Oil Change Interval Questions - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > V6 Specific Discussion
  #1
Old 10-28-2012, 11:31 PM
iamstubb's Avatar
iamstubb iamstubb is offline
Senior Member
I have a new 12 SXT V6/8spd that I am breaking in. Owner's manual says first oil change at 8,000 miles. Mine has 110 hours and 3500 miles in about 2.5 months and the information notice on the dash has idicated time for a change. I'm getting about 28 mpg so I don't think I am too spirited of a driver, but that seems a little soon. Anyone know what contributes to that indicator coming on? Why so soon? If I am tough on it, should I change my oil type? I see a lot of synthetic fans here and read postings for BND and others. If I do that, will I have to keep track of intervals myself or will I be constantly nagged by the oil change due notice? How would I then know that it is time for a change if there is that much variability in the interval?
  #2
Old 10-29-2012, 04:36 AM
Hazmat11 Hazmat11 is offline
Senior Member
My Charger: 2013 Granite Grey R/T
Feel free to have a look at this thread and give it a good read since many of us have asked the same question before. Based on the information you should already be pulling your conventional oil and changing to something else. If you can afford to use QB lubricants I'd make the switch. Here's the link:
http://www.chargerforums.com/forums/...d.php?t=159383
Also feel free to PM Brian from BnD Automotive. He can answer any question you have regarding off the shelf oils and the advantages of his products. His site screen name is 370_HEMI.
Hope that helps,
Andy
__________________
2013 Charger R/T
  #3
Old 10-29-2012, 04:39 AM
Jonny's Avatar
Jonny Jonny is offline
Senior Member
Lifetime Supporting Member
My Charger: 2010 Charger R/T
8k is the most you can go. Always change the oil when the indicator says it is time! (but don't go more than 8k)
The first change is usually around 2500...
__________________
I am the Stig
2010 R/T DWBlue, 2800 PI stall, Homemade CAI, JBA headers and mids, Flowmaster catback, Custom tune by Diablotoona, 180 T-stat, 3.06 rear gears.
  #4
Old 10-29-2012, 07:43 AM
370 HEMI's Avatar
370 HEMI 370 HEMI is offline
Supporting Vendor
Quote:
I would never go anywhere near that mileage on the first change! You have a double over head cam (DOHC) engine with 4 valves! It is also a variable valve timing engine with cam phasers. The oil is used to phase the cams. Conventional oils will tend to gum up in this engine with the type of heat you will generate.
I would definitely change it out where you are. Now remember that the in dash indicator is based on algorithm and not the condition of the oil. We can make a really good 8.5w32 QuantumBlue HP Custom Blend 3.6L VVT Formula for you that would easily go 10k miles between changes.
Chrysler uses a Flexible Service System or FSS. As stated earlier, it is comprised of algorithms to predict oil change intervals. The algorithms are based primarily on factors such as driving habits, driving speed, and failure to replenish low oil levels. Chrysler's research determined that these factors contribute to oil breakdown. (So again, it is the oil that is at issue here!)
The algorithm method systems basically monitor time between oil changes, vehicle speed, coolant temperature, load signal, engine rpm, engine oil temperature and engine oil level to determine the remaining time and mileage before the next oil change.
Remember that what the oil is comprised of makes ALL the difference with what drain intervals you keep. We recommend 3k miles on conventional, 5k miles on typical off the shelf synthetics, and 10k miles on QuantumBlue. We always recommend an oil analysis to verify what is going on in the engine. We have done many 3.6L VVT engines....two of which are owned by us personally (2011 Avenger Lux and 2011 Grand Caravan R/T). 10k on QB with these engines are loafing it!
You can keep track yourself by pegging a 10k mile number or we can remind you after a certain period of time. 3,500 miles div by 2.5 months = 1,400 miles per month. This means you would need to change the oil every 7.14 months @ 10k miles. If the oil analysis shows we are still good, we could take it to 12k or until the oil analysis sais we have gone far enough. We do have some customers with 5.7 and 6.1L Hemis that are going 15k miles per oil change.
http://www.chargerforums.com/forums/...d.php?t=157116
It is up to you. We would love to help protect your 3.6L like we have done for so many other customers.
Regards,
Brian
BND Automotive LLC
440-821-9040
www.bndautomotive.com
__________________
ACES IV Fuel Catalyst- "Higher HP -N- Torque w/better mileage & longer engine life... Rocket Fuel for your car!
QuantumBlue Lubricants-"Because our Custom Blended lubricants ALWAYS outperform store bought!"
QuantumBlue HP Gold Coolants -"Better than even OEM without the GUNK"
ALSO TRY: QuantumBlue Vinyl and Fabric Stain and UV Protectors.
  #5
Old 10-29-2012, 08:04 AM
DodgeCares's Avatar
DodgeCares DodgeCares is offline
Senior Member
Iam,
Once the oil change indicator is reset it will come back on based on input from multiple sensors on the vehicle. It will not take into account the type of oil you use. 6 months or 8,000 miles is the longest that you are recommended to go in the manual even if the change oil light does not come on.
__________________
Chris B.
Top Care Specialist
Chrysler Group LLC
  #6
Old 10-29-2012, 11:50 AM
IBDAGRIZ IBDAGRIZ is offline
Senior Member
Now that all of that is over. Run down to Walmart and buy ya a filter and a 5 qt jug of synthetic in your choice of flavors and change your oil. My V-6 takes more than 5 so I get an extra qt while I'm there..Mobil 1 is very good. So is pretty much any good synthetic oil on the market and almost all will get you 8k on an oil change..
Griz
  #7
Old 10-29-2012, 02:47 PM
AFPVet AFPVet is offline
Senior Member
Quote:
Griz
Yep. Although, my manual says to change at 5k for best performance with the factory syn they put in. It will go all the way to 10k with a good synthetic, but it's better to change where your manual says to get the most out of it performance wise.
  #8
Old 10-29-2012, 03:33 PM
iamstubb's Avatar
Senior Member
Thanks everyone! It's been 12 years since I bought a car and I want to take care of this one. I appreciate the difference of opinion and the useful info. I was a little worried that maybe my wife was taking the car out and testing 0-60 while I was at work, but I guess the interval is about as expected. I've always been a 3k/conventional user for my other cars (which are well beyond 200k) but I think over that time-frame synthetic or QB might be the most cost-effective.
  #9
Old 10-29-2012, 04:04 PM
370 HEMI's Avatar
Supporting Vendor
Remember this, everyone is entitled to their own opinions and will do what they feel is right. However, opinions are anacdotal and are based on feelings and what they have read or what they have done in the past or even what they have read from the marketing arms of all these oil companies.
When we discuss what QB does and compare it to what is out there on the shelves, it is by fact and by oil analysis to derive the results.......not anacdotal assumptive knowledge!
Oils have changed so dramatically in formulation in just the last 2-3 years alone due to the specifications changing by the manufacturers. These specs are pushed on them by the EPA and the government to higher Corporate Average Fuel Economy (CAFE) numbers and emission standards that are ever more strict.
Engineers that I have talked to in all the majors have repeatedly reminded me that 4.6 to 5.8 years is all the usable life they build into the cars. They remind me too that the warranty is 5 years or 100k. 5 years will be up before 100k form 90% of the customers. They get really angry when I discuss the ability to make these engine, transmission, and differential systems last 15 to 20 years if a customer wants to.
For them it is a business of turning over the cars....for us it is a love of the cars and working for the customer and not the manufacturer.
We would love to have your business and help you protect your new car.
Regards,
Brian
BND Automotive LLC
440-821-9040
__________________
  #10
Old 10-30-2012, 04:39 PM
Jonny's Avatar
Senior Member
I buy three 5 quart jugs of synthetic at Walmart, along with two Mopar oil filters. Good for two full oil changes with some left over. Costs well under $100 for 2 full oil changes, and good for up to 30k miles if you get Mobil 1 extended use.
I've done oil analysis with many oils in my car, the Mobil 1 extended use really does well, as it states.
__________________
I am the Stig
Tags
pentastar; oil; v6
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Oil change interval on 2012 R/T dmicale General Charger Discussion 29 07-28-2012 10:29 AM
dealer changes Oil Change interval? howzz1854 Charger SRT-8 Discussion 29 01-29-2011 01:22 PM
Oil Change Interval FNDelta General Charger Discussion 9 09-23-2009 09:59 PM
Oil change interval. YKW BND Automotive 13 09-18-2009 03:56 PM
Synthetic oil change interval Dodgefreak General Charger Discussion 37 03-31-2006 06:32 AM
© AutoGuide
