My car Won't Slow Down! - Dodge Charger Forums
Performance Discussion/Modifications Discuss any performance modification in this section.
post #1 of 12 Old 06-13-2011, 11:17 AM Thread Starter
CONAN
Senior Member
(Thread Starter)
I just got my 07 superbee back on friday. I was having an arrington magna supercharger installed. My mechanic and a guy from dtpracing were working on the tune for 2 weeks.
Heres what I noticed. while driving, you hit the gas and the car goes 40mph, you then take your foot off the gas but the car continues going the same speed and will not slow down, unless you hit the break. So obviously something is up with the tune. cause it didn't do that before. not to this degree anyways. it did it slightly, i always had to keep my foot near the break while cruising through town. but now, its much more pronounced. luckily, i have an appt. with a dyno tuner to not only look at that, but the horse power is way to low, considering the mods that i have.
Just curious if anyone else ever had that problem with a car not deaccelerating.
CONAN is offline
post #2 of 12 Old 06-13-2011, 01:06 PM
wadisr
Senior Member
wadisr's Avatar
Garage
Not to skip the subject but, where did you get those headlight covers?
2016 Charger R/T Scat Pack, Technology group, confidence group, Beats, sunroof, Black leather/alcantara seats
2013 Dart Rallye (Wife's)
2013 Charger SRT8 Fully loaded Hell
Boy
red interior Gone but not forgotten
2011 Charger R/T plus, Hell
Boy
2006 Charger R/T Gone but not forgotten
wadisr is offline
post #3 of 12 Old 06-13-2011, 01:17 PM Thread Starter
CONAN
Senior Member
(Thread Starter)
that was probably the first mod i got for the car. back in 07. People have asked me before. I know i ordered them online. I have looked a few times to try and find them again. the only ones i ever see are the gto ones. I don't know if they make them or not anymore. they cost about 250. they are from what i remember, a bendable hard rubber. it had a peel back on the sides to stick.
CONAN is offline
post #4 of 12 Old 06-13-2011, 01:17 PM
Gunder Armour
Senior Member
Gunder Armour's Avatar
These cars always seem to hold their speed well when cruising. Don't know the technical explanation though. They just don't slow down quickly. Maybe someone can chime in about the tune causing the cruise control to activate or....
"Heroes Live Forever"
'13 Charger R/T AWD MAX
Previous '06 Charger R/T+ Owner
NOTICE: This post was just an opinion by the author. No offense should be taken. Thank you.
Gunder Armour is offline
post #5 of 12 Old 06-13-2011, 01:22 PM
Gladiator
Super Moderator
Gladiator's Avatar
I always thought our cars did that because of where they idled. My car will go 10mph or more on its own on a flat lot if I don't hold the brake.
Are you not entertained? Are you not entertained? Is this not why you are here?
Gladiator is offline
post #6 of 12 Old 06-13-2011, 01:24 PM
Gunder Armour
Senior Member
Quote:
Yeah, if you find a receipt or link, let us know! LIKE THOSE!
post #7 of 12 Old 06-13-2011, 09:28 PM
mnunes
Supporting Member (Lifetime)
mnunes's Avatar
I have heard of cars not decelerating when you let up and it always seems to come back to the tune. I'm pretty sure I've heard about it on cammed cars, not sure about supercharged ones - but it's always in the tune.
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #8 of 12 Old 06-14-2011, 06:34 PM
Grimlock
Senior Member
Grimlock's Avatar
Yeah I have definitely heard of this before as well, but I don't remember the specifics. I would post this on the LX Forums as well if you haven't already.
Grimlock
2003 Corvette Z06
2007 Charger SRT8 Gone, but not forgotten!
1969 Roadrunner in Red Gone, but not forgotten! <beep, beep>
Grimlock is offline
post #9 of 12 Old 06-14-2011, 07:14 PM
PlumCrazyDaytona
PlumCrazyDaytona's Avatar
Send a message via MSN to PlumCrazyDaytona Send a message via Yahoo to PlumCrazyDaytona
Yes its the tune and has to do with the Electonic Throttle Control, ETC. Right now your ETC is a little loose meaning the return to idle position is slow and therefore the holding speed. Now depending on the cam and other things these cars can be real moody and not like the cam you are running and "HAL" will fight it, like in my case. I have an odd ball surge that comes and it goes....to eliminate it we gave the car less ETC which gives you this effect or can if its too loose, too tight and you get the surges....
As an example with ETC set up tight throttle is super crisp, when you rev the engine its tight and comes down fast. Now when I had it set this tight it was a bear to drive, as an example using cruise at any speed you would feel the throttle adjust up and down to maintain the speed. dialed down a bit and smooth as a factory tune.
However this is a tricky thing to get nailed down...Mine is not perfect and most days is just fine, but out of the blue I will either get the surges or slow slowdowns, like the 40mph cruise with no throttle input.
I have accepted it as a trade off to a big cam, hell it runs great in -20 temps and awesome at 90 so to me a slight trade off.
6.1 Intake manifold,SRT MAX cam on 112lsa, CNC Inertia Heads milled,mopar TCM,blue tops, 3000 Edge converter 3.91 Getrag, Kooks LongTubes, catless mids and SLP Loud Mouth II, powerbond undrive pulley, 170 tstat, , R1 crossdrilled/slotted rotors, HAWK Pads,eibach lowering springs,dampners,sways mopar strut braces, razors edge sub frame connectors #157 of 1400 ACES IV Quantum Blue Lubricants PB 1/4 12.38@110.66
PlumCrazyDaytona is offline
post #10 of 12 Old 06-14-2011, 07:25 PM
Gabe
Senior Member
Gabe's Avatar
We call it Auto-Drive ... lol
Mine does it too, since the cam install.
Supercharged cars are also susceptible to it , unfortunately.
It's in the tune ... mine will be revised once the blower goes on, so we'll see how much AJ can get rid of it ...
Mine: '13 Mustang GT, Sterling Gray, 6-spd man, Recaros, Track Pk, 2.3L Whipple, 608 RWHP, 517 RWTQ
Fiancee's: '08 Mustang GT500, White/blue stripes, '13 TVS & injectors, FRPP twin-65mm TB, JLT 123mm CAI, 656 RWHP, 661 RWTQ
Previous: '07 Charger R/T AWD, heads/cam, a few other things. 355 AWHP, 370 AWTQ
Gabe is offline
  Dodge Charger Forums > Dodge Charger Discussion > Performance Discussion/Modifications
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Car wont slow down/ Idol Issues TalonDSM88 Performance Discussion/Modifications 29 07-24-2010 08:37 AM
I didn't drive car for 5 days while sick & now it seems slow... Phanta5m General Charger Discussion 18 04-28-2008 07:36 PM
Car got slow again and lost its pep!!!!! Sublimeon22s Performance Discussion/Modifications 61 04-19-2008 05:06 PM
All of a sudden my car got slow? Nyczbubba V6 Specific Discussion 12 06-23-2007 07:32 PM
is our car actually slow? chargerboy04 General Charger Discussion 151 03-24-2006 07:47 PM
You may post new threads
You may post replies
