Delay in starting up... - Dodge Charger Forums
post #1 of 31 Old 06-17-2006, 10:00 PM Thread Starter
juanvaldz
Senior Member
juanvaldz's Avatar
(Thread Starter)
I've had my SXT for about 3 weeks now and I've noticed something odd.
about half a dozen times, When I've put the key and and thrned it, nothing happens.
Well, saying "nothing" may be incorrect, the dash lights up like it should but the car doesn't start.
After a short delay, 2 or 3 seconds, varooom, the engine lights off.
Durring the delay, it not even cranking.
Is this something others have seen?
Juanvaldz
Silver Steel SXT
If you cant be fast, then you gotta look Damn good going slow
juanvaldz is offline
post #2 of 31 Old 06-17-2006, 10:04 PM
HKLEVI
Supporting Member (Lifetime)
HKLEVI's Avatar
Garage
Re: Delay in starting up...
Durring the delat, it not even cranking.
Holy cr@p...I thought my SXT did that due to the engine kill the dealer put on interacting with the alarm I put on. It would come and go but when I traded it in, it had been doing it at every start up for a couple of weeks. Knowing this, take that sucker to the dealer ASAP!
Quote:
FWIW- I'm not much of a fan of displaying my profession off-duty unless it involves the display of my handgun and badge simultaneously to a turd.
-- Green_Manalishi
2006 Bright Silver Metallic Charger R/T
President, Alamo City LX Modern Mopar
USAF SF (Ret)
HKLEVI is offline
post #3 of 31 Old 06-18-2006, 10:17 AM
arfur
arfur's Avatar
Sounds like a sticky relay, or bad joint somewhere. Although the management system has to do many checks, if you turn the key to start, it should at least turn-over almost straight away. Although it won't fire straight away.
Don't Hassle the HOFF
Arf - expert in
and
arfur is offline
post #4 of 31 Old 06-18-2006, 02:11 PM
mnunes
mnunes's Avatar
I noticed this only once and it was after removing fuse 11 to reset the computer then replacing it. The first start was a bit delayed.
I don't remember if the engine will even start without fuse 11 in place (or blown). You might want to check that.
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #5 of 31 Old 06-19-2006, 11:33 AM
mattbrown
Junior Member
My 3 week old SXT started doing this exact thing this morning. Think I'm gonna reset the computer and see if it fixes it. I'll report back.
Matt
mattbrown is offline
post #6 of 31 Old 06-19-2006, 11:47 AM
mattbrown
Junior Member
I pulled Fuse 11 and waited a few minutes and replaced it. It had zero effect. The car still takes 2 seconds or so before it fires. BTW (for mnunes), the car will not start at all if you don't have that fuse in.
Matt
post #7 of 31 Old 06-19-2006, 02:41 PM
ZMagnum
Senior Member
ZMagnum's Avatar
It's totally normal.
From fnkychkn on LXForums.com:
Normal condition due to the (ETC) Electronic Throttle Control. The engine controller will do a calibration of the throttle body at every start. If you turn the key slowly you may never experence this delay.
If you turn ignition switch very fast there could be a delay of up to 2 to 3 seconds before vehicle cranks.
This condition will occur on all vehicles that have ETC.
'08 Stone White Dodge Magnum R/T
MySpace Page -
TheAutoLog Page -
ZMagnum is offline
post #8 of 31 Old 06-19-2006, 03:51 PM
HKLEVI
HKLEVI's Avatar
Garage
So why does it come and go???
HKLEVI is offline
post #9 of 31 Old 06-19-2006, 04:00 PM
ZMagnum
Senior Member
ZMagnum's Avatar
Quote:
You got me. It may be due to different amounts of time to do the calibration. I just turn my key more slowly. The delay stopped.
Don't hop into an LX if a zombie is chasing you.
ZMagnum is offline
post #10 of 31 Old 06-19-2006, 04:42 PM Thread Starter
juanvaldz
Senior Member
juanvaldz's Avatar
(Thread Starter)
I like the Zombie comment.... Note: That is only for New Age zombies... The fast ones like in the remake of "Dawn on the Dead" or "28 Days"
Old school zombies are a bit slower, even with the delay, I'm good to go with the SXT. But New age zombied will require a upgrade to an R/T
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Delay in Power mississaugamadman Canada / Mexico 3 08-12-2006 05:14 PM
Headlight delay gHEMI speed General Charger Discussion 2 06-03-2006 07:46 AM
ps3 delay official.... GoDaddy Off-Topic 11 03-15-2006 09:05 AM
I DID IT!!!! sorry for the delay BetoMXL General Charger Discussion 13 02-17-2006 09:55 PM
Is there an R/T delay? SEDave General Charger Discussion 8 07-27-2005 11:01 AM
You may post new threads
You may post replies
