Rifled throttle body - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > Performance Discussion/Modifications
  #1
Old 01-10-2013, 08:23 AM
Daytona#2103's Avatar
Daytona#2103 Daytona#2103 is offline
Junior Member
So my friend and I were talking about guns and our cars and it got me thinking. Would I be possible to rifle out the throttle body? Kinda like a TBS but its the throttle body itself. Wonder if it would work.
__________________
2006 Daytona Top Banana #2103. K&N CAI, GTS head and tail light covers, shocker TRAIN HORN, tail light hide-away strobes, grill strobes, red led footwell lights, 25% tints back and 30% in front.
  #2
Old 01-10-2013, 08:32 AM
Hriv's Avatar
Hriv Hriv is offline
Senior Member
My Charger: 2008 Charger R/T
Wouldnt that be adverse to performance?
The rifling would induce a swirl into the flow of air in and make it more turbulent?
On our helicopters engines (atleast the 701Ds in our H-60s and H-64s) there are de-swirl vanes forward of the compressor blades to straighten out the flow and make it less turbulent to improve compression. IE the same effect as an CAI.
Sent from my "HD" Pantech Breakout using the free version of AutoGuide
__________________
Current: Blaze Red 2008 Charger R/T
Previous: Steel Blue 2008 Charger SE. Traded in and missed.
U.S. Army 15F Aircraft Electrician
South Korea: '07-'08. Iraq: '08-'09. Afghanistan: '10-'11, and another currently going on.
  #3
Old 01-10-2013, 08:48 AM
Junior Member
Re: Hriv
I don't know. It was just a thought that's been stuck in my mind for a few days.
But shouldn't it act like a TBS. I know the point of the air swirling a TBS causes is for better fuel/air mixture for better combustion.
__________________
  #4
Old 01-13-2013, 10:27 PM
DEVILS CHARGER's Avatar
DEVILS CHARGER DEVILS CHARGER is offline
Member
My Charger: 06 Charger R/T
That in my opinion is a bad idea. Messing with the throttle body can really mess up the air/fuel ratio. Try this link, even though it's a tbs it might be something you're looking for. I bought one for my r/t, I noticed a different between 2-5k rpms, and then when I installed my tuner, I was able play around with the air/fuel ratio and I noticed a positive difference with the entire rpm range.
http://www.taylorvertex.com/Products...elixPowerTower
  #5
Old 01-14-2013, 07:45 AM
Hriv's Avatar
Senior Member
I standcorrected
__________________
  #6
Old 01-14-2013, 08:49 AM
Junior Member
I know it was just a thought. Not actually gonna do it. Thought it'd be cool if it worked.
__________________
  #7
Old 01-14-2013, 10:34 AM
Jonny's Avatar
Jonny Jonny is offline
Senior Member
Lifetime Supporting Member
My Charger: 2010 Charger R/T
You want straight flow until just before the fuel is introduced... TB is a long distance from the injectors.
__________________
I am the Stig
2010 R/T DWBlue, 2800 PI stall, Homemade CAI, JBA headers and mids, Flowmaster catback, Custom tune by Diablotoona, 180 T-stat, 3.06 rear gears.
  #8
Old 01-14-2013, 11:36 AM
hskr's Avatar
hskr hskr is offline
Senior Member
Send a message via AIM to hskr Send a message via Yahoo to hskr
There is absolutly zero purpose behind swirling the air coming through the throttle body whether the TB is "rifles" or you use one of the pointless TB spacers. The whole concept of improved a/f mixture is outdated and really only applies to carbs or throttle body injection set ups. With modern multipoint fuel injection, even if you swirled the air coming through the TB, it has to make several turns prior to reaching the point where the fuel injectors sit there by negating any positive effect the swirling air may have had on fuel atomization as the air will no longer be swirling by that point.
It's nothing but a marketing ploy to get ignorant people to waste money on TB spacers and tornado fuel savers and any other product that supposedly helps a/f by swirling the air.
__________________
Brian
'08 Cool Vanilla SE+
'00 Dakota R/T
  #9
Old 01-15-2013, 11:17 AM
Hriv's Avatar
Senior Member
So I was originally right? -face slap to self-
__________________
  #10
Old 01-19-2013, 12:20 PM
04goat 04goat is offline
Member
It made a difference when i sanded down the outer lip of my tb on my gto. it has better throttle response. as long as you stay back away from the throttle flap it will not harm the idle. my gto has been modded like this for nearly 110,000 miles. and no problems.
__________________
04 gto 6sp yj, p/tb,tb bypass,160 * thermostat,pacesetter longtubes,tsp torquer 2 cam package, fully custom built 3 1/2 " exhaust, 238/248@50 600/605 lsa 112 n/a, custom tuned by andrea at abel raceing best et on dr's w/slipping clutch 12.70 @ 109, new times to come with the ls7 clutch
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
90 mm Throttle Body PureAmerican Performance Discussion/Modifications 18 04-16-2012 01:45 PM
ported throttle body installed and now Electronic throttle control light blinks jimmirehman Charger Problems/Assistance 1 04-30-2010 05:33 PM
WTB 5.7 throttle body ponch79 Parts For Sale/Wanted 1 03-09-2010 03:20 AM
Throttle Body?? sco_pet V6 Specific Discussion 197 04-16-2009 09:52 PM
New throttle body.. 1FST4DR Parts For Sale/Wanted 0 07-23-2007 12:50 PM
© AutoGuide
