Radiator Flush gone bad, HELP! - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
  #1
Old 05-23-2011, 06:41 AM
2sday2 2sday2 is offline
Junior Member
Angry Radiator Flush gone bad, HELP!
My routine coolant flush has gone wrong somehow! I'm getting ready to take a roadtrip so was checking all my fluids. Found what looked to be a red muddy mess in the coolant tank so decided to flush the system. I've got the 5.7 with about 75k so figured it's about time anyway. Did a drain/fill/drain/fill multiple time until the radiator ran clean, then added a flushing/cleaning agent from the local parts store topped off with water then ran the motor for the first time. Got up to temp, drained more red fluid/ drained and filled multiple times and finally got her cleaned up. I filled it with PEAK antifreeze that advertises that it is good for ANY make model or year. Started her up when finished and it looked good. Ran to grab a bite to eat and it was running hot but I only let it get to 255, just barely to the red on the needle. Stopped let her cool then headed back to the house, only a couple of miles. Got up to the 250 mark again, parked and it was boiling like crazy. Let her cool down and now she won't even start! I'm getting scared by the posts about valve seats falling out but that might be my problem. Anybody have any ideas? I was supposed to be leaving on vacation Thursday but that may have just gone up in smoke! Any advise will be greatly appreciated. Chris
__________________
'06 R/T Performance Group Package
Air Raid Cold Air Filter
Metallic Silver - added factory front fascia
  #2
Old 05-23-2011, 07:23 AM
06charger2010's Avatar
06charger2010 06charger2010 is offline
Senior Member
Quote:
Maby your thermostat is stuck closed. Could you feel coolant running on both sides of it?
After it cooled off to cold did you check level in radiator to see if full? Maby there was alot of air still in there.
Also Turn your heat on full to get all the air out of there also.
__________________
Top Banana #3820
Magnaflow Cat Back, Charger Rear Bumper Diffuser, Custom Tails, 5% Tint, painted Engine Cover, Lots of Wax
  #3
Old 05-23-2011, 07:55 AM
Junior Member
I can check thermostat, but my worry is that it won't start now and I don't want to do any major engine damage if the valve seats have fallen. I don't want to call a Stealership but might be running out of options. Anybody in the North Dallas TX area care to take a look at her for me? This has got me sick!
__________________
  #4
Old 05-23-2011, 03:18 PM
Junior Member
Thumbs down The bad has gotten worse!
Update to Coolant Flush gone bad. Had my baby towed to my friends shop, Solutions Automotive in McKinney TX and my worst nightmare has come true. No compression in 2 cylinders low in 4 others. This must have been the valve guide problem I've just learned about, but I want to puke! In my mind this is an obvious manufactures defect. Any motor, especially with the trademark Hemi should be able to take a little extra temp without melting down on itself! Does anybody know where to find a longblock? Any chance Dodge will at least partially stand behind their product here or am I bent over?
__________________
  #5
Old 05-23-2011, 04:26 PM
Grimlock's Avatar
Grimlock Grimlock is offline
Senior Member
At least one guy on these forums was able to get Chrysler to pay 50% when they had a similar issue.
__________________
Grimlock
2003 Corvette Z06
2007 Charger SRT8 Gone, but not forgotten!
1969 Roadrunner in Red Gone, but not forgotten! <beep, beep>
  #6
Old 05-23-2011, 04:44 PM
Jonny's Avatar
Jonny Jonny is online now
Senior Member
Lifetime Supporting Member
My Charger: 2010 Charger R/T
...just when I was considering giving up my 180 t-stat for the sake of fuel economy.
Good luck, friend! I hope you can get it fixed.
__________________
I am the Stig
2010 R/T DWBlue, 2800 PI stall, Homemade CAI, JBA headers and mids, Flowmaster catback, Custom tune by Diablotoona, 180 T-stat, 3.06 rear gears.
  #7
Old 05-23-2011, 05:06 PM
06supercharger's Avatar
06supercharger 06supercharger is offline
Senior Member
that's phuked dude. sorry as hell. don't count on dodge helpin ya out on an 06.
__________________
06 RT - Pred 93 CAI tune, K&N Drop In, Flowmaster Super 44's, SE coilovers, reso delete, drilled and slotted Baer rotors, Baer ceramic pads ,blacked out EVERYTHING .
KEEP CALM AND CHIVE ON ....
  #8
Old 05-23-2011, 05:33 PM
Senior Member
Sorry man That suks
keep us up to date
__________________
Top Banana #3820
  #9
Old 05-23-2011, 05:52 PM
rsoto80's Avatar
rsoto80 rsoto80 is offline
Senior Member
Did you check and see if there is any coolant mixed in with the oil? Could be just warped heads.
__________________
13.84@101 mph Gainesville Raceway
  #10
Old 05-26-2011, 10:33 AM
ChargerS.X.T's Avatar
ChargerS.X.T ChargerS.X.T is online now
Senior Member
Any updates?
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Radiator Hose Blew Off! How do I drain the Radiator? CPTcharger Charger Problems/Assistance 1 09-24-2010 06:31 PM
Coolant Flush help WidowmakerSRT8 Charger SRT-8 Discussion 3 04-12-2010 04:48 PM
Anyone ever have this happen? upper radiator hose came off of the radiator nofear18 Charger Problems/Assistance 5 11-04-2009 05:37 AM
coolant flush ? EVIL R/T General Charger Discussion 6 09-20-2009 11:46 AM
Tranny flush - How much? Kenny Pollock Performance Discussion/Modifications 48 07-12-2009 01:25 PM
© AutoGuide
