Car stalls for first 75 miles after fill-up. - Dodge Charger Forums
Charger SRT-8 Discussion This area is for discussion involving the SRT-8 version of the Dodge Charger.
post #1 of 10 Old 01-30-2012, 07:45 PM Thread Starter
SpringHillSrt8
Member
(Thread Starter)
For about the last two months, every time I fill up the car randomly stalls during the first 75ish miles of the fill-up. It will stall 2-4 times usually in those 75 miles. Once the first 75 of a fill-up is gone this is no longer an issue and the car runs great.
At first I was having trouble and I came on here to see other users having the same trouble if they were overfilling the car it would stall. I stopped overfilling the car but it still stalls in the same way. Usually it happens at a redlight but recently it has been happening sometimes under 5mph.
It seems weird to me that after the first 75 there is no longer an issue. I have tried using different gas stations and everything but can not find the problem. Is there any easy fix to this that anyone is aware of? I really do not want to take the car to the dealer without at least knowing what is causing it.
Also my gas gauge is no longer working properly it is stuck at about a half tank, just throwing that in there in case it will help anyone pinpoint any problems.
Thank you in advance
Silver Charger SRT8
Options I II and III
SpringHillSrt8 is offline
post #2 of 10 Old 01-31-2012, 02:44 PM
Grimlock
Senior Member
Grimlock's Avatar
My wild guess is that you overfilled the tank once. Is the car throwing any codes?
Grimlock
2003 Corvette Z06
2007 Charger SRT8 Gone, but not forgotten!
1969 Roadrunner in Red Gone, but not forgotten! <beep, beep>
Grimlock is offline
post #3 of 10 Old 02-01-2012, 05:49 PM
MCaesar
Senior Member
Faulty fuel pump?
2006 SRT8 228,000 miles+ (ordered with F1s and options)
COMING SOON!
2015 Dodge Charger SRT Hellcat
707 horsepower
650 pound feet of torque
MCaesar is offline
post #4 of 10 Old 02-01-2012, 09:51 PM
Ddaddy
Supporting Member (Lifetime)
Ddaddy's Avatar
Garage
Saturated Evap cansister. Replace it.
2006 Charger SRT-8
1969 Dart GTS 340
2012 Chrysler 300C Hemi
All V8 Mopars!
Ddaddy is offline
post #5 of 10 Old 02-01-2012, 09:54 PM
Grimlock
Senior Member
Grimlock's Avatar
Quote:
That was my theory....
Grimlock is offline
post #6 of 10 Old 03-26-2012, 12:03 PM Thread Starter
SpringHillSrt8
Member
(Thread Starter)
Hey guys, thanks for all of the input, the problem went away for a short period of time but now it's back with a vengeance. I'm going to take your guys advice and replace it. Does anyone know the best place to purchase the evap canister and the evap solenoid? Thanks in advance
post #7 of 10 Old 03-27-2012, 08:16 AM
1FST4DR
Senior Member
The dealer is all I know. I also know if that doesnt fix your issue you will need to replace the fuel tank.. Good luck
06 BLK charger SRT-8.
10.06@137mph
a few Mods...
Get AMP'D..
1FST4DR is offline
post #8 of 10 Old 08-04-2012, 08:56 AM
White Knight
Junior Member
Before you replace your tank you may want to try and clean the tank vent valve. This valve is not replaceable separately. If not operating properly it allows liquid fuel to flow to the evap canister and saturate the canister which allows liquid fuel to be vented to the manifold causing stalling to the point of the engine dying a low speeds. I had this problem, and recently replace my tank which solved the problem. I had the dealer return the tank to me after the repair. After cutting the valve from the tank and taking it apart it became clear that nothing was broken, only the valve appeared to be contaminated with a white powder. I suspect this was keeping the valve from sealing properly. I would suggest that before you spend $1000+ for a new tank you try and clean the valve. I suspect this could be done similar to the way fuel injectors are cleaned, by forcing carburetor cleaner or a similar solvent backwards thru the the vent valve in the tank. The vent hose is accessible in the engine compartment at the evap canister. The fuel tank needs to be no more than 1/2 full to ensure the valve is open. I would suggest not putting more than a pint or 2 per tank.
White Knight is offline
post #9 of 10 Old 08-04-2012, 01:33 PM
CHARGERTREV
Senior Member
CHARGERTREV's Avatar
^ he isn't replacing a tank, just the canister. OP when the pump clicks off stop overfilling it.
2007 Charger - SOLD
2012 Mustang - Race Car
1995 Honda Civic - Daily
1998 Jeep Wrangler - Toy
CHARGERTREV is offline
post #10 of 10 Old 08-06-2012, 09:04 PM
White Knight
Junior Member
The post before was recommending a tank replacement if the canister does not fix the stalling. If the vent valve in the tank is not working properly the new canister will not fix the problem. The canister is like a sponge that absorbs the fuel vapor until the solenoid opens and allows it to be burned by the engine. A saturated canister will dry out if the vent valve in the tank is working properly. That is why the car runs fine after a couple of gallons of fuel have been burned off. The fuel level is low enough that only vapor makes its way to the canister. Verification of the tank problem can be done by only filling the tank to 3/4 full. If the stalling does not occur, then it is most likely the vent valve causing the problem. Fill the tank full until pump clicks and see if problem re-occurs. Since the original poster's last post is so old I assume the issue has been resolved. My point in posting this info was to offer trouble shooting guidance and a potential solution that would save some folks some $$$.
  Dodge Charger Forums > Dodge Charger SRT-8 > Charger SRT-8 Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
After fill up car stalls a couple times 3996 Daytona Charger Problems/Assistance 11 12-12-2012 12:47 PM
Randomly stalls walshyfz86 Charger Problems/Assistance 1 01-03-2010 10:40 PM
Car almost stalls when given just a little gas. aliveguy5 Charger Problems/Assistance 21 08-04-2008 01:01 PM
Engine Almost Stalls sinistersix Performance Discussion/Modifications 7 02-27-2008 08:36 AM
Almost stalls at WOT from the start??? LTZROK Charger Problems/Assistance 6 09-27-2006 06:59 PM
You may post new threads
You may post replies
