Break Pad Rattle...i know i know - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
  #1
Old 10-25-2012, 06:23 AM
1Sick08Charger 1Sick08Charger is offline
Junior Member
OK...i know this has been talked about plenty of times...BUT...i am getting a rattle in my front end of my 08 charger...under 30MPH....if i hit cracks in the road or uneven pavement....i get a rattle....if i apply the breaks over bumps....hard or just enough for the break light to come on the rattle goes away....i had my front end checked out and everything is tight...the guy did say it could be coming from my lower ball joints....but HOW...i apply the breaks and its GONE. i did new pads and rotors and hard wear (anti rattle clips) it still rattles....do i have to bend them more? maybe my calpiers or caplier bracket is bad or loose? has anyone had this problem and had to do something different with the pads or anti rattle clips??? and please dont say check ur struts or ball joints....trust me its not the problem...ball joint or struts dont stop making noise when the pads get pressure on them...thanks for any advice i can get
  #2
Old 10-25-2012, 04:42 PM
rsoto80's Avatar
rsoto80 rsoto80 is offline
Senior Member
Did you apply grease on the both sides of each brake pad shim?
__________________
13.84@101 mph Gainesville Raceway
  #3
Old 10-26-2012, 04:57 AM
sector 2's Avatar
sector 2 sector 2 is offline
Senior Member
Supporting Member
You might check your ball joints / bushings .....I had severe clunking w/ the same issues. When I would brake...no more clunk. Many times the culprit is either the tension strut and or the lower control arms having worn and cracked bushings...this cause metal to metal clunking and rattling. When you brake, it puts tension and loads up the suspension components.
How many miles are on your 08? Remember, we drive big heavy cars, and the suspension will take a beating. I had to change out ALL front and rear bushings (went w/ poly bushings) upper and lower ball joints, upper and lower control arms and sway bar end links. I was good for about a year.....it happened again, clunking until I brake. I never thought to check the bushing in the lower control control arm where the coil over is mounted into. Booth rubber bushings are shot.....sorry for the long winded response, but just might be suspension and not brakes......let us know.
__________________
CURRENT: 2013 Charger R/T, Super Track Pack, Forged Aluminum Wheels - other than catch can & ACES IV, bone stock!
Gone and missed...2007 RT
Marine Corps Combat Vet Plates....It's good to be home!!
  #4
Old 11-01-2012, 07:13 AM
Junior Member
Well I changed the lower control ARM ball joints....the rattle/clink sound is a lot more quiet...but still on passenger side....no more driver side noise....and it only makes the rattle over weird bumps....the mechanic told me to get caliper brackets.....any suggestions guys?
  #5
Old 11-11-2012, 02:43 AM
sector 2's Avatar
Senior Member
Supporting Member
You gotta get under the car w/ a prybar w/ the car on stands or a lift and wiggle stuff around. If you do the caliper brackets and the rattle is still there, check the bushings where the strut comes down and secures to the control arm. Check that bushing on the engine block side. Really check your upper control arm ball joints. Also I bet if you check the bushings on the control arm and the tension struts....they are probably disintegrating. You also can check the sway bar bushings. Also check inner / outer tie rods...it is a lot to check, believe me I know. Good luck.
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Can someone break this down for me squat V6 Specific Discussion 10 07-20-2011 08:47 AM
Someone Tried to Break Into my Car birddog General Charger Discussion 39 06-17-2009 07:21 AM
Break Down devicespy New England Area 10 07-11-2007 04:11 AM
Rattle in door, anyone?? & trunk rattle info taminator Charger Problems/Assistance 17 03-15-2007 02:21 PM
do I really need to break it in? LosingSleep Charger SRT-8 Discussion 6 02-06-2006 07:51 AM
© AutoGuide
