sunroof not working fuses good? - Dodge Charger Forums
post #1 of 6 Old 04-09-2012, 03:57 AM Thread Starter
chargersxt06
Member
(Thread Starter)
i have a 06 charger sxt i lost my manual so i didnt know what fuses to check so i checked them all im pretty sure there all good the ones in the trunk, any other ideas? it doesnt make any noise or anything when i try to open or vent it
BB CAI, 91 Tune, Custom Duals, 35% tint in front - 20% tint in back, Super White LED Dome Lights, Pirelli P4 tires, still to come Ported TB, JBA Shortys, Alarm/Remote Start, Dbl Din, Eibach Pro System and much more!!
chargersxt06 is offline
post #2 of 6 Old 04-09-2012, 05:26 PM
richd
Senior Member
Quote:
I have the same car.The fuse for the Sunroof is in the rear PDC,Fuse might say audio amplifier,but thats the fuse for it #44,Make sure its good,and make sure its in tight,some on here found it loose,and solved their problem,Good Luck
richd is offline
post #3 of 6 Old 04-09-2012, 05:32 PM Thread Starter
chargersxt06
Member
(Thread Starter)
Quote:
so i checked the fuse several times #44 and its looks ok i will test it with a meter when i get home but water did leak in one winter through the sunroof could the motor be fried?
post #4 of 6 Old 04-09-2012, 06:13 PM
richd
Senior Member
Possible,or could be a bad connection from leak,if fuse checks out,then you might have to check the motor and wiring.If it was wet,hope that the fuse blew before damaging motor.
richd is offline
post #5 of 6 Old 04-10-2012, 05:23 PM Thread Starter
chargersxt06
Member
(Thread Starter)
so when i pull the fuse #44 my radio shut off to is that the right one?
post #6 of 6 Old 04-10-2012, 10:22 PM
richd
Senior Member
Yes thats the one,its for audio amp,&sunroof,Im giving you the TSB that tells how to reset sunroof,when you get it working :
http://www.wkjeeps.com/misc/LX/TSB_3...SB_2304006.pdf
richd is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Sunroof/Moonroof stopped working 1badblkhemi Charger Problems/Assistance 0 05-01-2011 07:08 AM
Sunroof quit working - where to start? DzlsHers Interior Discussion/Modifications 13 04-04-2011 07:27 AM
EVIC Not working good?? LtX Audio - Alarms - Navigation - Electronics 0 02-24-2011 08:56 PM
SWEET!!! Cheap sunroof option for non-sunroof cars. 69&07Chargers Exterior Discussion/Modifications 61 08-23-2007 08:07 AM
Fuses and Dealer Alarm?? Fuses 28-42??? Bluonyx Charger Problems/Assistance 1 10-12-2005 03:30 AM
You may post new threads
You may post replies
