"Battery Saver Mode"...??? - Dodge Charger Forums
post #1 of 21 Old 01-23-2013, 07:20 PM Thread Starter
Elmer Fudd
Senior Member
Elmer Fudd's Avatar
(Thread Starter)
At least a week ago I noticed this email like icon on the information display. I thought it had to do with the Bluetooth or something. I finally figured out it was a message that reads "Battery Saver Mode".
It will not clear, been on constantly at least a week and a few hundred miles - no symptoms. Battery seems strong...cranks right up even when 30 degrees...
Ill show the dealer soon when I get the two new front wheels.....any hints as to what this is?? One of the few things these cars seem to lack is an ammeter...
Elmer
2013 Charger RT
2011 GMC Terrain SLT
2005 GMC Yukon
2003 GMC Sierra
Elmer Fudd is offline
post #2 of 21 Old 01-23-2013, 07:56 PM
lg68jcu
Senior Member
I was going to post this same subject. It's been 0-10 degrees for a few days and I have been using the remote start more. Like you the one day I had a message and sure enough it was the battery saver mode. I did just get the message once this was 2 nights ago. I did not get it today. My guess is its just minimizing power so the battery can recharge quicker with the alternator due to extra drain on the battery. Just taking a guess here
I have a 2013 AWD RT
lg68jcu is offline
post #3 of 21 Old 01-23-2013, 08:01 PM Thread Starter
Elmer Fudd
Senior Member
Elmer Fudd's Avatar
(Thread Starter)
lg, I'm betting that this is some fancy computer controlled setting that is glitchy...
Think about it....370 hp and Dodge couldn't simply put a bigger alternator on the car??
But I have been using the remote start a lot. And on another forum I noticed folks tying the remote start to this message. I'll not use the remote a few days and see if it clears.....
post #4 of 21 Old 01-23-2013, 08:39 PM
Ddaddy
Supporting Member (Lifetime)
Ddaddy's Avatar
Garage
The message is due to low battery voltage. The link to remote start seems coincindental since it's usually only employed in very cold weather.
The root cause appears to be a bad alternator (factory defective) that isn't charging the system properly. Several have fried and at least one customer had it catch fire.
The system is designed to reserve enough power to start the vehicle and doesn't let you run the ancillary systems and draw the voltage down below an acceptable "start" charge. The issue appears to be that the system isn't recharging the battery enough and the "battery saver" program is kicking in.
Now that it's cold enough to expose this issue, expect a TSB from Chrysler soon.
2006 Charger SRT-8
1969 Dart GTS 340
2012 Chrysler 300C Hemi
All V8 Mopars!
Ddaddy is offline
post #5 of 21 Old 01-23-2013, 08:44 PM Thread Starter
Elmer Fudd
Senior Member
Elmer Fudd's Avatar
(Thread Starter)
DDaddy that makes sense....
Now that you explain it that way, it does seem like sometimes the seat heaters are very slow to work and other times they fire right up......that could be the system activating....
I will be at the dealer in a few days anyway getting 2 new wheels, they can check the alt.
thanks much
post #6 of 21 Old 01-28-2013, 04:08 PM Thread Starter
Elmer Fudd
Senior Member
Elmer Fudd's Avatar
(Thread Starter)
UPdate
Dealer checked system......bad alternator.....ordered a new one.
post #7 of 21 Old 01-31-2013, 05:52 AM
Fudge
Fudge's Avatar
Send a message via AIM to Fudge
Quote:
Now does this make the car more "interesting" to drive knowing it may spontaneously combust on you?
But on a more serious note..... this battery saver mode is this only on the new chargers or do the older styles have it also?
~2013 Mustang GT (Deep Impact Blue)
-2009 Dodge Charger R/T Daytona 364/400 (SOLD ... and missed)
Fudge is offline
post #8 of 21 Old 01-31-2013, 11:02 AM
lg68jcu
Senior Member
Yikes! Looks like I might be taking her in to get a new alternator. Thanks for the posts and info.
lg68jcu is offline
post #9 of 21 Old 01-31-2013, 05:08 PM
zoomzoom1
zoomzoom1's Avatar
OLder Gens don't have this option......
2006 Top Banana #3033-4000..Arrington Heads and Crazy Spartan Cam..LSA114.Mopar CAI, Mopar LT's w/Hi-flo's ..Mopar/Borla 125 Cat-bac. EForce supercharger by Edelbrock Mopar stage one Lowering springs, KONI STR shocks.Custom Dyno-tuned by Brent at DTP Racing..500rwhp..490rwtqe..QB oil..Aces Fuel..P/S additive'
2006 INFERNO RED SRT8..Mopar CAI 180stat..Custom Tuned by BRENT at DTP..402rwhp..398rwtqe
Roanoke Valley Mopar Club/Classic and Modern Mopars...
zoomzoom1 is offline
post #10 of 21 Old 01-31-2013, 07:24 PM
Fudge
Fudge's Avatar
Quote:
O ok, thought this seems like good idea, makes the car more idiot proof for the general driver.....if they pay attention to the dash lights!
Fudge is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Installed new battery "ESP BAS" & "ABS" light won't go off. DeeMan75 Charger Problems/Assistance 28 08-25-2011 12:19 PM
Reset "adaptive learning/drive mode" for more MPG! white06r/t General Charger Discussion 27 12-13-2009 08:25 PM
Do chip mods affect/disable "Fuel Saver Mode" riannapo Performance Discussion/Modifications 3 06-26-2007 11:20 AM
Help!!! - 2nd try Was ESP the problem? "Limp home mode" Charger RT Owner Charger Problems/Assistance 1 11-12-2005 02:38 PM
You may post new threads
You may post replies
