Traction Control - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
  #1
Old 12-26-2012, 05:18 PM
MotoAce51's Avatar
MotoAce51 MotoAce51 is offline
Senior Member
Traction Control
Today we got hammered with snow. It was my first trip driving the Charger in snow. I wasn't worried since I have had 2wd trucks in the past and once you get used to it its not bad.
Anyways, the TCS is weird on this car. I was playing around and you can hold it wide open and it wont just spin. The TCS cuts all power and only drives at low RPM's and holds traction. I think its an amazing idea but it does bum me out a little when playing... I just had to comment because I was amazed how it worked. After I realized it I would jump on it like crazy and "mr squiggles" turned on and power was minimized. Weird stuff for sure.
Now I realize I need to install a NO ESP mod so I can slide around and drift a bit.
__________________
2006 Charger R/T
- Carbon Fiber LMI Hammer Intake - Boss 22's - Blastin' Bobs 7db Reso Delete - Tranzformer Shift Kit - K&N CAI - DiabloSport - inTune CAI Tune - BT Catch Can - Tinted Marker's - 10000K HID - Halo & LED Headlights - CF Vinyl Dash & Door Pillar Overlay
  #2
Old 12-27-2012, 02:52 AM
ColdSteel's Avatar
ColdSteel ColdSteel is offline
Senior Member
We finally had the first snow, since I bought my 2008 new in December 2007, that I 'had' to drive my car. I recently put Firestone Winterforce tires on and they get big thumbs up from me for performance at a price that's about 60% of the Blizzaks.
Since I have the 2008, I can fully disable ESP with the key trick and let the car slide out (it's good practice), but I have to agree with MotoAce that when fully enabled, the ESP does an amazing job controlling power output to maintain traction. All you do is put your foot down on the gas pedal and Squiggles does all the work. No feathering, no goosing (and no 'fun'), just good straight line acceleration from a stop, regardless of the conditions on the road. I was impressed. With ESP enabled, I experience absolutely no yaw at all.
__________________
2008 R/T -Demoulded, Debadged, Daytona grille, Predator
Mopar CAI, LED Tails, HID Lows/Fogs, Tinted Windows SLP Loudmouth II, BT Catch Can, BT Shift Insert
Matte Black SRT Replicas w/ Hankook Ventus v12 evo tires (Stock wheels with Firestone Winterforce tires away until November)
  #3
Old 12-27-2012, 06:56 AM
MCaesar MCaesar is offline
Senior Member
If you drive in really deep stuff or ice you need LSD in addition to ESP
Otherwise ESP will just cut power to the point where you can not move
__________________
2006 SRT8 198,000 miles+ (ordered with F1s and options)
So, Caddy can get 6.1 hemi power out of a 3.6L V6 - What could we get out of a twin-turbo 5.7L hemi?
That is the stuff SRT should be doing
  #4
Old 12-27-2012, 06:59 AM
MotoAce51's Avatar
Senior Member
I noticed that. I needed a little more power at times and it really limited my movement.
__________________
2006 Charger R/T
  #5
Old 12-27-2012, 07:09 AM
ColdSteel's Avatar
Senior Member
That's where the ESP OFF button comes in. Right in the manual it tells you to turn it off if you are in sand/mud/snow so that you can continue to supply power when there is expected slippage.
__________________
  #6
Old 12-27-2012, 08:01 AM
MotoAce51's Avatar
Senior Member
Quote:
I didn't read the manual. That makes sense. I am guessing that's why the ESP off just turns it off to an extent then. That's good info to know. Thanks. I could have used that last night crawling up a hill downtown. I had traction but the car didn't let me go.
What do I need to do to get the car to slide/ spin? Even with ESP off if you try to do a doughnut, the throttle cuts out and it tries to get traction. I have to feather the throttle and its a pain.
__________________
2006 Charger R/T
  #7
Old 12-27-2012, 08:06 AM
ColdSteel's Avatar
Senior Member
For a 2006, not so easy to go full off; only option to eliminate TC is in the Predator menu, I believe, but you can't do that on the fly.
__________________
  #8
Old 12-27-2012, 08:21 AM
MotoAce51's Avatar
Senior Member
Yeah, I will need to install the no ESP mod soon then. I am really glad you mentioned the ESP off button for driving in slippery cond. though. I never knew that.
__________________
2006 Charger R/T
  #9
Old 12-27-2012, 09:21 AM
DodgeCares's Avatar
DodgeCares DodgeCares is offline
Senior Member
Moto,
From the manual:
The ESP warning light, located in the instrument
cluster, starts to flash as soon as the ESP
system sensor’s information varies from the
driver’s intended path. The ESP warning light
also flashes when traction control is activated. If the ESP
warning light begins to flash during acceleration, ease up
on the accelerator and apply as little throttle as possible.
Be sure to adapt your speed and driving to the prevailing
road conditions. When the ESP warning light is illuminated
continuously, the ESP is switched off. To return to
the enhanced vehicle stability offered by ESP, press the
ESP switch (the ESP warning light in the instrument
cluster goes out). Avoid spinning one drive wheel. This
may cause serious damage to the drive train.
To improve the vehicle’s traction when driving with
snow chains, or starting off in deep snow, sand or gravel,
switch off the ESP system by pressing the ESP switch.
__________________
Top Care
Chrysler Group LLC
DodgeCares will be offline until July 15, 2013.
  #10
Old 12-29-2012, 05:50 PM
MotoAce51's Avatar
Senior Member
[QUOTE=DodgeCares;2381240]Moto,
From the manual:
[/QUOTEUn
Sent from my ADR6350 using AutoGuide.Com Free App
__________________
2006 Charger R/T
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Traction control Stevens12 General Charger Discussion 6 07-12-2012 04:40 PM
traction control? WTFO09R/T Performance Discussion/Modifications 13 03-27-2011 09:51 AM
ABS, ESP, BAS, Traction Control MRUSH1026 Charger Problems/Assistance 0 05-24-2010 03:07 PM
Traction Control Chargin69 General Charger Discussion 7 01-16-2007 07:32 AM
Traction Control The Bear Performance Discussion/Modifications 1 12-12-2006 11:25 AM
© AutoGuide
