dome lights, trunk release not working - Dodge Charger Forums
Interior Discussion/Modifications Discussion about modification of the interior of the vehicle. Such as the addition of mp3 players, dash kits, etc.
post #1 of 14 Old 06-16-2006, 10:23 AM Thread Starter
davidhSRT8
Senior Member
davidhSRT8's Avatar
(Thread Starter)
I'd appreciate a little help.
I plugger a phone charger into the cig. lighter outlet, and a small piece fell out causing a short. Now the dome lights, the a/c back lights, and the trunk release button don't work. I reviewed the owner's manual fuse chart I can't find which fuse(s) need to be replaced.
Thanks guys!
I'm a friend of Bill W since Feb 5, 2003
ALL GONE:
2006 Midnight Blue R/T
NOW: 2007 Black Pearl SRT8 fully loaded
davidhSRT8 is offline
post #2 of 14 Old 06-16-2006, 10:26 AM
Crazy_luck
Senior Member
Crazy_luck's Avatar
Send a message via AIM to Crazy_luck Send a message via Yahoo to Crazy_luck
Re: dome lights, trunk release not working
Did you use the lighter in the dash or the outlet in the center console? What kind of piece fell out?
Crazy_luck is offline
post #3 of 14 Old 06-16-2006, 10:30 AM Thread Starter
davidhSRT8
Senior Member
davidhSRT8's Avatar
(Thread Starter)
Hey Crazy. It was the outlet directly under the a/c, the cig lighter outlet. The piece was the tip of the phone charger. I removed the piece, but I saw a small arc/spark when it fell in.
post #4 of 14 Old 06-16-2006, 10:35 AM
Crazy_luck
Senior Member
Crazy_luck's Avatar
I can't remember the fuse # off the top of my head, but I'm sure I know which one it is. I was going to tap into it for something else since that one looses power when the ignition is off.
post #5 of 14 Old 06-16-2006, 10:35 AM
potsyboy
Senior Member
potsyboy's Avatar
Quote:
The cig fuse is located in the trunk search for the "adding a sub" thread it's the fuse used to power the amp. The small piece you speak of sounds like the fuse located in the phone charger.
Black SRT8 - Tinted tails/windows, Removed side molding, Illuminated Door Sills, Dodge Ram hood emblem replaced, LED lighting, Custom HID Projector Retrofit & AAC Halos.
"Last night I played a blank tape at full blast. The mime next door went nuts!"
potsyboy is offline
post #6 of 14 Old 06-16-2006, 10:45 AM
potsyboy
Senior Member
potsyboy's Avatar
Found the thread, see fuse #18
potsyboy is offline
post #7 of 14 Old 06-16-2006, 10:52 AM Thread Starter
davidhSRT8
Senior Member
davidhSRT8's Avatar
(Thread Starter)
Thanks Pots. I replaced fuse #18 with a yellow 20 amp fuse, but no joy. Does #18 also control the trunk release, dome lights and a/c lights?
post #8 of 14 Old 06-16-2006, 11:19 AM
TJchargerRT
Senior Member
TJchargerRT's Avatar
I am more than positive that its fuse 18 because it was one of the fuses i blew a couple weeks ago. I lost the Dome lights and the trunk release so if replacing the fuse didnt help you might have to bring her to the dealer for service.
Watch the Best VIDEO Ever
TJchargerRT is offline
post #9 of 14 Old 06-16-2006, 11:58 AM Thread Starter
davidhSRT8
Senior Member
davidhSRT8's Avatar
(Thread Starter)
Thanks TJ, I'll double check, but I'm certain I replaced it. I'll post my results.
-David
post #10 of 14 Old 06-16-2006, 12:34 PM
rossb
Senior Member
rossb's Avatar
Location: Admit nothing, Deny everything, Make counter accusations
See my thread here:
http://www.chargerforums.com/forums/...ead.php?t=9480
The soution to my problem is on page 2 of the thread.
rossb is offline
  Dodge Charger Forums > Dodge Charger Discussion > Interior Discussion/Modifications
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
CD Player Not Working CanadaGuy Charger Problems/Assistance 4 07-20-2006 07:10 PM
Trunk Release Button Zylonist Interior Discussion/Modifications 4 07-11-2006 06:41 AM
Dome Lights Mikey0o0o Interior Discussion/Modifications 12 04-20-2006 09:20 AM
Dome Stickers-Problems and Solution RJ Schuff Exterior Discussion/Modifications 3 04-19-2006 12:34 PM
Anyone working on xmas?? BetoMXL Off-Topic 12 12-23-2005 07:12 PM
You may post new threads
You may post replies
