whistling sound on cold start - Dodge Charger Forums
Charger Problems/Assistance (2011 +) You having problems with your Charger? Check and see if it is a common problem and get answers here.
post #1 of 11 Old 12-09-2012, 03:27 PM Thread Starter
ert
Member
(Thread Starter)
Last winter my 2011 R/T started making a high pitch whistling / screetch sound briefly on startup in cold temps (< 32F). The dealer was unable to find anything, but now it's doing it again since it's getting colder out. Any ideas what this might be? The sound lasts only about a second and only when the engine has been off for 12+ hours in cold weather. I've had similar sounds on other cars that turned out to be bad alternator bearings, pulley, etc, but those problems generally produced constant sound and could be easily diagnosed. I'm not looking forward to leaving my car at the dealer for several days only to have the same reply as last time.
2011 R/T Billet Metallic
Corsa Extreme exhaust
ert is offline
post #2 of 11 Old 12-17-2012, 08:25 PM
WhiteOut529
Senior Member
Does it go away after some time??
WhiteOut529 is offline
post #3 of 11 Old 12-17-2012, 08:34 PM
torred 3.5
Senior Member
torred 3.5's Avatar
I have the SAME problem on my 08 3.5L. And I live in Michigan so it gets pretty cold out. Just like you described, I have the 89 oct predator tuned installed and every morning for the first 2-3 seconds will make a whining/whistling noise right after start up and then it will go away when the engine comes off high cam or when I put it into reverse. Weird, I'm maybe wondering is it a vacuum leak somewhere in the intake? I have no idea, but I don't find it to be a serious problem.
2008 Dodge// Charger SE Plus 3.5
TORRED exterior. Mods: too many to list.
Charger bought new, 10 minutes from Chrysler headquarters on December 30, 2008.
torred 3.5 is offline
post #4 of 11 Old 12-19-2012, 01:31 PM
DodgeCares
Senior Member
DodgeCares's Avatar
Quote:
Torred,
There was a TSB that may be related to your issue. I could find no such bulletin for the 2011 models though. See below.
NUMBER: 18-036-08 REV. A
GROUP: Vehicle Performance
DATE: December 3, 2008
SUBJECT:
Flash: Whistle Sound From Engine Compartment/Purge Solenoid
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software and Initializing the NAG1 transmission (sales code DGJ)
or Clear the Variable Line Pressure (VLP) Counters on 42RLE equipped vehicles (sales
code DGV) with the StarSCAN®/StarMobile®.
CAUTION: It is important to initialize the NAG1 transmission (sales code DGJ) for
2008 model year or Clear the Variable Line Pressure (VLP) Counters on
42RLE equipped vehicles (sales code DGV) with the
MODELS:
*2008** - 2009 (LE) 300C/300 Touring (International Markets)
*2008** - 2009 (LX) 300 / Magnum / Charger
NOTE: This bulletin applies to models equipped with a 3.5L engine (sales code EGG)
built before August 26, 2008 (MDH 0826XX).
SYMPTOM/CONDITION:
Some customers may complain of a whistle sound coming from the engine compartment
while the vehicle is running. This condition is caused by the purge solenoid. A software
change has been made to the current on the purge solenoid circuit which corrects the
condition.
If the vehicle owner complains of this issue reprogram the PCM with the new software.
DodgeCares is offline
post #5 of 11 Old 12-19-2012, 01:34 PM
torred 3.5
Senior Member
torred 3.5's Avatar
Quote:
Originally Posted by DodgeCares View Post
Torred,
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
condition.
wow, great info, didn't even know that! So how do I get this fixed? Let the dealer know of this problem and they'll give me the new software/calibration?
post #6 of 11 Old 12-19-2012, 01:36 PM
Hemi_Infantry
Senior Member
Hemi_Infantry's Avatar
Could it just be a squeeky pulley that needs some belt spray? Happens to me when it gets cold out.
(My name is Mike) Black 06 R/T, Black BOSS 338s, smoked LED tails, AAC Dual Halo (red/blue), AEM Brute CAI, BBK 85MM TB, Predator 91 CAI tune, 180 t-stat, TranZformer Shift Kit, ACES IV, BT Catch-can, Borla 125, JBA catless mids, (Eibach Anti-roll kit, and SLP underdrive pulley waiting for install) custom front emblem, Danko chin, Danko 345Hemi badges, 2" cowl ram air hood with pins // (stereo equip) Nation's 290amp alternator, 2000w Alpine amp, 200w & 400w mid amps, Memphis 6x9s, 2x Kicker 12" L7s, Rockford Fosgate hybrid cap
-machine gun turret sold separately
Hemi_Infantry is offline
post #7 of 11 Old 12-19-2012, 01:44 PM
DodgeCares
Senior Member
DodgeCares's Avatar
Vehicle would have to be diagnosed by dealer and update would be done if it was determined to be a resolution to the problem. It only would be covered under warranty or service contract if you have coverage. It is not a recall that would be covered at any time.
post #8 of 11 Old 12-31-2012, 01:03 AM Thread Starter
ert
Member
(Thread Starter)
Quote:
It only last 1-3 seconds on a cold start.
ert is offline
post #9 of 11 Old 01-05-2013, 01:15 PM
torred 3.5
Senior Member
torred 3.5's Avatar
My father is an engineer at Chrysler so he has the starscan tools/diagnostics etc. Could this be done by him?
post #10 of 11 Old 01-07-2013, 08:14 AM
DodgeCares
Senior Member
DodgeCares's Avatar
He would have to have the new software to do so.
  Dodge Charger Forums > Dodge Charger Models (2011 - Up) > Charger Problems/Assistance (2011 +)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Humming/whistling sound Supermanx52 Charger Problems/Assistance 0 02-25-2011 04:08 PM
Awful sound on negative temp. cold start carchitect General Charger Discussion 57 02-05-2009 01:48 PM
i have a whistling sound that seems to come from my cai 08rtbama Performance Discussion/Modifications 27 06-30-2008 12:28 AM
Whistling sound on SXT Charg-s(x)t-er_22 Charger Problems/Assistance 7 02-23-2006 10:03 PM
K&N CAI whistling sound? SouthNJCharger Performance Discussion/Modifications 2 01-16-2006 12:52 AM
You may post new threads
You may post replies
