Enable sound horn on lock feature (HELP) - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Models (2011 - Up) > Charger Problems/Assistance (2011 +)
  #1
Old 10-31-2012, 01:35 AM
esz's Avatar
esz esz is offline
Member
Dear friends!
I am hoping that somebody from the forum has an idea about this problem.
The feature "sound horn on lock" has made me go crazy over the past years, starting from my first charger in 2009.
I have just purchased a brand new 2012 Charger SRT8 and was hoping that the aforementioned feature will finally start working.
The first thing I did when I was at the dealer receiving the car, I have checked if the feature is working. Of course for some reason, the feature did not work. The option is turned ON in the navigation system and it still does not work
When I visited the dealer for my first service (2500 km), the service adviser told me that it's impossible to turn the feature ON and that he had several complaints from customers about this issue.
I told him that I will not give up and that I will bring good news to him as soon as I find a way to make the feature work.
I live in Kuwait and the car was manufactured in Canada.
What do you guys think? Is it possible to turn this (silly) feature ON?
__________________
2012 Charger SRT8 (Stock)
SOLD (but not forgotten):
2009 Charger R/T (Road & Track)
MODS:JLT's Carbon Fiber CAI
  #2
Old 10-31-2012, 06:22 AM
3996 Daytona's Avatar
3996 Daytona 3996 Daytona is offline
Senior Member
I found that the alarm and unlock features in EVIC are very unreliable. I set mine to turn the lights on when I unlock but it only works once in a while. The same thing with the unlock all doors with one press. I have it off but sometimes they all unlock. I gave up on it and just accepted that it will do what it wants
__________________
3996 of 4000 Go Man-Go Still bling-free (not counting the Wilwood brakes)
BT Catch can - SLP underdrive - PPP Stage II heads - BBK Headers - 268 Compcam - Jet 180 T-stat - Wilwood Brakes - BB Stage II VB - MDS Delete - Custom Tune by Johan
  #3
Old 11-03-2012, 05:20 AM
nessqn nessqn is offline
Junior Member
Sound horn on remote start is not working on my 2012 R/T Rd & Track Charger. So r the power pedals.The power-lock button on door handles work intermittently. Dealer/Service center is clueless...we cant have the best of both worlds i guess...
  #4
Old 11-06-2012, 11:54 AM
esz's Avatar
esz esz is offline
Member
Quote:
You should go to the dealer and let them fix it!
At least your horn partially works, mine is totally off
__________________
  #5
Old 11-06-2012, 11:57 AM
esz's Avatar
esz esz is offline
Member
Quote:
What about sound horn when you lock your car?
Are you from the states?
__________________
  #6
Old 11-07-2012, 07:53 PM
Ddaddy's Avatar
Ddaddy Ddaddy is offline
Senior Member
All of my selections work exactly as selected. I turn on headlights with unlock and honk the horn upon lock.
If it isn't working properly, you might want to disconnect the battery for 30 secs and then reconnect. This should reset the system to acept the new selections and enable them. Alternatively, you can pull the IOD fuse in the trunk to reset the BCM that controls these things.
If you continue to have issues, ask the dealer to reflash the BCM with the latest version to address the issue.
Many folks forget that these cars have a Body Control Module just like the Program Cointrol Module or the Transmission Control Module.
__________________
2006 Inferno Red SRT-8
Option groups I, II, & III + Sunroof
Built Thursday February 23, 2006
Triple A Performance (AirFunnel, AirHog, Aces IV)
QuantumBlue Custom Blended Oil (Yeah, it's that good)
I will drive her until one of us dies! 1/4 mile: 13.388 secs@105.75 mph
  #7
Old 11-07-2012, 08:02 PM
esz's Avatar
esz esz is offline
Member
Thank you for your reply!
I think disconnecting the battery won't work. I will try with the other 2 options.
Good idea to reflash the BCM. Maybe that's the solution.
Do you think that the BCM software for US, Canada and Kuwait can be different from each other?
__________________
  #8
Old 11-07-2012, 08:08 PM
Ddaddy's Avatar
Senior Member
I don't think there will be any differences in the BCM by country. This is a factory program and should cover all of the models irrespective of market. The master program is likely written to cover all models and options.
I wouldn't discount disconnecting the battery or pulling the IOD fuse. It worked on our Grand Caravan when we were having issues with the remote door locks. It's cheap and easy to try.
__________________
  #9
Old 11-07-2012, 08:09 PM
GLHS837's Avatar
GLHS837 GLHS837 is offline
Super Moderator
Lifetime Supporting Member
They could very well be. I wouldnt toss out the battery disconnect, worth a shot. 2 minutes with I think a 10mm socket is worth the off chance of it fixing the problem. Being Kuwait, I imagine your choice of dealers is probably limited, but if there is another one to go to, I would try that. Perhaps if there is a separate Chrysler dealership, that might work, since under the skin, this car and the 300C are basically the same.
__________________
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
  #10
Old 11-07-2012, 08:15 PM
esz's Avatar
esz esz is offline
Member
Will give it a try before going to the dealer.
Thank you!
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Wiring an electronic air horn into the horn circuit? Please help! Buddyfonteyne Audio - Alarms - Navigation - Electronics 4 09-16-2012 06:34 PM
need help / horn when lock adnan Charger Problems/Assistance 0 10-07-2010 05:48 AM
how to shut off the horn-honk-on-lock ? brichi Charger Problems/Assistance 10 08-12-2008 09:37 AM
Horn / Door lock question??? Charger555 Exterior Discussion/Modifications 4 11-13-2006 12:20 PM
© AutoGuide
