2013 Charger SRT Launch Mode - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger SRT-8 > Charger SRT-8 Discussion
  #1
Old 01-17-2013, 04:12 AM
ChargerVA's Avatar
ChargerVA ChargerVA is offline
Member
Exclamation 2013 Charger SRT Launch Mode
For the life of me, I cannot get my 2013 Charger SRT to kick into launch mode. I have hit the ESC button twice on the center console, only to have it turn off ESP and turn it back on. Am I missing something? Hitting the wrong button? Was there a system update that I missed?
__________________
'13 Charger SRT8 Pitch Black, HID Package. Working on the rest!
  #2
Old 01-17-2013, 04:26 AM
WhiteChargersrt8 WhiteChargersrt8 is offline
Senior Member
Same here man. Mind doesn't have it ether. I think they didn't put it on the first 2013 srt's. Wonder if there is a add on to the 2013's that dont have it.
  #3
Old 01-17-2013, 04:55 AM
ChargerVA's Avatar
Member
I have heard that there is a update that needs to be done in order to enable it, but that was only with the '13 Challies... I haven't seen anything on the '13 Chargers..
Any idea on how to pull up the version ID of your car? I guess I need to make a trip to the dealership... Ugh..
__________________
  #4
Old 01-17-2013, 07:20 AM
SlowLNF SlowLNF is offline
Junior Member
Manual says its not unlocked until after 500 miles. Are you guys past that point?
  #5
Old 01-17-2013, 07:25 AM
Bigcountry's Avatar
Bigcountry Bigcountry is offline
Senior Member
When you say "launch mode" are you referring to turning the esp completely off? I am assuming that the new SRT's still function like my 07, meaning one press of the button turns it partially off, while holding the button for 10 seconds or so while still in PARK will bring up the dings and turn the esp system off. Things could have changed, but that's how the older ones work. There's also the old trick of while at a stop or gently rolling, turn your key as if starting the car. The radio, warning lights and all will cut off momentarily (starter won't engage) and then you are in full off mode. Again, this works on the earlier models, can't guaranty it on yours. Maybe someone else has tried it on the newer ones and will speak up.
__________________
'07 Torred SRT-8. All options except rear video. K&N CAI, 180 Jet T-stat, Diablo Equiped, B/T Catch Can, 35% Tint, Super 10's with Reso Delete , Custom Graphics by Signs and Designs of Asheboro.
  #6
Old 01-17-2013, 07:53 AM
ChargerVA's Avatar
Member
Here's what it is:
"A new for 2013, standard launch control system helps maximize straight-line acceleration.
When the vehicle is at a complete stop, the driver engages the system by pressing the ESC button twice and then with their foot securely on the brake, quickly applies full throttle. Launch control holds the engine at optimal launch rpm (1,825) and waits for the driver to release the brake. Launch control then uses engine torque management to achieve controlled wheelslip for maximum acceleration up to 62 mph (100 kph). "
According to SRT, it should display it up on the dash, letting you know that it is indeed engaged.. Though i have hit that button till i got "Pac-Man" thumb, and it still isnt working.
__________________
  #7
Old 01-17-2013, 08:15 AM
Junior Member
Quote:
Originally Posted by ChargerVA View Post
Here's what it is:
There's also a Yellow sheet that comes with your manual. It explains exactly how to engage the Launch Control, and that it is not available for the first 500 miles of the vehicles life.
  #8
Old 01-17-2013, 11:42 AM
ChargerVA's Avatar
Member
Waaay past the 500+ mile point, unfortunately. I will double check the manual on that "Yellow Sheet". Maybe the dealership skimped on mine...
__________________
  #9
Old 01-17-2013, 08:20 PM
MuscleCar's Avatar
MuscleCar MuscleCar is offline
Senior Member
Vehicles built prior to 12/2012 are not equipped with this feature. Engineering is currently working on a fix for this concern.
__________________
2012 Dodge Charger R/T Road & Track, Super Track Pak, DiabloSport 91 Tune, Borla S-Type Exhaust, BT Catch Can, K&N Filter, Serious Metals Strut Bar
  #10
Old 01-17-2013, 09:35 PM
TNCHARGER TNCHARGER is offline
Senior Member
My Challenger was built Nov 23 and has Launch Control as another member's Challenger that was built a couple weeks before mine....so the "rumor" I keep seeing posted that cars built before Dec 2012 are wrong......that said, you need to read this thread from another forum...will answer all your questions.. http://www.lxforums.com/board/f155/2...ontrol-318192/
__________________
..2013 Challenger SRT8...dressed in black.....
Tags
launch mode, srt 8
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
2013 Launch control?? Cuts2TheBone General Charger Discussion 3 10-25-2012 04:46 AM
2013 Viper GTS Launch Edition Revealed AutoGuide.com Off-Topic 3 08-17-2012 09:55 PM
Forget manual mode, give me a sport mode! MCaesar Charger SRT-8 Discussion 40 02-12-2006 02:48 PM
New Charger launch date? Mark Ebert Picture/Media Post 0 10-21-2004 02:52 AM
New Charger launch date? Mark Ebert General Charger Discussion 0 10-20-2004 06:36 PM
© AutoGuide
