having a major issue after installing a battery, please help...... - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 01-28-2013, 10:27 AM
leifo leifo is offline
Junior Member
I jus want some advice from you guys in hopes of it being a simple fix, which I doubt, I have an 06 r/t charger so heres my issue I jus put my new battery in and when I started the car and drove it most of my lights on the dash would stay on the,brake, abs, check engine light seat belt, esp bas, and none of my blinkers work, and it wont switch from 1st gear and I can't manually shift gears eigher hope you vuys can help thx in advance
  #2
Old 01-28-2013, 10:37 AM
Ddaddy's Avatar
Ddaddy Ddaddy is offline
Senior Member
Disconnect both terminals from the Battery and wait a good 5 minutes before reconnecting. Make sure the cables are clean and you tighten them well. Connect the ground cable first and make sure the car is off and key removed before diconnecting/reconnecting.
__________________
2006 Inferno Red SRT-8
Option groups I, II, & III + Sunroof
Built Thursday February 23, 2006
Triple A Performance (AirFunnel, AirHog, Aces IV)
QuantumBlue Custom Blended Oil (Yeah, it's that good)
I will drive her until one of us dies! 1/4 mile: 13.388 secs@105.75 mph
  #3
Old 01-28-2013, 11:53 AM
Junior Member
Thx for the tip but still the same thing
  #4
Old 01-28-2013, 10:45 PM
Scottwoos06RT's Avatar
Scottwoos06RT Scottwoos06RT is offline
Senior Member
YES. DO this , BUT...... after battery disconnect. Turn Key to ON. Leave for 30 sec. Turn OFF and REMOVE key. Wait 5-more min. Then connect Battery. Give it 2-minutes (at Least)....... Turn the key, Software will take 30-40 seconds to reboot, Wait till wee lil
DAYTONA symble shows and then give er a ful turn to start.
IF that doesn't do it....... I'll be damned.
Cheers Mate
__________________
[SIGPIC] Original Order # 96 out of 200 (canadian) 40K miles (total) , 20K on the "Re-build".... am gettin' buried in this car...AFE Stage II CAI, SRT Hood , MOPAR PERFORMANCE: Headers/Catback/P.PHeads/Comp Cam 273 / -diablo CMR tune. MOPAR TQ 2800,Steel forged Rotating Assy-internals (Mopar) Manley Forged Pistons/ line bored/balance & BP Printed /KW V-2 Coil-Over Susp. w/MOPAR Perfomance F&R sway-bar (EIBACH) / Borla Exhaust LT headers (mopar)/DMH E-Cutouts
Baer 6 piston X-treme , Franks coatings on all. Line-Lc Twin Roots S/C in a Box.... going on later this spring.Unofic'l/ Air clocked @ 174.37MPH :l
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Major maintenance issue H-TX Charger Problems/Assistance 28 08-03-2012 01:31 PM
Battery Light/Battery Problem stxangler Charger Problems/Assistance 6 08-14-2011 08:41 AM
Battery / Voltage issue...HELP Rodge Charger SRT-8 Discussion 10 06-02-2011 10:16 AM
© AutoGuide
