Big problem I think... 2008 5.7 Hemi Police package - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 11-17-2012, 01:06 AM
southbronxems's Avatar
southbronxems southbronxems is offline
Member
Arrow Big problem I think... 2008 5.7 Hemi Police package
So, I live in NY and the recent hurricane brought with it a serious gas shortage problem. I used some old fuel in the garage to make up for the shortage and within a day, the car was starting hard. I fueled up the following day with fresh gas, but after the hard starting, there was a loud tick that sounded like it was on top near the valves.
The tick went away on its own the next day, and the car started starting normally again. I threw 2 codes. Random multiple misfire during the hard starting, and then p0303 cylinder 3 misfire that I can not clear.
I added seafoam to the fuel and marvel mystery oil to the crankcase, (I know, some people dont like additives). It seems like its running ok on the highway with full power, but idle is very rough still. I changed the #3 injector, checked the coil, and changed the plugs, (they were do anyway).
I still have a miss in #3, and those two plugs were oily and dark. Obviously there is a firing issue, but I think the spark is ok. Can this be a valve issue. I know there were some valve issues with the Hemi, but the car starts and runs ok, except for the missfire. Im not even sure this was caused by the fuel, maybe its coincidence...
If the valve was sticking or the seat was fallen, would that cause the misfire issue and allow the car to keep running well for the most part?
The car is not ticking anymore and sounds normal except for the misfire.
What should I check/fix next?...
Thanks!!!
__________________
2008 Charger Fleet "Police group/Special service group" 5.7v8. Homemade Cold Air Induction, Tint 20%, Double tail light mod, Thrush/Flowmaster hybrid exhaust, More to come one day... My cars name is "Morlan".
  #2
Old 11-17-2012, 09:00 AM
Member
Bumpbump...
__________________
  #3
Old 11-17-2012, 01:17 PM
richd richd is offline
Senior Member
It looks like you need to check compression,and it could be bad valve seals and fouling plug causing mis-fire.
  #4
Old 11-17-2012, 06:48 PM
Scott's Avatar
Scott Scott is offline
Senior Member
Take the valve cover off. Something is broke. You only need to remove the coil packs. Then you can see if you have a broken component
__________________
07 R/T, Spoiler, Daytona Insert, Glove box light, Mopar Fender CAI, Hood struts, Cabin Air Filter
  #5
Old 11-17-2012, 08:21 PM
TBird100636's Avatar
TBird100636 TBird100636 is offline
Senior Member
My Charger: 2011 Charger R/T Plus AWD
Cool
Compression test, Cylinder leakdown test, and maybe pull the valve cover.
__________________
2011 Dodge Charger R/T Plus AWD- Redline-5.7L Hemi Registry #1650 Tbird100636
2006 Dodge Charger R/T- Inferno Red- Gone-5.7L Hemi Registry # 00696 Tbird100636
  #6
Old 11-17-2012, 11:00 PM
Member
Thanks everyone for the responses. Pulled the valve cover today. Checked the rocker arms and ended up finding a bent pushrod on the intake side. Not sure how this happened but I replaced it and everything seems to be running ok now, no more misfire. My battery died when this started happening. Im thinking it died mid crank and the compression caused the motor to kick back before the valve had a chance to cycle. I have no other explanation and I hope that was all it was. I ll repost if anything changes. Thanks for everyones advice though!!!
__________________
Tags
coil, injector, spark, ticking, valve
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
2006 R/T vs 2008 Police package stanglx2.3 General Charger Discussion 11 10-17-2012 02:53 PM
Help!Need better tires HEMI 5.7 with Police Package gumbyandpokie999 Wheels/Tires/Brakes/Suspension 1 01-25-2011 08:43 AM
For Sale: 2008 Dodge Charger Police Package 3.5L medicone Cars For Sale/Wanted 1 10-22-2010 03:25 PM
© AutoGuide
