Phone connection issues - Dodge Charger Forums
General Charger Discussion General Discussion about the Dodge Charger.
post #1 of 11 Old 04-18-2012, 10:10 PM Thread Starter
Tinman93
Senior Member
Tinman93's Avatar
(Thread Starter)
I am having trouble getting my phone to connect and stay connected to my radio. I have a Droid Bionic. Sometimes it will connect just fine as I get in and out of the car. Other times, it refuses to connect or stay connected unless I totally restart the phone. It is a pain. Has anyone had similar issues or can anyone offer any insight?
Tinman93
2012 Pitch Black Charger
RT Max AWD
Tinman93 is offline
post #2 of 11 Old 04-19-2012, 12:03 PM
GMG1411
Senior Member
GMG1411's Avatar
I never had any issues with my Droid in car, until the most recent O.S. update. Now it seems to connect and disconnect from car bluetooth at will.
Dunno if that's the same issue you're having.
Previous proud owner of a 2006 Daytona R/T in GoManGo #1411
Now a proud Ram1500 owner.
GMG1411 is offline
post #3 of 11 Old 04-19-2012, 10:04 PM Thread Starter
Tinman93
Senior Member
Tinman93's Avatar
(Thread Starter)
Pretty much the same issue for me. It's a real PITA. Sometimes it will connect without restarting. Sometimes that won't even work. I love it when it works but get really frustrated messing with it. I am open to suggestions if anyone has any.
Tinman93 is offline
post #4 of 11 Old 04-19-2012, 10:56 PM
DigbyAllen
Member
I have the same problem. I've gotten into the habit of checking if the phone is connected after I start the car but before shifting out of park. Usually it is paired, but occasionally I have to fool with it. It's annoying but I look at it as just one more thing to double check before driving.
DigbyAllen is offline
post #5 of 11 Old 04-20-2012, 06:13 AM Thread Starter
Tinman93
Senior Member
Tinman93's Avatar
(Thread Starter)
Quote:
What seems to work for you when it is not paired? Mine seems to be getting more difficult to connect.
Tinman93 is offline
post #6 of 11 Old 04-20-2012, 12:42 PM
DigbyAllen
Member
The last time I took my car to the dealer I mentioned this problem, and they said they have heard of it but couldn't find anything wrong. They did update the firmware to the latest version but I've had problems since then so that wasn't a cure all. The problem is intermittent and I can't figure out the pattern, if there is one.
For the first 2-3 months I owned the car (bought new) it worked perfectly. Then one time after that I was surprised when my phone rang while I was driving but the car didn't pick it up. Of course you can't reconnect the pairing while you're driving, but it might be nice if you had a passenger that they could do it, but it doesn't work that way. You have to be stopped.
What seems to work best for me is I put my phone into discovery mode and then let the Charger find it i.e initiate the pairing from the car. If that doesn't work, then I do the reverse, let the phone find the car. One time I couldn't get anything to work, so I actually deleted the bluetooth entry in both the phone and the car and did the pairing process all over again. I turned off the car after deleting, and before reconnecting the phone. I'm not sure if this is necessary but I thought of it as rebooting the computer and starting up clean.
I've never not been able to connect, but sometimes I have to try a few different things. Knock on wood it's been fine the past couple of weeks but like I said I've gotten into the habit of checking the pairing before shifting into drive so at least I'm not surprised to learn that it's not paired while driving when you can't fix it.
post #7 of 11 Old 04-20-2012, 12:51 PM
jackyy
Senior Member
jackyy's Avatar
Haven't had any problems with my Thunderbolt
07 Crystal Black Pearl R/T w Road & Track, fully loaded, 35% Tint, DEI Hood Scoop, Mopar CAI, Mopar vent shades, Brylcreemed
jackyy is offline
post #8 of 11 Old 04-20-2012, 04:37 PM Thread Starter
Tinman93
Senior Member
Tinman93's Avatar
(Thread Starter)
That's good to know. I didn't realize it wouldn't pair while driving. I think I will delete the device and start over. I was already thinking of the rebooting analogy, so hopefully that will help. Thanks for the tips.
Tinman93 is offline
post #9 of 11 Old 04-20-2012, 05:07 PM
SmittyRN
Member
I'm having issues with my Samsung Galaxy S2; I'm running a custom version of Ice Cream Sandwich on it, and I can't seem to keep it paired right now. It's hard to keep a bead on it, because I've been trying out several different setups on the phone for the past couple of weeks, but today I paired it, and it wouldn't work later. So I deleted it, re-paired it, and it worked fine until I shut the car off; when I came back, same problem. I'm going to spend some time over the next few days trying to figure out what is up. Good to know it isn't just my phone.
2012 Dodge Charger Blacktop
"Black Betty"
SmittyRN is offline
post #10 of 11 Old 04-20-2012, 10:19 PM Thread Starter
Tinman93
Senior Member
Tinman93's Avatar
(Thread Starter)
Thanks. If you find a solution let us know.
Tinman93 is offline
  Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
2011 Steering Wheel Controls Issues EVIC, Uconnect, Phone, Horn jpescalante Charger Problems/Assistance 3 07-14-2011 08:10 AM
AVIC-F700BT bluetooth connection issues Nomad^Phoenix Audio - Alarms - Navigation - Electronics 11 07-29-2009 07:11 PM
Hands Free Phone ISSUES white06r/t Interior Discussion/Modifications 6 10-27-2006 02:25 PM
You may post new threads
You may post replies
