O2 sensor problem!!! - Dodge Charger Forums
post #1 of 21 Old 01-07-2013, 06:16 PM Thread Starter
callmenice456
Junior Member
(Thread Starter)
i replace my o2 sensor,but my engine still is on and its throwing the same code, I was reading on a forum that it maybe a fuse, has anyone had this problem
callmenice456 is offline
post #2 of 21 Old 01-07-2013, 06:22 PM
rsoto80
Senior Member
rsoto80's Avatar
You have to clear it first to see if it comes back. Otherwise itll be stored in memory.
13.84@101 mph Gainesville Raceway
rsoto80 is offline
post #3 of 21 Old 01-07-2013, 06:27 PM Thread Starter
callmenice456
Junior Member
(Thread Starter)
yea I cleared it out, an its came right back
post #4 of 21 Old 01-07-2013, 06:43 PM
sconnell80
Senior Member
sconnell80's Avatar
What is the code that is coming up? Also what motor do you have? Need some more info to help you.
2006 Charger SRT8 Brilliant Black, Options I, II, III with Sunroof. AIR HAMMER CAI, DiabloSport Predator Perf 93 CAI Custom Tune, 170* Tstat, Magnaflow High Flow Cats, Custom Reso Delete w/4" SS Rolled Tips, Mygig RER Navi with Lockpick and Backup Camera, OEM Projector Headlights w/HID 5000K Low, High and Fog Kit, Full Interior Led Mod, 5% Rear Window-15% Front Window Tint, Tinted Tails and Front Turn Signals, Double Tail Light Bulb Mod, Front Turn Signal Mod, LED Reverse Lights, BT Satin Oil Catch Can, Polished SRT Rims
sconnell80 is offline
post #5 of 21 Old 01-07-2013, 06:48 PM Thread Starter
callmenice456
Junior Member
(Thread Starter)
bank 1 sensor 2 and I have the 2.7, I gotta get the code again
post #6 of 21 Old 01-07-2013, 07:03 PM
TripleTransAm
Senior Member
TripleTransAm's Avatar
If it's a bosch sensor you could be getting the "took too long to warm up" code. Seems Chrysler pcms are finicky about the brand of o2 sensor, at least on the hemis. Might be the same with the 2.7.
/Steve
1987 Pontiac Trans Am GTA
1998 Pontiac Trans Am WS6
1978 Pontiac Trans Am
1978 Pontiac Trans Am 4-speed SE
2006 Daytona R/T Tor-Red (59 of 200 - Canadian)
2016 Dodge Charger R/T R&T
TripleTransAm is offline
post #7 of 21 Old 01-07-2013, 07:05 PM
TripleTransAm
Senior Member
If sensor 2 is the after cat sensor then it could be an exhaust leak or failing cat.
post #8 of 21 Old 01-07-2013, 07:06 PM Thread Starter
callmenice456
Junior Member
(Thread Starter)
yea its a bosch sensor from auto zone, and the car runs alil different tho
post #9 of 21 Old 01-07-2013, 07:08 PM Thread Starter
callmenice456
Junior Member
(Thread Starter)
is there anyway to test for exhaust leak or failing cat?
post #10 of 21 Old 01-07-2013, 07:10 PM
sconnell80
Senior Member
sconnell80's Avatar
I have bosch sensors on my car both front and rear 02's and they are just fine. Some cars are different and some are touchy. If the code is P0420 or P0430 then that means your cat is not doing its job, or you could just have a bad sensor. Either way, change the 02 sensor or do a cheap mod to take care of it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
O2 Sensor CEL rtmadness Charger Problems/Assistance 1 07-23-2010 10:39 AM
Old truck occasional idle problem! Figure out problem pay pal you $10! ChargeRonDavinS Off-Topic 16 10-14-2009 04:08 PM
Cam Sensor Problem? OneBadChally General Charger Discussion 2 09-17-2008 10:33 PM
do anybody have this problem - no tire sensor still reading low gamova Wheels/Tires/Brakes/Suspension 4 01-07-2008 07:33 PM
Problem with tire pressure sensor??????? subliminal_hemi General Charger Discussion 22 11-04-2007 12:11 PM
You may post new threads
You may post replies
