Location of rain sensing sensor - Dodge Charger Forums
General Charger Discussion General Discussion about the Dodge Charger.
post #1 of 9 Old 02-27-2012, 10:38 AM Thread Starter
Sublime1199
Senior Member
Sublime1199's Avatar
Send a message via MSN to Sublime1199
(Thread Starter)
Hi guys, I just bought a 2011 Mopar 11 with the rain sensing option. Where is the sensor located? Is it that sensor located under the rear view mirror?
Sublime1199 is offline
post #2 of 9 Old 02-27-2012, 12:11 PM
GLHS837
Super Moderator
GLHS837's Avatar
I believe so. Easy to test with a spray bottle
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
GLHS837 is offline
post #3 of 9 Old 02-27-2012, 12:23 PM Thread Starter
Sublime1199
Senior Member
(Thread Starter)
Quote:
Thanks. I was driving to work this morning and it started to sprinkle but the wipers did not come on even though I have the setting turned on. It then occurred to me that my radar detector might be blocking the sensor so I will have to do some testing when I get home tonight.
post #4 of 9 Old 02-27-2012, 05:48 PM
YatBob
Member
The wiper switch needs to be in the intermittent position for the auto wipers to work, see page 200 in the owners manual
YatBob is offline
post #5 of 9 Old 02-28-2012, 08:43 AM Thread Starter
Sublime1199
Senior Member
(Thread Starter)
OHHHH DUH! Thanks, I was able to get it working :-)
post #6 of 9 Old 02-28-2012, 09:06 AM
MKMotorsport
Senior Member
If I'm not mistaken (which I very well could be), It takes 6-8 'sweeps' of the wipers to put an AWD car into AWD if it was previously in RWD. Not sure if this is the same? Or are you saying if the wipers are left in the intermittent mode (maybe lowest setting?) there is an actual external sensor that detects water that would automatically start the wipers?
I know the 'humidity sensor' is inside the vehicle and relates to HVAC actuation, specifically the front/and maybe rear defroster activation while in auto climate control mode... hmmm.....
2011 R/T AWD, factory order. 4627 lbs. Best ET/MPH, 9/21/11- 13.462@103.636 (sea level corrected). Bandimere Speedway, 5800ft above sea level. Fastest stock '11 AWD? (Not stock now- Jet 180 stat, BBK 85mm w/port match, Frankentake, figuring out exhaust...) Have NOT run modded YET
MKMotorsport is offline
post #7 of 9 Old 02-29-2012, 08:31 AM
YatBob
Member
Quote:
That's the way it works, the sensor is behind/built in the rear view mirror, the only issue I have is that the turn on headlights with wiper function is hit or miss with the auto function, sometimes it works sometimes not
YatBob is offline
post #8 of 9 Old 03-05-2012, 10:16 AM
MKMotorsport
Senior Member
Ah cool! I think that's what the small "clear/opaque" square is behind the rear view mirror. Must be a photosensor that either detects the light/dar transition of the wipers passing (initially), or that is sensititive enough to actually detect droplets of water on the windshield....anyway, very cool! I was wondering what that square was, LOL
post #9 of 9 Old 03-05-2012, 07:58 PM
afeinman
Senior Member
I've noticed that it will detect rain falling down, but not if I am driving through a mist. I am wondering if it is actually the tiny circle near the wiper blade pivot point, which would be shielded from mist.
afeinman is offline
  Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Rain-Sensing Wipers Swipe on a Clear Day Wingsy Charger Problems/Assistance 1 08-21-2011 03:28 PM
Knock Sensor Location? Ronaldo Charger Problems/Assistance 3 08-05-2008 12:09 PM
How bad do you want a rain sensor? PCCharger General Charger Discussion 12 06-06-2007 07:50 PM
Rain sensor Arl37 Interior Discussion/Modifications 4 12-21-2006 08:09 PM
anyone ever install a rain sensor? Hemi_charger General Charger Discussion 10 10-16-2006 01:59 PM
You may post new threads
You may post replies
