I have a 2012 R/T Maxx that has an irregular problem with the blind spot monitoring system. It seems the be more dominant when the temperatures get down lower. I've only had the car for a few short months and it has less than 5k miles on it. I have taken it to the dealer on one occasion. They read the system, seeing where it lost connection on three different times. But during the visit they could not reproduce the problem. They cleared the system and sent me on my way. Two days later go to start the car up and its back. This is about the third time it has done it and will stay out for sometimes 3-5 days. Even turning it on and off in the settings makes no difference. Tried to reset the vehicle by disconnecting the battery. The driver side mirror orange triangle will stay illuminated always and in the info cluster by the speedometer it states: vehicles blind spot monitoring is unavailable. What do you guys think this may be. Any help would be great!
So took it to the dealer again today. Problem actually showed while I was there. Dealer is ordering a replacement driver side mirror. Hoping this fixes the issue and none of you guys have the same problems!
I actually had this problem not to long ago where the passenger side orange triangle stayed illuminated. I was able to shut it off in the settings and turn it back on and it cleared it.
I've turned it on and off in the settings probably 100 times no luck lol. The dealer said it's a bad connection in the mirror itself. I just ride with it turned off for now til the new mirror comes in. Little beep when it starts letting me know the system is off. But not that annoying bright orange triangle lit up 24/7.
I seem to be having the same problem. I just picked up a 2013 SRT and the passenger side mirror is the one that is not working. When I have blindspot detection turned on, the orange indicator won't turn off. Also, the auto-dimming feature does not work on this mirror. I'll be taking it to the dealer on Thursday.
I don't believe the passenger mirrors have the auto dimming feature. Correct me if I'm wrong but I don't think the SRT mirrors are any different than the RT Max?!? The driver side and rear view should be the only ones.
Headed to the dealer this afternoon actually to get the new mirror installed. Will let you know if this fixes the problem.
Got the same error message the it turned off my radio and heat was running all day couldn't turn off. Took to place i brought the car he took out the fuse for the blind spot, all the other things started working but hes telling me i should change the sensor any suggestions. He wasnt to friendly. Could it be the fuse?
Hi charger14RT,
Feel free to let us know via private message if you plan to work with your dealer to resolve this. We are happy to provide you with additional assistance during that process.
Lydia
Dodge Social Care Specialist
2018 Dodge Charger Daytona. I had this happen. Both came on and would not shut off. I could manually turn them off in the control panel by turning off the BSM system. Took it to dealer and they replaced both sensors, FAST FORWARD.. Yesterday the diver side was stuck on and this morning they are both back on. It is a cold muther -f'r here and that might have something to do with it. Taking it back to the f'n dealer next Tuesday. Spoke with the service manager on the phone and told him I was NOT HAPPY. I am sure they will replace the sensors again, but I don't think that is the problem. I think the problem has something to do with the voltage regulated to the sensors in cold weather,
Hi Kidd1962, Glad to hear you are working with your dealer for this concern. If we can be of any additional assistance as you are working with your dealer, feel free to send us a private message. We'd be more than happy to help.
Rob
DodgeCares
What I learned was the sensors in the rear bumper must have something to do with the blind spot monitoring system. On the way back from Arizona last October I ran into a bit of snow and as soon as the rear bumper got coated with snow & ice I would get that orange triangle in my side mirrors and a warning on the dash that the blind spot system was inoperative. But as soon as the snow & ice fell off, everything came back on again. You can see in the pic below the two sensors closest to the license plate are covered.
They techs found a fault in the module that runs the sensor. They’re going to replace two modules per VW’s recommendation. The sensors themselves looked good. emi calculatorgst loginifsc code
Related Threads
Charger Forums
2.9M posts
104.7K members
Since 2003
