Bigger amp - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > Audio - Alarms - Navigation - Electronics
  #1
Old 01-01-2013, 01:25 PM
Shawnlh's Avatar
Shawnlh Shawnlh is offline
Member
Bigger amp
First off, I tried searching, but I'm either unable to find what I'm looking for, or I don't know what I'm looking for.
I have a 2007 SRT8 Charger with options I, II, and III. H/U is the NAV with 6 disk changer. Has tweets in the dash, mids in the front doors, assuming 6x9's on the rear deck, and a factory square kicker sub. The sound is good, but I would like a little more power for a touch better volume.
The only thing I'd like to replace is the amp (or amps) if it has more than one. And perhaps even upgrade the sub but still use the stock enclosure as I need my trunk space.
Any thoughts?
Thanks
  #2
Old 01-01-2013, 05:06 PM
Part Deux's Avatar
Part Deux Part Deux is offline
Super Moderator
Lifetime Supporting Member
upgraded kicker amp will gain you a little more boost and quality.
__________________
Did you know that - Thread
How do I everything - Thread
aka THO.R
Quote:
Originally Posted by 08 Stoned Charger View Post
I have a name for the 3 new mods...............Druken Purple Pirates!!!
Quote:
Originally Posted by Daytona606 View Post
American Muscle, like a pit bull. Big but not large, well defined, explosive power, in it till the end. The cat will give it go and zig and zag, but in the end the pit bull will always catch the cat – the outcome is never good for the cat.
  #3
Old 01-01-2013, 05:12 PM
Shawnlh's Avatar
Member
Quote:
Link?
  #4
Old 01-01-2013, 06:15 PM
Part Deux's Avatar
Super Moderator
http://www.moparsupercenter.com/mopa...7kick18ab.html
__________________
aka THO.R
  #5
Old 01-01-2013, 06:22 PM
Shawnlh's Avatar
Member
Thank You
  #6
Old 01-01-2013, 07:04 PM
Shawnlh's Avatar
Member
One more question......
I went and checked the car, and the sub has it's own amp mounted to the underside of the rear deck. Is there an upgrade for this as well?
  #7
Old 01-01-2013, 07:08 PM
Part Deux's Avatar
Super Moderator
of course there is Check out the link I gave you for other options.
For anybody else reading this, that amp I linked REQUIRES a powered sub, not the passive sub in the RT's
__________________
aka THO.R
  #8
Old 01-01-2013, 07:26 PM
Shawnlh's Avatar
Member
I did check the pages in the link you posted.
No luck...
  #9
Old 01-02-2013, 08:40 AM
rodneyiii's Avatar
rodneyiii rodneyiii is offline
Senior Member
The power rating is the same as the original amp but the DSS mode makes a nice difference. Also, the EQ setup of this amp creates a little more LOW bass. I had one in my SRT8 for about a month before I traded the car. Since the Kicker spkrs are 4 ohms, the amp output is 28W/ch into 6 channels. The Charger has no center dash spkr like the 300s (1 ch) and the Kicker sub has its own amp (1 ch).
FYI - The subwoofer amp in the Chargers is rated at 200W.
__________________
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
  #10
Old 01-02-2013, 05:50 PM
Part Deux's Avatar
Super Moderator
SRT has a powered sub, the Daytona with the 322a does not. I installed the kicker 368w amp in my prior Daytona and couldn't figure out why there was no bass. I actually got to talk to a real live Kicker Engineer, who told me that the amp required a powered sub.
__________________
aka THO.R
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Bigger isn't always better Ziggatron Performance Discussion/Modifications 48 01-18-2012 12:05 PM
A bigger BND oil filter ? Gabe BND Automotive 9 04-13-2010 11:50 PM
bigger is better right?.... RIGHT!!!!! GORILLIA Wheels/Tires/Brakes/Suspension 24 10-02-2007 02:59 PM
Whose is Bigger?!!!!! mmaloy General Charger Discussion 41 11-28-2005 08:27 PM
© AutoGuide
