blacktop 3.06 rear axle ratio on the HEMI - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
  #1
Old 01-12-2013, 01:11 PM
djtuzik djtuzik is offline
Senior Member
For all the blacktop hemi owners
215MM Rear Axle and the 3.06 rear axle ratio, what kind of MPG effect does it have? Are the RPMs much higher? is it annoying?
  #2
Old 01-12-2013, 02:51 PM
Colts&Glocks Colts&Glocks is offline
Member
You are correct with regards to higher RPM's. Also, as you assumed gas mileage will suffer. Is it worth it for you to pay for parts and labor, and to get your pcm reprogrammed for the new gears? 0-60 times will be an ever so slight improvement over 2.65's. Again, do you think it's worth it? I don't. Just my opinion...
  #3
Old 01-12-2013, 03:01 PM
Senior Member
research
Quote:
How much does that cost?
I just read up on it, the higher RPM are offset by tire size. So the reason why the blacktop package comes with the higher ratio, is because the tires are larger.
looks like gas milage is going to be very similar unless I put 18 inch tires on.
  #4
Old 01-12-2013, 03:15 PM
Member
How much exactly I don't know. I'd say at least an EASY $500 at a wishfull minimum. I'd believe if you went ahead and did it you'd most likely regret it, as you'd see very little performance gain, and smaller mpg's and perhaps higher engine wear.
  #5
Old 01-16-2013, 01:52 PM
michiganpat's Avatar
michiganpat michiganpat is offline
Senior Member
no, tire diameter is essentially the same...stock 235/55R18's are 28" tall, stock 245/45R20's are 28.4", so with the same gearing and RPM, speed will be off by approx 1.4%
__________________
'11 Toxic Orange Charger R/T
'06 Dodge Grand Caravan
'76 Plymouth Duster
  #6
Old 01-16-2013, 07:11 PM
Stevens12's Avatar
Stevens12 Stevens12 is online now
Senior Member
I have the 3.06 gears and I consistently get 17-18mpg mixed and 24-25 mpg highway.
__________________
Mopar Chin Spoiler
Super Track Pak black Grille
20% window tint
MKW M102 20" Black w/Machine face, Toyo ST-II 255/45r20
  #7
Old 01-16-2013, 08:35 PM
mblock66's Avatar
mblock66 mblock66 is offline
Senior Member
My Charger: 2013 R/T R&T STP
Quote:
I will be getting them in the car I order this week. Road and Track with the Super Track Pack.
The 3.06 gears will be good for about 2 tenths to 60 and maybe 3 in the quarter. MPG should be barely suffer.
To me they will have more jump across the RPM range and are VERY worth it to me. Gears are literally the best mod you can do for these muscle cars as far as raw performance.
3.06 is still pretty mild but stock for stock will pull away from a 2.65 R/T all day
  #8
Old 01-17-2013, 05:26 AM
wadisr's Avatar
wadisr wadisr is offline
Senior Member
My Charger: Brilliant black crystal pearl 2011 charger R/T Plus
Has that been tested? depends on the driver I think..
__________________
2011 Charger R/T plus,HellBoy Red interior,20% tint,modern muscle billet catch can,K&N drop in filter,R/T Heritage emblems,mopar chin,matte black grill. (purchased 8/2/11)
2013 Dart Rallye, all options except sunroof (purchased 12/19/12)
RETIRED...2006 Charger R/T, 22" Maas rims, Nexen 265/35 R22 tires, L.E.D tinted color matched tails, Luminics head & fog lights,20% tint, K&N CAI ,modern muscle billet catch can, diablo 93 octane CAI tune, Flowmaster 44/4" tips, matte black spoiler,blacked out trunk,matte grill,mopar chin,HEMI tattoos.
  #9
Old 01-17-2013, 05:40 AM
Jonny's Avatar
Jonny Jonny is offline
Senior Member
Lifetime Supporting Member
My Charger: 2010 Charger R/T
I went from 2.65 to 3.06
You will likely be disappointed, as I was.
3 tenths? No way that will happen, I don't think I saw a full tenth improvement, and I tracked it pretty regularly.
__________________
I am the Stig
2010 R/T DWBlue, 2800 PI stall, Homemade CAI, JBA headers and mids, Flowmaster catback, Custom tune by Diablotoona, 180 T-stat, 3.06 rear gears.
  #10
Old 01-17-2013, 06:04 AM
Senior Member
you have to remember the tranny gearing is very deep, with first being 3.59:1, and OD only being .83....
dunno how much it'll be worth, as I've seen guys reporting stock regular r/t's running the same/similar times (13.5-13.7) as most published reports of R/T R&T with 3.06's...
__________________
'76 Plymouth Duster
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Hemi Rear Axle & Suspension Links 13K miles Suspman Parts For Sale/Wanted 2 12-08-2009 08:57 AM
changing rear axle ratio to 3.03 with the diablo pete R/T Performance Discussion/Modifications 18 04-28-2009 07:32 AM
2006 Dodge Charger Hemi SRT/8 Rear Axle Bremo Brakes 425hp Parts For Sale/Wanted 3 10-14-2006 12:44 PM
Charger R/T rear axle ratio change Ric232 General Charger Discussion 6 07-27-2005 07:57 AM
Difference between final drive ratio and rear axle ratio? Stonebreaker General Charger Discussion 34 07-16-2005 07:38 AM
© AutoGuide
