86760 miles on 7 oil changes...continuing proof..... - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Supporting Vendors > BND Automotive
  #1
Old 07-19-2012, 09:18 PM
370 HEMI's Avatar
370 HEMI 370 HEMI is offline
Supporting Vendor
Many wonder what will happen to my engine if I use QuantumBlue over the long haul. One individual oil change.....all by itself......is a data point but not all inclusive.
This has been a long term validation of what our formulas do in a regular 5.7L MDS Hemi run every day in typical use......using a Predator and modifications as well.
Jed's OCD has now gone 86,760 miles on 7 oil changes. He is averaging 12,394.29 miles per oil change.
Like Kid Rock likes to say......."it aint arrogence if you can prove it!"
Well these numbers do not lie about the protection of QuantumBlue Custom Blends.
His most recent is 14,899 miles on one change!
At the beginning, he started at 30,928 miles when he switched from Mobil 1 to QuantumBlue for his first oil change.
From that point, the oil changes went like this:
12,307 miles
11,286 miles
12,000 miles
11,106 miles
12,401 miles
12,761 miles
14,899 miles on his most recent one!
17 ppm iron divided by 14.899 = 1.14 ppm per 1000 miles!
0 chromium....no ring wear!
0 lead....no bearing wear!
4 ppm aluminum div by 14.899 = 26.8 100ths of 1 ppm per 1000 miles!
0 nickel....no valve wear!
So basically this engine now has 117,252 miles with the oil keeping this engine from wearing basically at all.
What are the dollars and cents?
Using this months special as an example.....$12.76 per quart x 7 = $89.32 + free oil filter = $89.32 + $15.75(shipping from Ohio to California) = $105.07.
$105.07 div by 14.899= $7.05 per 1000 miles.
Typical off the shelf synthetics are $6.75 per quart x 7 = $47.25 + $6.50 for an oil filter = $53.75 x 1.07 (tax) = $57.51.
$57.51 div by 5 = $11.50 per 1000 miles....assuming a 5k mile oil change.
So for 14,899 miles with typical synthetics would be $11.50 x 14.899 =$171.34!
Also, Jed gets to keep 2.3 hours of his life doing something else besides waiting in a service facility room while his oil isn't changed as often!
So yes, price is a one time thing, but cost is a life time thing! Cheaper to use and better protection......best of both worlds.
Regards,
Brian
BND Automotive LLC
440-821-9040
www.bndautomotive.com
__________________
ACES IV Fuel Catalyst- "Higher HP -N- Torque w/better mileage & longer engine life... Rocket Fuel for your car!
QuantumBlue Lubricants-"Because our Custom Blended lubricants ALWAYS outperform store bought!"
QuantumBlue HP Gold Coolants -"Better than even OEM without the GUNK"
ALSO TRY: QuantumBlue Vinyl and Fabric Stain and UV Protectors.
  #2
Old 07-19-2012, 09:39 PM
Cuts2TheBone's Avatar
Cuts2TheBone Cuts2TheBone is offline
Senior Member
can someone else verify this information this is a good result test for this engine. As I just dont honestly have a clue what is a "good" return results for all this "ingredients". Now Im still fairly skeptical regarding this whole bnd stuff and custom blend ect. However you said this oil change is 15k miles? what excatly are your intervals...im not worried about miledge but more so in duration of time...My car is strictly a fun car for me so i dont even hit 6k in 6 months unless i just went on vacation with it like that past week, so sometimes i feel like throwing money down the toilet when its only 3k on sythenic and its at 6 months and the book is very clear about changing at mile interval or time interval whichever comes first. I just have one last oil change with mobil 1...and I just might contemplate switching to try this "magic" stuff if the time interval is longer than 6 months.
__________________
https://www.youtube.com/user/ChargerSRT392?feature=mhee
Always looking for a good run
2012 Charger SRT8 Blue Streak Pearl
12.53@ 110! Stock
Goal - Low 11s with just a Procharger..no DRs.
2009 Tored Charger SRT8 - Gone but not forgotten.
  #3
Old 07-19-2012, 09:41 PM
PlumCrazyDaytona's Avatar
PlumCrazyDaytona PlumCrazyDaytona is online now
Senior Member
Send a message via MSN to PlumCrazyDaytona Send a message via Yahoo to PlumCrazyDaytona
WOW!!
That is pretty cool. Its hard to imagine that I only need to change oil once every two years...But again and again I keep seeing proof!
Thanks for posting up
__________________
6.1 Intake manifold,SRT MAX cam on 112lsa, CNC Inertia Heads milled,mopar TCM,blue tops, 3000 Edge converter 3.91 Getrag, JBA shorties, catless mids and SLP Loud Mouth I, powerbond undrive pulley, 170 tstat, , R1 crossdrilled/slotted rotors, HAWK Pads, #157 of 1400 ACES IV Quantum Blue Lubricants PB 1/4 12.38@110.66, without 6.1 intake...
http://s182.photobucket.com/albums/x...2-12-13-01.mp4
http://s182.photobucket.com/albums/x...=VIDEO0010.mp4
  #4
Old 07-19-2012, 11:04 PM
370 HEMI's Avatar
Supporting Vendor
Quote:
I will be happy to post some examples of "good oil analysis" comparisons that are considered normal. Also will post where these different metals come from.
Any good analysis will have 3 sections.....wear metals, contaminants, and additive packages. This is why we like ALS as they break them out well.
Just to be fair though, here is one from Royal Purple on a WRX with 6,500 miles on the change. Blackstone said this was a "good" sample.
Look at the iron, chromium, lead, aluminum and nickel. Remember that we are looking at numbers from 6,500 vs 14,899. This sample from Royal Purple is 2.29 times less mileage with more wear!
With all due respect, you can't get better than zero. If you can reduce the chromium, lead, and nickel, those are the moving wear metals you want to really focus on!
Here is another sample from ALS on a 5.7L Hemi with just over 40k miles using Mobil 1 and 4,900 miles on the sample. Similar year, type, and usage temps and conditions:
Look at the iron, chromium, lead, aluminum, and nickel. Compare it with our 14,899 sample. This is more than 3 times less mileage on the Mobil 1 with much more wear!
Here is an example of where these different ingredients come from:
Basically 101 miles less than 15k miles.
what excatly are your intervals...im not worried about mileage but more so in duration of time...My car is strictly a fun car for me so i dont even hit 6k in 6 months unless i just went on vacation with it like that past week, so sometimes i feel like throwing money down the toilet when its only 3k on sythenic and its at 6 months and the book is very clear about changing at mile interval or time interval whichever comes first.
We recommend initially 10k miles. After that, we move up based on actual oil analysis. If we know you are going to use the car for fun and not even get to the miles in 6 months we can blend the oil to incorporate the longer interval time wise before you get to the higher mileages so that you don't have to dump it constantly every 6 months etc. 1 change can last for 2 years if it is under the 10k miles.
Here is a 6.1L Hemi Challenger with 15k miles on one change....12.5w40. Again, you can see the iron, chromium, lead, aluminum and nickel. Similar results show consistency!
We would make a 5w40 QuantumBlue Ultra High Performance 6.4L VVT Cam Phaser Custom Blend for your new 2012. We would just use the compendium of knowledge gleaned from all the analysis results of our 40,000+ customers to produce exactly what you would need!
Regards,
Brian
BND Automotive LLC
440-821-9040
__________________
  #5
Old 07-20-2012, 10:03 PM
370 HEMI's Avatar
Supporting Vendor
Quote:
Originally Posted by PlumCrazyDaytona View Post
WOW!!
D. Glad you had a chance to see the results from Jed's car. He was very happy to see how far he could go. From what I gleaned from him, he didn't really mean to go quite that far, but he was so busy with work that it just racked up that fast.
Extra protection where and when you need it.
Regards,
Brian
BND Automotive LLC
440-821-9040
__________________
  #6
Old 07-20-2012, 10:14 PM
bigjim.srt-8's Avatar
bigjim.srt-8 bigjim.srt-8 is offline
Senior Member
This is the real deal with a real Guy.
Jed is a good friend and Part of our So Cal car club Mopar360.
His car runs great and Jed drives this car in the extreme heat out here non stop.
__________________
Jim,
07 TORRED SRT-8- Option Groups I, II, III... Demolded
Mopar Cold Air Intake and JBA Exhaust With 5" tips, Jet 180 T-stat, Diablo Predator Tuner, BT Catch Can
BT mods-Front and Rear Emblems,Front and Rear Sill Plates,Fender Badges,Underhood Kit
V-1 Radar Detector,R1 Drilled and Slotted Rotors, Powdercoated Alloys with Toyo Proxes ST's
  #7
Old 07-22-2012, 01:05 PM
370 HEMI's Avatar
Supporting Vendor
Jim,
Thank you for verifying that Jed is a real person with a 2008 Charger R/T 5.7L MDS Hemi and that it runs good using our products!
Regards,
Brian
BND Automotive LLC
440-821-9040
__________________
  #8
Old 07-23-2012, 08:30 AM
Devils6's Avatar
Devils6 Devils6 is online now
Senior Member
how much for the coolant and transmission fluid kit..
Sent from my DROID RAZR using AutoGuide.Com Free App
__________________
2010 Dodge Charger V-6, Black. Mods- Mopar T shifter, new victory stripe dodge logo, chin spoiler, cold air intake, ZEX wet, 75 shot, Zex spark plugs, Quantum Blue oil and Filter, Zex purge kit, custom magnaflow exhaust.
Wish list
predator tuner
Inertia 1.1 or 1.0 cams
SRT -8 hood
  #9
Old 07-23-2012, 07:58 PM
370 HEMI's Avatar
Supporting Vendor
The coolant is $72.98 for 2 gallons of concentrate. Use distilled water at a 50/50 mixture and you will be good for 5 years or 150k miles.
The transfluid....Hemi/3.5L Transmission Pan Drain and Fill Special: 8 quarts QuantumBlue transmission fluid appropriate for 42RLE and NAG1/W5A580 transmission + QuantumBlue Transmission Filter Kit - 4 speed....42RLE-$130.08 and 5 speed.....NAG1-$142.58.
Regards,
Brian
BND Automotive LLC
440-821-9040
__________________
  #10
Old 07-23-2012, 09:56 PM
tbl01 tbl01 is offline
Member
So here's another take of equal consideration. This is an apples to apples comparison long term(miles) user as well.
Using this oil analysis 2006 hemi rt 187k miles mutiple changes over 10k miles Penzoil Platium, not ultra.
http://www.bobistheoilguy.com/forums...2566052&page=1
Okay.
Walmart ...Penzoil Platium synthetic are $5.00 per quart x 7 = $35.00+ $6.50 for an oil filter = $41.50 x 3.63(NYtax) = $45.13. ( If you get it on sale it will be even cheaper)
$45.13 div by 15.05 = $3.00 per 1000 miles....based on a 15,053 mile oil change.
So the savings for using a top off the shelf synthetic is $105.07-$45.03 = $59.94 So with today's oil change..... included in the cost of the oil change is night out with the family at Playland, or 16 gallons of gas.
So yes, price is a one time thing, but cost is a life time thing! Cheaper to use and equivelent protection at least for this comparison......best of both worlds.
Let me be clear I'm not saying its not a good or even great oil ...it appears to be great, but for me I cant justify the 250% plus price differential. If I run P.Platium in my car and can get consistent numbers as shown in the link above its a cost effective alternative route.
__________________
2012 Charger RT R&T, STP, Bluestreak Pearl
2003 Mach 1 sold
2001 Cobra Sold
1989 928 S4
1967 GT Fastback A-code (under restoration)
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Death PROOF Alexcharger07 Picture/Media Post 13 03-07-2009 11:36 AM
diablo > SC - proof! tehee dudeiwin86 Performance Discussion/Modifications 19 09-06-2007 04:53 PM
Proof that money is EVERYTHING goval Off-Topic 55 06-09-2007 01:04 PM
© AutoGuide
