higher octane. (No need for high octane in our cars without a tune)
Higher octane fuel burns slower, which is basically how it resists detonating... without the higher compression, it may not fully burn, so you actually get less MPG and less power running too high of an octane fuel....
You live in NY, just like I do. NY years ago mandated all grades of fuel carry detergents. Used to be you only got that with premium, which is why all the "oldtimers" think you NEED premium, when they may not.
2006 LX/Charger manual, page 241:
"The 3.5L and 5.7L engines are designed to
meet all emissions regulations and provide
satisfactory fuel economy and performance
when using high-quality unleaded
gasoline with an octane rating of 87 to 89.
The manufacturer recommends the use of
89-octane for optimum performance. The routine use of
premium gasoline is not recommended. The use of
premium gasoline will provide no benefit over highquality
regular gasoline or mid-grade gasoline and in
some circumstances may result in poorer performance.
__________________
I am the Stig
  #7
Old 02-26-2013, 11:09 PM
Yuro's Avatar
Yuro Yuro is online now
Senior Member
My Charger: TorRed 2007 RT
I have noticed a drop in my mpg with winter fuels
Year: 2007 5.7
Fuel being used: 89 octane
Current Mileage: 55,000
Type Of Tires being used: Michelin MXV4
Current Driving Pattern: Town driving 100% (not city not highway)
Current MPG average on EVIC: 13.7 MPG
I like to use Autostick at times and enjoy my rides, so I guess you can call it a bit of spirited driving.
__________________
'07 Charger RT
TorRed or NoRed!
K&N CAI + crankcase filter(baby Spectre cone air filter)
Stock-like
  #8
Old 02-27-2013, 12:29 AM
iamstubb's Avatar
iamstubb iamstubb is offline
Senior Member
Winter fuel mileage drop would more likely be related to the blending in of ethanol. In my 3.6 I have also seen a difference on the same tank of gas, no mods, or fancy stuff, with decreased temperature. Happens also with mods and fancy stuff, so I think it has something to do with the fuel trim and a big temp swing.
__________________
2012 SXT V6/8SPD Sport Package
Performance: Rear Stabilizer/Mopar CAI/Quantum Blue/ACES IV
Exterior: Mopar Caliper Covers/Mopar Chin Spoiler/Rear Spoiler
Interior: Alpine 276 watt amp with Infinity Reference 3032 Dash 3.5", Infinity Reference 9632 Door/Rear Deck 6x9"
  #9
Old 02-27-2013, 01:59 AM
Patriot Infinity's Avatar
Patriot Infinity Patriot Infinity is offline
Senior Member
Send a message via Skype™ to Patriot Infinity
What manual are you reading? The 5.7L hemi was optimized for 87-89, or it wouldn't say it in the manual.
__________________
2008 Dodge Charger R/T w/R&T
  #10
Old 02-27-2013, 08:29 AM
MoparRT's Avatar
Senior Member
Honestly I switch between 91 or 93 depending on if the station I'm at carries 93 (Shell does). But the reason for that is Regular: 87[$3.99], Premium: 89[$4.19], Super: 91[$4.39], Shell V-Power: 93[$4.41]… Prices are pretty close and it will save me from having to use high octane later mileage wise.
When I used 87 in my last Hemi, it dealt with it okay, but it felt resistent a lot of the time. I can literally 'feel' the difference between Regular and Super. Explain how I lose power by using a fuel that I've experienced more power using, please.
Also, with my last hemi I saw no change in MPGs using 93 compared to 87 or 89. That was a comparison Stock and with my Tuner on "Tow/Hall, Performance 91, 87 and Mileage XS" using different types of gas from mom+pop stations, to Stewarts, to Shell, to Sunoco, to Xtra Mart. And my conclusion was... 91-93 octane from Mobil(i.e. Xtra Mart) and from Shell gave me the most responsive throttle, the most power and no difference in gas mileage. So, I will not be swayed to use a lower grade of fuel. It works for me and I don't have a problem being alienated for it. You use what you use, I'll use what I use fellas.
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Winter is now officially over. What are your plans for your Chargers R/T MUSCLE General Charger Discussion 23 10-14-2012 01:06 PM
So how many RWD chargers are braving winter? Requiem478 General Charger Discussion 191 02-24-2012 05:47 AM
RWD Chargers and winter driving atvman General Charger Discussion 48 03-27-2011 07:22 PM
Winter and Chargers don't mix......ouch ! namgel General Charger Discussion 8 02-05-2007 09:12 AM
Winter mod for our Chargers..better than AWD devicespy General Charger Discussion 1 03-18-2006 12:58 PM
© AutoGuide
