Engine code P0430 - Dodge Charger Forums
post #1 of 13 Old 09-23-2011, 08:13 PM Thread Starter
IrishChargerRT
Senior Member
IrishChargerRT's Avatar
(Thread Starter)
Engine code P0430
Catalyst system below threshold P0430, That's the code my car threw today and I failed my smog Is it the O2 sensors or what, my registration is due tomorrow and I am so pissed off right now. Any Help would be great guys
2013 Dodge Charger SRT8. Mods... Airaid Cold Air Intake and Flowmaster Super 40`s Exhaust.
Smoke' em -v- (smo'k-em) 1.The act of placing large amounts of rubber into the pavement and or asphalt, usually by means of ground ripping torque. 2. A gross and gratuitus display of power, with the intent of intimidating imports.
IrishChargerRT is offline
post #2 of 13 Old 09-23-2011, 09:09 PM
bigjim.srt-8
Senior Member
bigjim.srt-8's Avatar
My Charger threw that code a couple years ago. My Cats fell apart and had to be replaced.
It was done under the Emisions warranty and covered 100%.
Pay your registration tomorrow so you aren't late and then take to dealer to have it fixed.
Good luck!
Jim,
07 TORRED SRT-8- Option Groups I, II, III... Demolded
Mopar Cold Air Intake and JBA Exhaust With 5" tips, Jet 180 T-stat, Diablo Predator Tuner, BT Catch Can
BT mods-Front and Rear Emblems,Front and Rear Sill Plates,Fender Badges,Underhood Kit
V-1 Radar Detector,R1 Drilled and Slotted Rotors, Powdercoated Alloys with Toyo Proxes ST's
bigjim.srt-8 is offline
post #3 of 13 Old 09-23-2011, 10:09 PM Thread Starter
IrishChargerRT
Senior Member
(Thread Starter)
Good luck!
I hope not man, the code will pop up and then it will go away so I have no idea what can be causing it? And I can't register my car until I pass smog, I wish I could just pay the registration and be done with it.
post #4 of 13 Old 09-23-2011, 10:31 PM
outbackred
Senior Member
outbackred's Avatar
Just take it in to the dealer and show them the code and like above post if it is your cats they have to replace for free if you have less than 100,000 miles or 6 or 8 years.
Most muffler shops just want your money for new cats and they won't tell you that you can get it done for free at the dealer. Had them replaced on my dodge ram with 75,000 miles on it for free.
2006 BB R/T, Boss 334's Demolded, Some Debadging, Homemade CAI, Magnaflow Exhaust, Smoke Sidemarkers,
Honeycomb Insert, PD grill,BT Pink Thingy, BT Catch Can, Danko front spoiler, Razors Edge subframe connectors, AirRide suspension
outbackred is offline
post #5 of 13 Old 09-23-2011, 10:39 PM
PlumCrazyDaytona
Supporting Member (Lifetime)
PlumCrazyDaytona's Avatar
Send a message via MSN to PlumCrazyDaytona Send a message via Yahoo to PlumCrazyDaytona
Not a big deal the code will clear out after three complete drive cycles with no errors. Also you should know there is a TSB for a software fix for cars that throw the code. I use to throw the 430 and 420 codes all the time before I built up motor, and with my tune with the o2's turned on I have not gotten the code. So check with your dealer it could just be a software thing, or drive it for a week and see if the code clears itself. Or if you cant wait go to autozone or any national parts store and get a code reader and clear the code.
6.1 Intake manifold,SRT MAX cam on 112lsa, CNC Inertia Heads milled,mopar TCM,blue tops, 3000 Edge converter 3.91 Getrag, Kooks LongTubes, catless mids and SLP Loud Mouth II, powerbond undrive pulley, 170 tstat, , R1 crossdrilled/slotted rotors, HAWK Pads,eibach lowering springs,dampners,sways mopar strut braces, razors edge sub frame connectors #157 of 1400 ACES IV Quantum Blue Lubricants PB 1/4 12.38@110.66
PlumCrazyDaytona is offline
post #6 of 13 Old 09-23-2011, 10:43 PM Thread Starter
IrishChargerRT
Senior Member
(Thread Starter)
Well it has 125K right now, but I will take it in and see.
post #7 of 13 Old 09-23-2011, 10:46 PM Thread Starter
IrishChargerRT
Senior Member
(Thread Starter)
Quote:
Well I cleared the code but it came back after 50 miles or so. How long does it take for the OBD to reset? Because I could probably clear it and drive like 40 miles and then take it for the smog and hopefully it is reset by that time.
post #8 of 13 Old 09-23-2011, 10:56 PM
PlumCrazyDaytona
Well its hard to say..if your main concern is the the test it takes roughly three drive cycles to arm and show ready. So maybe try some foulers or take it to the exhaust shop have them test the cats and if they are good swap out your rear o2's
post #9 of 13 Old 09-24-2011, 06:40 PM
status1
Senior Member
That warranty is for the original owner only or any charger with less than 100k ?
status1 is offline
post #10 of 13 Old 09-24-2011, 08:19 PM
outbackred
Senior Member
outbackred's Avatar
I happened to be the original owner of the truck but the exhaust shop did not know that when he brought that up. I took it to the dealer and was replaced for free. They probably looked to see if I was the original owner but they never said. A quick call to a dealer and they can tell you what the federal regulations are about cats.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
High Flow Cat Code P0430 crulejaypee Performance Discussion/Modifications 0 03-29-2010 11:08 AM
P0430 code? Sublimeon22s Charger Problems/Assistance 2 02-08-2010 01:58 PM
Code P0430 ATL SRT General Charger Discussion 4 05-10-2009 01:18 AM
Engine light on - Diablo says CODE P0430 CtrlAltDel Charger Problems/Assistance 4 03-19-2009 08:59 PM
P0430 CODE -- system Catalyst issue? Charger_Blitz Charger Problems/Assistance 1 05-20-2008 12:46 PM
You may post new threads
You may post replies
