Another winter storage thread.. - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 12-11-2012, 05:05 PM
Miss Innocent's Avatar
Miss Innocent Miss Innocent is offline
Senior Member
My Charger: '10 SXT and '07 Sublime RT #565
Sublime is supposed to go away tomorrow evening... few questions..
I know I need the oil changed.. would it be okay to put the Quantum Blue stuff in, and then just run the normal 10k miles on the same oil? or do I need to change the stuff that sits all winter?
Washing the car... touchless is the only option now as we have a few feet of snow.. so is the stuff that gets picked up on the 5 min drive to the storage facility really going to make a huge deal?
Other than that... fill tank to the nuts, add Aces IV, pull battery and fuse, baking soda, really good car cover, and 2x6 boards so the tires don't touch the cold cement.
__________________
A new religion that will bring you to your knees.
  #2
Old 12-11-2012, 06:37 PM
Ddaddy's Avatar
Ddaddy Ddaddy is offline
Senior Member
Wow, 30 views and no responses. I guess inquiring minds want to know!
Answers below...
Yes, put in fresh oil and you can run it in the Spring without changing. You will want to pull the "start" fuse so that you can crank it to get oil flowing and lube everything up prior to actual starting. Brian has a posted this in his Vendor section or you can call him for details. It's good advice.
Not a big deal but be sure to take it through the carwash when you first wake it in the Spring to get it clean underneath. Salt is the concern so unless there is a lot of salt in the mix, no reason to worry as long as the storage place is good and dry.
Other than that... fill tank to the nuts Don't overfill, just normal fill,
add Aces IV,
Good idea to stabilize the fuel for the Winter
Good idea again to maintain battery life
baking soda,
I assume this is an open container on the inside for odors?
The boards aren't necessary, concrete won't harm the tires. Fill the tires to the max pressure listed on the sidewall and return pressure to normal driving pressure when you wake it up in the Spring. If you want to be extra cautious, put the car up on jack stands to unload the suspension and still fill the tires to max pressure to keep the tire bead intact and prevent moisture intrusion that can corrode the bead seat on the aluminum rims.
__________________
2006 Inferno Red SRT-8
Option groups I, II, & III + Sunroof
Built Thursday February 23, 2006
Triple A Performance (AirFunnel, AirHog, Aces IV)
QuantumBlue Custom Blended Oil (Yeah, it's that good)
I will drive her until one of us dies! 1/4 mile: 13.388 secs@105.75 mph
  #3
Old 12-11-2012, 09:50 PM
Senior Member
Quote:
Answers below...
Perfect! you are awesome! Baking soda for excess moisture and smell yeah.
Storage place is dry and clean.
I wont have time to put up.. the tires call for 42lbs of air.. that's insane, I drive with like 35 lol
__________________
  #4
Old 12-12-2012, 05:49 AM
GLHS837's Avatar
GLHS837 GLHS837 is offline
Super Moderator
Lifetime Supporting Member
Sounds insane, but really the second best way to go. The sidewalls of the tires are the thing we are working on here, keeping them from being held in a the same flexed position for months and that internal air pressure will allow them to resist the weight of the car better, and not be so flexed. thats why DD suggested the jackstands. If the tires are not supporting the weight of the car, they are happier. Oh, and if you set 42psi now, when it's 30 degrees colder, those same tires will have about 4-6psi less
__________________
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
  #5
Old 12-12-2012, 06:21 AM
Part Deux's Avatar
Part Deux Part Deux is online now
Super Moderator
Pull the storage fuse instead of the whole battery cable... I don't recall which one.
What do the experts here think about putting plastic down on the cement under the car?
I wouldn't cover the car unless you 1. concernced with debris or bird droppings 2. the car is absolutely clean before covering it.
Little bit of salt you pick up is not going to be a big deal unless it's heated storage. I'm not a fan of heated storage for that exact reason.
Good luck surviving winter
__________________
Did you know that - Thread
How do I everything - Thread
aka THO.R
Quote:
Originally Posted by 08 Stoned Charger View Post
I have a name for the 3 new mods...............Druken Purple Pirates!!!
Quote:
Originally Posted by Daytona606 View Post
American Muscle, like a pit bull. Big but not large, well defined, explosive power, in it till the end. The cat will give it go and zig and zag, but in the end the pit bull will always catch the cat – the outcome is never good for the cat.
  #6
Old 12-12-2012, 07:10 AM
R/T MUSCLE's Avatar
R/T MUSCLE R/T MUSCLE is online now
Senior Member
My Charger: 2010 R/T with road and track group package
Here you go Missy, Maybe this will help..
Big John
http://mycountdown.org/Other/Spring/
__________________
2010 Dodge Charger R/T with Road and Track group package,tinted all around. Black Crystal Pearl coat paint. 1966 Pontiac GTO tripower 4spd, 390posi. GTO made the cover of High Performance Pontiac Magazine Dec/92
  #7
Old 12-12-2012, 07:39 AM
370 HEMI's Avatar
370 HEMI 370 HEMI is offline
Supporting Vendor
Ddaddy is right. The oils are designed for 10k miles (16k km) or 2 years. I change my SRT8 every 2 years as I don't get to 10k miles on it!
Salt is only active when wet. If the salt is dry it will remain dormant. If you are concerned about the underhood components and the brake rotors, you can give me a call and I can put together some of the QB Metal Anti-Corrosion Dry Lubricant Spray for you. Any rust prone metals will be protected and still be dry. Fine to drive on it in the Spring!
The fuse is the IOD fuse and allow the battery to be fine without draw on it. Chrysler made this years ago because their cars were drawing down the battery sitting in the parking lot. Imagine going to test drive a new car and the battery is dead when the salesman tries to turn it over!! http://www.chargerforums.com/forums/...light=iod+fuse
GLHS837 is right on the tire pressures. Jackstands are preferred but higher pressures so that they don't flex excessively is acceptable too!
Regards,
Brian
BND Automotive LLC
440-821-9040
www.bndautomotive.com
__________________
ACES IV Fuel Catalyst- "Higher HP -N- Torque w/better mileage & longer engine life... Rocket Fuel for your car!
QuantumBlue Lubricants-"Because our Custom Blended lubricants ALWAYS outperform store bought!"
QuantumBlue HP Gold Coolants -"Better than even OEM without the GUNK"
ALSO TRY: QuantumBlue Vinyl and Fabric Stain and UV Protectors.
  #8
Old 12-12-2012, 07:52 AM
GLHS837's Avatar
Super Moderator
Quote:
Originally Posted by 370 HEMI View Post
GLHS837 is right
Regards,
Brian
BND Automotive LLC
440-821-9040
Makes a great sig
__________________
―C-3PO, to R2-D2
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Winter Storage? Franchize48 General Charger Discussion 10 04-10-2009 10:56 PM
Winter storage 1finecharger New England Area 7 10-19-2008 10:05 PM
Winter Storage?? mccrisco General Charger Discussion 11 12-07-2006 06:23 PM
Winter storage. cdaboysfan General Charger Discussion 18 08-15-2006 10:13 AM
Winter Storage blhemi General Charger Discussion 6 10-02-2005 06:24 PM
© AutoGuide
