Cylinder 1 misfire? - Dodge Charger Forums
General Charger Discussion General Discussion about the Dodge Charger.
post #1 of 10 Old 10-04-2011, 03:28 PM Thread Starter
R/Teen
Senior Member
(Thread Starter)
Cylinder 1 misfire?
my check engine light came on and i took it to meineke and they said it was cylinder 1 misfire..
That means what?
He said, either a spark plug or some type of coil? He gave me these crazy prices
Spark plug: $100
Coil: $100-$200??
I got my oil changed there two days ago, 10/2/2011 and this happens. Im dumb when it comes to engines, is that the legit prices? Im a college kid,$200 to me is a boner.
Thanks in advance guys.
--2007 Dodge Charger R/T--
Steel Blue Metallic Clearcoat
R/Teen is offline
post #2 of 10 Old 10-04-2011, 03:45 PM
Vito
Senior Member
Vito's Avatar
Send a message via AIM to Vito
Those arent Crazy prices lol, for a shop to do it, 100 is a little steep for that, try bringing it to a different shop, it will cost your around 1.75 cents if you can figure out how to do it your self. there are threads on here for you to look at on how to change out spark plugs
and yes he is talking about a coilpack im assuming, the price he gave you is legit it seems like, i dont know the exact price for one off hand, but that sounds reasonable
I really Hate Mustangs, Especially Cobras
True||Street||Cars
1000+ RWHP Twin Turbo SRT-8 In The Making
Vito is offline
post #3 of 10 Old 10-04-2011, 03:51 PM
Vito
Senior Member
Vito's Avatar
as simple as it gets
Vito is offline
post #4 of 10 Old 10-04-2011, 04:17 PM Thread Starter
R/Teen
Senior Member
(Thread Starter)
Thanks bro, i'll look into it.
R/Teen is offline
post #5 of 10 Old 10-04-2011, 04:28 PM
Jonny
Supporting Member (Lifetime)
Jonny's Avatar
The plugs get changed every 30k, and it's best to use the copper Champions, listed on the radiator support. The Hemi uses 16 plugs.
When did you last change the plugs? It may be as simple as changing them to resolve the misfire.
I am the Stig
2010 R/T DWBlue, 2800 PI stall, Homemade CAI, JBA headers and mids, SLP LMII catback, Custom tune by Diablotoona, 180 T-stat, 3.06 Getrag.
Jonny is offline
post #6 of 10 Old 10-04-2011, 07:04 PM Thread Starter
R/Teen
Senior Member
(Thread Starter)
I havent changed them since ive gotten it. I got a different charger, v6 now. Long story.
But! I got the car at 49k miles on it so im assuming then when they've done it, but who knows. Im assuming thats the case (hopefully). Ill do some work with it tomorrow and let you guys know.
Thanks you guys.
R/Teen is offline
post #7 of 10 Old 10-04-2011, 09:06 PM
rodneyiii
Senior Member
rodneyiii's Avatar
Different things besides the ignition can cause a cylinder misfire. How many miles are on the car now? The V6's don't require a plug change until 100K miles. You can start with doing some diagnostics to eliminate things without spending any money. First, clear the code from the PCM. Swap the plug from cyl 1 to another cyl and see if the misfire code moves to the other cyl. If not, swap the cyl 1 coil to another cyl and see what happens. If the code stays with cyl 1, something else is creating the misfire. If the code moves with the swapped component, that is the problem part.
Heavy carbon buildup on the piston, a clogged injector, a marginally working O2 sensor, a vacuum leak - any of these can cause a misfire.
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
rodneyiii is offline
post #8 of 10 Old 10-07-2011, 09:08 AM
lsale
Member
lsale's Avatar
So we're talking about a v-6 Charger here and what year? The check engine light coming on coincided with your oil change? If so, check your plug wires that none are obviously loose, could have been bumped by the tech, also check if any oil is puddled up on the coil or wire & boot, the tech could have spilled oil.....
2011 Charger RT Max.
2010 Challenger RT Classic, traded in.
1987 Monte Carlo SS, stolen & never recovered.
1972 Chevelle, sold.
1970 Camaro, totalled.
lsale is offline
post #9 of 10 Old 10-09-2011, 05:17 PM Thread Starter
R/Teen
Senior Member
(Thread Starter)
update!!
My babys fixed! We switched out the spark plugs and runs like a champ.
Thanks guys. That vid came in handy.
R/Teen is offline
post #10 of 10 Old 10-11-2011, 12:55 PM
Vito
Senior Member
Vito's Avatar
good to hear it man, how old are you btw, post some pics of your whip
Vito is offline
  Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Misfire! Cylinder 1 (3.5 V6) r450rr2004 Charger Problems/Assistance 36 04-05-2016 03:08 PM
Cylinder 1 Misfire, help! Mango Daytona Performance Discussion/Modifications 14 12-29-2010 04:30 PM
Cylinder 6 misfire????? White Thunder V6 Specific Discussion 2 08-19-2010 05:11 PM
throwing code cylinder misfire please help crazylikeacharger Charger Problems/Assistance 16 04-04-2009 01:42 PM
Cylinder Misfire (Houston) lilj Texas 3 09-18-2008 02:58 PM
You may post new threads
You may post replies
