How hard is it to change valve cover gasket ? - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 11-13-2012, 08:35 PM
randyman420 randyman420 is offline
Junior Member
Send a message via Yahoo to randyman420
Been in the dealer 3 times now (2011 hemi passenger side ) they just cannot fix the leak ..think it's really that hard a job ? It leaks on the exhaust and stinks me out ..think it could be the head gasket ? the whole motor was apart at 7,000 mi ..cam ,lifters,rockers replaced ..then after that the coolant tank was full of oil ..they did a pressure test ( removed the oil pressure sending unit and forced air threw it to try to find the leak ),,they replaced the oil cooler ..had to go back 3 more times for coolant flushes and a new tank (like pulling teeth for the tank) now this crazy problem ..wonder if they blew something by forcing air into the system ..." 44 days in shop so far ,9100 miles ...think I better get "LEMON 1 plates for her ,,ugggggggg
  #2
Old 11-13-2012, 08:41 PM
bestman77 bestman77 is offline
Member
wow..that does sound like a lemon!
Man I'd be pushing for a new Engine with all these problems at 9100 miles
  #3
Old 11-13-2012, 10:07 PM
Hazmat11 Hazmat11 is offline
Senior Member
My Charger: 2013 Granite Grey R/T
That sounds like an exhaust manifold gasket and not a valve cover gasket. While they're not hard to change, it hardly sounds like it should be your responsibility. If it was the valve cover gasket you'd likely leak oil. If it was the head gasket you'd be using coolant and based on how much, you could see anywhere from slight to large amounts of white smoke during acceleration.
I'd go back until they get it right. If not, save your repair receipts and see if you can pursue a replacement under your state's lemon law. No one should have to go through that.
__________________
2013 Charger R/T
  #4
Old 11-14-2012, 09:26 AM
Mrbelvedere's Avatar
Mrbelvedere Mrbelvedere is offline
Senior Member
Perhaps the valve cover itself is damaged, cracked whatever allowing oil to leak onto the manifold? The gasket may also have partially fallen out of place when the tech was reinstalling the cover. Is there still oil in the coolant? Evidence of coolant in your oil? Either way, it's up to the dealer to resolve the situation. Keep trying and best of luck!
__________________
2006 Bright Silver R/T, Road and Track performance group with many, many subtle appearance and performance mods.
  #5
Old 11-19-2012, 05:12 PM
Junior Member
You were right ,,after 3 tries at a gasket ,,the cover was bad ,,think it stopped ,,and think the oil in the coolant stopped to ,,Thanks
Tags
engine, leak, lemon, oil, problems
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
How hard is it to change out the grille on our cars? durty_red23 Exterior Discussion/Modifications 25 03-22-2010 04:06 PM
how hard is it to change an oil pump? MySRT8U General Charger Discussion 14 12-30-2008 09:53 AM
How hard is it to change rear shocks? - Any pics? Blue Phantom Wheels/Tires/Brakes/Suspension 1 12-29-2008 05:30 PM
is it hard to change the calipers? Hemidude23 General Charger Discussion 3 12-28-2008 09:45 PM
© AutoGuide
