Trouble codes U0126, B121A, B121C, U0100 .......WTF - Dodge Charger Forums
post #1 of 6 Old 11-19-2011, 12:31 PM Thread Starter
87vertgt
Senior Member
87vertgt's Avatar
(Thread Starter)
So the
wipers, turn signals, windows, wipers, power locks dont work.
THE TRACTION CONTROL AND BSS AND PASS AIRBAG LIGHT IS ON.
I recently replaced the EGR VALVE AND PLUGS AND REMOVED THE LOWER CONTROL ARM TO PRESS OUT THE BALLJOINT.
Any info is apprecated
06 3.5/Mods:
Premium Gas
Air Freshner
Jumper Cables
Fix A Flat
ok ok....k/n Panel, Borla muf-dual tips
87vertgt is offline
post #2 of 6 Old 11-19-2011, 02:59 PM
mnunes
Supporting Member (Lifetime)
mnunes's Avatar
U0126 - lost communication with steering angle sensor
Possible causes:
DTCs RELATED TO BATTERY VOLTAGE, IGNITION, OR VIN MESSAGES
CAN C BUS CIRCUITS OPEN OR SHORTED
STEERING ANGLE SENSOR POWER AND GROUND
ANTI-LOCK BRAKES MODULE
U0100-LOST COMMUNICATION WITH ECM/PCM
Possible causes:
CAN B OR CAN C BUS CIRCUITS OPEN OR SHORTED
DTCS RELATED TO BATTERY VOLTAGE, IGNITION, OR VIN MESSAGES
FCM NOT CONFIGURED CORRECTLY
ECM/PCM
ECM/PCM POWER AND GROUND
MODULE THAT SET THIS DTC
B121A - RIGHT HEATED SEAT HI INDICATOR CONTROL CIRCUIT HIGH
Possible causes: (P84) RIGHT HEATED SEAT HIGH INDICATOR DRIVER CIRCUIT SHORTED TO BATTERY
RIGHT HEATED SEAT SWITCH
CLUSTER
B121C ???
Sounds like both U0100 and U0126 could be due to the steering column module (SCM) being incorrectly connected or defective. If the SCM isn't connected or working, you'd lose anything on the "driver's" side of the SCM, such as the steering wheel controls, horn, cruise control, turn signals, air bag, high beams, and wipers. Sounds like it matches your symptoms. Have you done any work around the steering wheel/steering column recently? If you have a telescoping steering column, try unlocking it and pushing it back in towards the dashboard (retracted position) to see if this makes a difference.
If the steering angle sensor can't be read, the traction control system won't be properly operational since it needs to know which way the wheels are turned to be able to properly modulate the brakes.
Not sure on the B121 codes.
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #3 of 6 Old 11-19-2011, 04:51 PM Thread Starter
87vertgt
Senior Member
87vertgt's Avatar
(Thread Starter)
hey bud thanks for the response.
no I havent messed with the column. I do have a adjustable column I will tilt it and see what happens.
also that SCM part I cant find online or any forums that speak of how to replace it!!! weird...
87vertgt is offline
post #4 of 6 Old 11-19-2011, 08:37 PM
mnunes
mnunes's Avatar
I didn't mean tilt the column. Some can also telescope in and out. In some cars, when it's fully out (towards the driver) the connector doesn't make good contact.
This thread describes how to remove the SCM (along with showing the connector I'm referring to).
http://www.lxforums.com/board/f63/pa...p-step-128961/
mnunes is offline
post #5 of 6 Old 11-20-2011, 02:51 AM Thread Starter
87vertgt
Senior Member
87vertgt's Avatar
(Thread Starter)
oh ok yeah mine doesnt telescope
do you know who I can test my scm? i dont believe it's the issue as why would it prevent my windows or radio or hvac from working?
87vertgt is offline
post #6 of 6 Old 11-21-2011, 11:14 AM Thread Starter
87vertgt
Senior Member
87vertgt's Avatar
(Thread Starter)
update
battery is dead
87vertgt is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Diagnostic trouble codes Binns Charger Problems/Assistance 2 01-04-2011 09:46 PM
Trouble codes and rough driving resbum Charger Problems/Assistance 1 06-30-2010 01:38 PM
Predator and trouble codes PlumCrazyDaytona Performance Discussion/Modifications 10 10-22-2008 02:57 PM
06 Rt trouble codes HarleyT Charger Problems/Assistance 1 02-27-2008 07:22 AM
trouble codes!!!!!!!!!!!!! dvdhotboy Charger Problems/Assistance 2 05-14-2007 06:20 PM
You may post new threads
You may post replies
