Interior Clicking Noise - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > Interior Discussion/Modifications
  #1
Old 01-11-2013, 09:25 AM
mangort17 mangort17 is offline
Junior Member
My Charger: 2006 Daytona
I have an 06 Daytona. I have been experiencing a rapid "clicking" noise coming from the dashboard on an intermittent basis. It usually lasts about a minute and then stops. It will also usually stop when I turn off the fan motor although it has happened once or twice when the fan was off. It also appears to be somewhat linked to outside temperature as it did not happen for about two weeks when temp was in 30's. It has happened a couple of times the last few days, temp around 50 car sitting in sun. The dealer has replaced the fan motor but that did not solve the problem. The car is still under warranty but expires in Feb and would like to have some ideas when I bring back to dealer.
  #2
Old 01-20-2013, 07:58 PM
MotoAce51's Avatar
MotoAce51 MotoAce51 is offline
Senior Member
Does it stop if you hit REC air? Has anything fallen in the vents?
__________________
2006 Charger R/T
- Carbon Fiber LMI Hammer Intake - Boss 22's - Blastin' Bobs 7db Reso Delete - Tranzformer Shift Kit - K&N CAI - DiabloSport - inTune CAI Tune - BT Catch Can - Tinted Marker's - 10000K HID - Halo & LED Headlights - CF Vinyl Dash & Door Pillar Overlay
  #3
Old 01-23-2013, 11:56 AM
Junior Member
I have not tried the "REC" button. It will almost always stop if I shut the fan however there have been a couple of times it kept going. It has not happened since the weather turned cold, last time was a few weeks ago on 50+ degree day.
  #4
Old 01-23-2013, 02:57 PM
MotoAce51's Avatar
Senior Member
The more I think about it the more I am thinking its nothing more than annoyance. Its probably the fan out of balance and touching the side, or the bearing is loose. My Vibe makes a high pitched whistling noise. You really notice it in the lower speeds. The only thing you can do it try taking it apart or try to live with it. Neither is really easy.
__________________
2006 Charger R/T
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
clicking noise while driving NetRang3r Charger SRT-8 Discussion 7 07-13-2011 06:45 PM
clicking noise shaleempr/t Charger Problems/Assistance 1 05-26-2011 09:18 PM
clicking noise from transmission box mbp Charger Problems/Assistance 2 10-16-2010 12:24 PM
Clicking noise at WOT! mcshocks Performance Discussion/Modifications 1 04-16-2007 08:17 PM
Clicking Noise after starting ChargerS.X.T Charger Problems/Assistance 2 04-03-2007 08:22 PM
© AutoGuide
