stock exhaust question - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Models (2011 - Up) > Performance Discussion/Modifications (2011 +)
  #1
Old 11-15-2012, 11:32 PM
450whpsrt4's Avatar
450whpsrt4 450whpsrt4 is offline
Senior Member
which is the resonators and which is the mufflers? and which has the MDS baffles in it?
i made an appointment for tuesday to get some part of the exhaust cut off the car and im not sure which one i want to remove.
im leaning towards the big canisters under the trunk.
  #2
Old 11-16-2012, 01:07 AM
KJT38's Avatar
KJT38 KJT38 is offline
Senior Member
The resonators are the ones in the back behind the rear axle and the mufflers are in the middle in front of the rear axle.
  #3
Old 11-16-2012, 11:40 AM
450whpsrt4's Avatar
Senior Member
Quote:
alright thanks
i think im gonna take the resonators off then. i hope it sounds decent.
  #4
Old 11-16-2012, 05:44 PM
cancer63's Avatar
cancer63 cancer63 is offline
Member
Quote:
Originally Posted by 450whpsrt4 View Post
alright thanks
Post a sound clip of it. Thinking of doing the same thing to my Charger.
  #5
Old 11-16-2012, 11:51 PM
450whpsrt4's Avatar
Senior Member
Quote:
will do when its done.
  #6
Old 11-17-2012, 04:59 AM
joey0480 joey0480 is offline
Member
I have heard a few...sounds good...good luck
  #7
Old 11-19-2012, 07:36 AM
michiganpat's Avatar
michiganpat michiganpat is offline
Senior Member
keep the resonators, take the mid mufflers off, otherwise you'll have drone at highway speeds, especially when MDS kicks in
__________________
'11 Toxic Orange Charger R/T
'06 Dodge Grand Caravan
'76 Plymouth Duster
  #8
Old 11-19-2012, 10:23 PM
450whpsrt4's Avatar
Senior Member
Quote:
wouldnt it be more of a performance gain to take those big canisters off?
i was also thinking of removing both and getting a set of 20 inch magnaflow mufflers.
  #9
Old 11-20-2012, 05:42 AM
Senior Member
no.
1) the stock 2.25" mandrel bent exhaust flows well enough to support ~400HP without significant HP loss.
2) as exhaust cools, due to the ideal gas law (PV=nRT), it's volume reduces (for a constant pressure, P, as temperature T goes down, volume V goes down), so the resonators way in the back where the exhaust is much cooler than it is at the manifolds really aren't much of a restriction.
3) as far as drone is concerned, one of the big factors for resonance RPM is pipe length, especially free length after the muffler. think of a pipe organ--longer, larger pipes have a lower resonant frequency...or think of blowing across the open top of a 2liter pop bottle---empty, it's a low tone...fill it half full with water, the frequency raises substantially....to minimize drone, you should put the mufflers as far back as possible, with short tailpipes....which is basically what the stock resonators are...mufflers all the way back with short tailpipes.
__________________
'76 Plymouth Duster
  #10
Old 11-20-2012, 07:38 PM
CHARLIE's Avatar
CHARLIE CHARLIE is offline
Senior Member
I took my resonators off a few months back. The drone is is not bad at all.
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Stock exhaust question stryker6040 V6 Specific Discussion 0 05-20-2012 03:36 PM
stock exhaust question Brian_Gallagher Performance Discussion/Modifications 4 04-17-2012 07:03 PM
Stock Charger Exhaust Question bloodstripe23 General Charger Discussion 4 05-11-2009 09:33 AM
Dual Exhaust (Stock Set-up) Question BoJantic V6 Specific Discussion 19 07-25-2008 04:46 PM
Stock exhaust question.. oldcarsrock V6 Specific Discussion 3 12-03-2007 10:14 AM
© AutoGuide
