What is the right PSI on Drag Radials ? - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > Track Talk
  #1
Old 11-07-2012, 06:04 PM
06MangoDaytona's Avatar
06MangoDaytona 06MangoDaytona is offline
Senior Member
Question What is the right PSI on Drag Radials ?
I'm going to Mason-Dixon Drag way for their final Test & Tune of the year and this time I have drag radials I'm going to run spare tires up front and I'm not sure how to set the PSI on this set up.
The Drag Radials are BFG G-Force and the size is 275/40/R17 and the spares are stock size T145/80/D18. Also do I need to change my wheel/tires size with my predator or will it make a difference ?
Thanks guys
__________________
Gone but Not Forgotten 2006 Go-Mango Daytona 1-11-13
Current 2012 SRT8 Challenger 392
  #2
Old 11-08-2012, 07:09 PM
Senior Member
Anybody run this set up or have any input ???
__________________
  #3
Old 11-08-2012, 08:05 PM
Keavdog Keavdog is offline
Senior Member
Lifetime Supporting Member
15-20 on the backs, try staring at 18. 40 up front.
It is also important to remember that the g-Force T/A Drag Radial operates most efficiently on the strip at cold inflation pressures of between 15psi and 20psi (in no case should below 12psi be used). And after the racing is done for the day, it is essential that the g-Force T/A Drag Radial be reinflated to normal highway operating pressures before carrying the driver and trophy back home. Running any tire at relatively low inflation pressure for a given load reduces the tire's speed capability by causing it to stretch more and operate at a high deflection (more radial bulge). The g-Force T/A Drag Radial is built to withstand brief "bursts" of high speed while inflated at low pressure (such as would be experienced on a quick car in the quarter-mile), but no tire can be expected to survive for a long time at high speed while operating at high deflection.
__________________
John
09 RT. 11.796 @ 113.15
11 IE Challenger 392 #787
13 Boss 302 Laguna Seca #392
  #4
Old 11-13-2012, 07:09 PM
Senior Member
Thanks for the help I didnt get to go but I'll keep this info for the next time I do
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
F/S: Drag Front Runners and Drag Radials WhiteR/T07 Parts For Sale/Wanted 4 07-01-2011 11:47 PM
F/S - 2 Voxx 18" Drag Rims with MT Drag Radials. HEMISFEAR Parts For Sale/Wanted 3 06-16-2010 07:52 PM
Help I need drag Radials! Srt8YouUp Wheels/Tires/Brakes/Suspension 11 06-02-2008 12:54 PM
drag radials - where to get the 17"s with the drag radials shibby Wheels/Tires/Brakes/Suspension 2 05-11-2008 04:55 PM
Drag Radials zerfetzen Wheels/Tires/Brakes/Suspension 18 04-16-2007 07:59 PM
© AutoGuide
