LED tail/brake light bulbs don't work - Dodge Charger Forums
Exterior Discussion/Modifications Discussion of exterior modifications belongs in this section, even if the visual modification slightly affects performance (ie. spoilers, etc)
post #1 of 14 Old 01-07-2013, 09:29 PM Thread Starter
06MangoDaytona
Senior Member
06MangoDaytona's Avatar
(Thread Starter)
Angry LED tail/brake light bulbs don't work
So I went ahead and ordered all LEDs for my Mango. Brake/Taillight bulbs,Reverse lights.
I ordered them from superbrightleds.com and they got to my house very quick so as soon as I got them I was excited to install them so I took out my tail lights and swapped out the bulbs and turn the lights on and nothing talk about pissed off. Only the reverse lights work has anybody else had this problem because I'm about to send these back not happy
Gone but Not Forgotten 2006 Go-Mango Daytona 1-11-13
Current 2012 SRT8 Challenger 392
06MangoDaytona is offline
post #2 of 14 Old 01-07-2013, 11:18 PM
xkm121
Senior Member
xkm121's Avatar
Now slow down. When you say they dont work. Do you mean they dont light up? Or they dont flash?
Bitten By Mod Bug Again
xkm121 is offline
post #3 of 14 Old 01-08-2013, 04:14 AM
ColdSteel
Senior Member
ColdSteel's Avatar
LEDs are not like regular bulbs. They only work in one orientation. If you plug them into the socket and they don't light, take them out, rotate 180-degrees, plug back in and voila. If you do that and they still don't work, then contact the vendor.
2008 R/T -Demoulded, Debadged, Daytona grille, Predator
Mopar CAI, Tinted Windows SLP Loudmouth II, BT Catch Can, BT Shift Insert
Matte Black SRT Replicas - <tires worn out>
Stock wheels with Firestone Winterforce tires
ColdSteel is offline
post #4 of 14 Old 01-08-2013, 07:10 AM Thread Starter
06MangoDaytona
Senior Member
(Thread Starter)
They won't turn or blink and I tried turning them 180 degrees and still no luck
post #5 of 14 Old 01-08-2013, 07:37 AM
1stDodge
Senior Member
1stDodge's Avatar
Maybe you need a Load Resister??
I am interested in doing this also.
Turn signal issues with LED bulbs
LED brake/tail lamps will not flash with thermal flasher units due to their extremely low current draw. Also, with stock flasher units, the turn signals may flash faster than normal (Hyper-Flash) or trigger bulb-out indicator on dash. Some vehicles will also disable the cruise control system if a brake light bulb is being indicated as bad. These installations will require an electronic flasher unit, available in our car bulb shopping category (for some vehicles) or at your auto parts store. Flashers designed to work with LED bulbs will often say "LED compatible". HEAVY DUTY flashers may also work with LED bulbs.
We offer some LED Flashers but we do not know which one (if any) will fit your vehicle. You will have to compare the pin-out of your flasher with the pin-outs of the flashers we offer, to see if we have a match, BEFORE you order one. Sorry but we do not have a flasher application list or the expertise to tell you which of our flashers will fit your vehicle.
Another fix is the installation of Load Resistors which are wired across (in parallel with) the turn signal bulbs to simulate the load of a standard filament bulb. We also have these available in our car bulb shopping category
1stDodge is offline
post #6 of 14 Old 01-08-2013, 12:49 PM
xkm121
Senior Member
xkm121's Avatar
Chargers dont have flashers any more. You need to splice load resistors into the wiring.
xkm121 is offline
post #7 of 14 Old 01-08-2013, 02:30 PM Thread Starter
06MangoDaytona
Senior Member
(Thread Starter)
Ok are there any threads on here on how to do that and where is a good place to get them
post #8 of 14 Old 01-09-2013, 07:23 AM Thread Starter
06MangoDaytona
Senior Member
(Thread Starter)
I ordered load resistors so hopefully this will correct my issues. I ordered 4 of them for each LED is that correct?
post #9 of 14 Old 01-09-2013, 08:17 AM
stargazer747
Junior Member
stargazer747's Avatar
LED's are great!
I'm sorry to hear you're having issues with your led kits, not sure why they're not working for you. I have an '06 GoMango Daytona with lots of modded upgrades, one of the first thing I did was replace the factory exterior lights as they are typical and unappealing. I purchased the halo sets for the front, high intensity sidelights, smoked fogs, and leds for the rear and in under 1 hour with a friend I had all installed right from out of the box and with no issues or additional items required.
I would guess there is a wiring conflict somewhere? I am not an expert but my first thought would be a fuse popped or short in the wiring, etc. Question, if you were to but back the originals do they work?
GoManGo! 1219-4000
K&N Typhoon Cold Air In-take, JBA High Flow Shorty Headers, Magnaflow mid-pipes with off-road CATS, Magnaflow Cat-Back Kit, Rotora Big Brakes Kit 13" Drilled & Slotted with 6 Piston (front) 4 Piston (Rear) Red Calipers, ST Suspension High Performance Yellow Coilovers, Mopar Rallye Black Rims, Rear Diffuser, Halo Projection Headlights & Rear LED Taillights!
stargazer747 is offline
post #10 of 14 Old 01-09-2013, 08:19 AM Thread Starter
06MangoDaytona
Senior Member
(Thread Starter)
I know its a bummer for sure but to answer your question yes the stock bulbs work when I put them back in
  Dodge Charger Forums > Dodge Charger Discussion > Exterior Discussion/Modifications
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
LED replacements for OEM tail light bulbs DRAGULA Exterior Discussion/Modifications 1 03-17-2011 06:03 PM
Tail light bulbs wat u gon do? Exterior Discussion/Modifications 0 07-22-2009 05:42 PM
Brighter than OEM tail light bulbs Pyrate Exterior Discussion/Modifications 2 12-29-2008 06:42 PM
Brighter Tail Light Bulbs? killerbee88 Exterior Discussion/Modifications 20 05-15-2008 07:42 PM
How do I change tail light bulbs? TeeJizzle General Charger Discussion 9 08-25-2007 04:25 PM
You may post new threads
You may post replies
