2.7 Spark plug Change Tutorial With Pics - Dodge Charger Forums
V6 Specific Discussion This area is for discussion about V6 powered Dodge Chargers.
post #1 of 12 Old 04-04-2012, 07:13 PM Thread Starter
JBoat
Member
JBoat's Avatar
(Thread Starter)
I just changed the spark plugs in my 2006 2.7 SE charger. I just turned 85,000 miles and started to notice a bit of stumble off idle. Now she's running buttery smooth again. I figured I'd post up some pics and tips on how to do it since I couldn't really find anything on the internet with pics...
The upper intake manifold needs to be removed to access the 3 passenger side plugs. It's not that hard to do yourself and only requires basic hand tools and a little mechanical know how...
Tools required:
10mm socket
13mm socket
10" extension
5/8 spark plug socket (I used one with and one without the rubber boot)
Flathead screwdriver
Feeler Gauges to set check gap
Anti Seize
Dielectric grease
I also used a 10mm T-handle for the intake bolts.
1) First step is to remove the negative battery cable (located in trunk under the carpet). 10mm socket. Also blow any dirt or debris off the motor with an air hose or vacuum.
2) Unplug the following connectors. Press the little tab in the center and firmly pull back.
IAT
Throttle body
3) Remove your intake or airbox. I have an aftermarket one so i just loosened the hose clamps from the throttle body, unplugged the IAT sensor and hose and pulled it off.
4)Then unplug the 3 hoses on the rear of the intake. The larger one with the metal lip is easier to pull all the way out once the intake bolts are all loose. I was able to angle it forward while gently pulling the hose back. It's very stiff so don't break it!
before
after
The 3 rear vacuum hoses unplugged. This pic also shows the wire harness connectors from the throttle already unplugged.
4)Unplug this vacuum hose:
I also removed the dealer service cap and placed it aside.
5) Remove the 2 intake support brackets on the passenger side from the intake studs. Upper is a 10mm and lower is a 13mm. I just loosened the bottom 13mm ones and wiggled it off the studs and left them in place.
6) Loosen all 7 upper intake bolts (10mm) I fully loosened them and left them in the holes.
These 7 bolts.
7) Lift up on the intake and gently pull it off. It takes a bit of finagling to get it around the dealer service tube so take your time and angle the front up and to the right and it will come off. Carefully set it aside out of the way. I used a clean rag to cover the intake ports so nothing falls in.
Intake removed
Here is what you will see. As long as the rubber gaskets are not torn or damaged you can reuse them.
Passenger side coil packs.
One coil pack removed.
Stock plug pretty worn out.
8) Remove the coil pack wire by pushing down on the tab in the middle and pulling straight back. Then remove the 10mm bolt. The coil pack will then pull straight up and out. Get your long extension and 5/8" plug socket and remove the old plug. I did them one at a time. It helps to have two 5/8" spark plug sockets, one with the rubber grip boot and one without. I use the rubber boot one to remove the old plug and to insert the new one and get it started. Then I tighten it with the other socket so I can pull it out of the hole. I tighten them to snug plus 1/8 turn. I use anti seize on the plug threads and dielectric grease inside the coil pack. They were gapped at .050.
8) Reinstall everything in reverse order. The intake bolt torque is 12nm. The torque sequence is as follows.
9) Make sure all the connectors and vacuum hoses are properly reconnected and then reconnect the negative battery cable and start the motor. Hopefully it fires right up and idles smooth...
Overall it took me about a 1.5 hours, but now that I know how to do it I can probably do all 6 in about 45 min to an hour...That water housing leak is next on my list...
(Disclaimer: I am not a professional mechanic and this is just for reference. If you are unsure of any of the following procedures, take you car to a shop. Also a factory service manual is highly recommended. Work on your car at your own risk!)
JBoat is offline
post #2 of 12 Old 04-04-2012, 07:23 PM
PlumCrazyDaytona
Supporting Member (Lifetime)
PlumCrazyDaytona's Avatar
Send a message via MSN to PlumCrazyDaytona Send a message via Yahoo to PlumCrazyDaytona
Very nice write up!!!
6.1 Intake manifold,SRT MAX cam on 112lsa, CNC Inertia Heads milled,mopar TCM,blue tops, 3000 Edge converter 3.91 Getrag, Kooks LongTubes, catless mids and SLP Loud Mouth II, powerbond undrive pulley, 170 tstat, , R1 crossdrilled/slotted rotors, HAWK Pads,eibach lowering springs,dampners,sways mopar strut braces, razors edge sub frame connectors #157 of 1400 ACES IV Quantum Blue Lubricants PB 1/4 12.38@110.66
PlumCrazyDaytona is offline
post #3 of 12 Old 04-04-2012, 07:29 PM
neonsox
Banned User
Nice write up, good photos!
neonsox is offline
post #4 of 12 Old 04-04-2012, 09:21 PM
mnunes
mnunes's Avatar
Great job! I've added it to the "How do I Everything" thread
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #5 of 12 Old 04-04-2012, 09:26 PM Thread Starter
JBoat
Member
JBoat's Avatar
(Thread Starter)
Thanks. Hopefully someone out there can benefit from this. I searched the web and all I could find was 3.5 and 5.7 info...
Don't be afraid to do this yourself people...
JBoat is offline
post #6 of 12 Old 04-05-2012, 07:15 AM
Stumblin Steve
Stumblin Steve's Avatar
Nicely done and well documented!
My time is coming up for the spark plug change.
Just your friendly neighborhood...Charger
'08 SXT Bright Silver. Dark slate interior. OEM MOPAR pedals/hood struts/CAI/Chin Spoiler. R/T true dual exhaust w/ Magnaflow tips. SRT8 rear diffuser. Predator 93 Tune. Lots of
Stuff!
Join the
Stumblin Steve is offline
post #7 of 12 Old 04-05-2012, 07:36 AM
PlumCrazyDaytona
That's awesome you are one of the select who are a part of the "how do I do evertyhing thread"
Way to go!
post #8 of 12 Old 04-08-2012, 05:58 PM
Adeptus
Member
Great job, very proffesional.
Adeptus is offline
post #9 of 12 Old 07-27-2012, 01:10 PM Thread Starter
JBoat
Member
JBoat's Avatar
(Thread Starter)
Sorry if the pics weren't available for a while. I guess I exceeded my Photobucket bandwidth. It shouldn't happen again since I upgraded. I don't come on here much anymore since I sold the Charger a couple of months ago. Now I have a 2012 Challenger V6 (Blue streak pearl). I did sign up at the Challenger forum, but I haven't posted yet since I plan to keep it bone stock...
Happy wrenching!...
JBoat is offline
post #10 of 12 Old 07-20-2013, 12:39 AM
truckdriver1968
Junior Member
I have a question for you. The foam padding that is in the 13th pic Is that suppose to be there at all times because I did mine last weekend and when I pulled the manifold off it wasn't there. Back in January the dealer replaced the head gasket's on my charger and I've been having over heating problems since.
truckdriver1968 is offline
  Dodge Charger Forums > Dodge Charger Discussion > V6 Specific Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
First spark plug change - 10 minutes or more to recognize the new plugs? Bignanner Charger Problems/Assistance 17 01-09-2017 04:12 AM
Spark Plug Change YouLoveMegan Charger Problems/Assistance 3 09-03-2010 10:32 AM
Spark Plug Change DaytonaR/T1613 General Charger Discussion 12 08-30-2010 06:20 PM
2.7 spark plug change $treetKing V6 Specific Discussion 5 06-09-2009 02:56 PM
Spark Plug Change ChargerOsix Performance Discussion/Modifications 65 09-28-2007 07:47 AM
You may post new threads
You may post replies
