How To remove and install Upper Control Arms - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 24 Old 03-10-2011, 10:59 PM Thread Starter
dellagratti
Senior Member
dellagratti's Avatar
(Thread Starter)
I couldnt find a thread so that inspired me to create one, I hope this helps out! It actually was a simple project to do.
TOOLS needed:
21mm,18mm,15mm,13mm wrenches; 10mm, 13mm, 18mm sockets, ratchet and extensions; a mallet, vise grips, PB blast and pickle fork.
After raising car and placing on jack stand and removing tire, use the 18mm and 21mm to remove the bolt holding the strut to lower control arm. The nut is 18mm and bolt is 21mm.
Next you will need the 18mm wrench to remove the nut from the upper control arm. I had to use the mallet to break the nut free (just be careful not to hit car).
Then i used the pickle fork to pry the 2 apart which will cause this and since I was replacing them i couldnt care less.
Then use the 13mm to remove the three nuts holding top strut in place and the remove whole strut to provide more space to work in.
Next locate the the bolt heads on inside of the engine bay. They are 18mm.
This one is under all the cables leading to computer.
For optimum space you may want to remove the strut brace.
After removing the bolts the old upper control arm will be ready to remove and the new one installed!
After all this just reinstall everything and insure all your bolts and nut are tight! I didnt have torque specs so I used my own PFT (Pretty F'n Tight)!
"The same prudence which in private life would forbid our paying our own money for unexplained projects, forbids it in the dispensation of the public moneys." - Thomas Jefferson
Still Stock.... For Now.
dellagratti is offline
The Following User Says Thank You to dellagratti For This Useful Post:
electrondevil (07-23-2015)
post #2 of 24 Old 03-10-2011, 11:11 PM
mnunes
Supporting Member (Lifetime)
mnunes's Avatar
Nice write-up. Did you replace the upper control arm due to front-end clunk? Did it help?
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #3 of 24 Old 03-10-2011, 11:34 PM Thread Starter
dellagratti
Senior Member
(Thread Starter)
Quote:
the clunk and that the boots were torn n no grease existed in boots which i discovered last weekend while installing the coilovers, i still need to do the rear end links cuz they are dry rotted bad. i havent driven it yet i made this, dinner, watced tv and spoke to the mom. i will drive in a lil while and give an update to the noise factor.
post #4 of 24 Old 03-11-2011, 01:22 AM Thread Starter
dellagratti
Senior Member
(Thread Starter)
so after a test drive the clunk noise from pass side is gone! what i saw after examing the oem boot to moog boot i noticed the oem one doesnt have anything on the bottom to prevent grease loss (if it does its long since gone) but the moog does.
post #5 of 24 Old 05-23-2011, 04:18 AM
GLHS837
Super Moderator
GLHS837's Avatar
I will add you can do this without removing then strut. Less access, but not too bad.
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
GLHS837 is offline
post #6 of 24 Old 05-23-2011, 05:40 AM
Manicmechanic
Senior Member
Manicmechanic's Avatar
Garage
Torque Specs are:
55 ft. lbs for the body mounting bolts.
35 ft. lbs. + 90* (Deg.) for the nut on the ball joint.
A-Arms are not interchangeable between RWD and AWD cars.
2006 Torred Daytona # 1988 Tunable 2-3/4 Exhaust,Remote 996XT GPS Scanner, SRT Wheels/Legmaker modded, BC Racing Coilovers, Demon Eyes Front/Rear, Silverstars, V-1 Hardwired, SRT Brakes, RK Sport Hood. PaddleShifters, '09 MYGIG, LUKAS Ace Blackbox, I still open the car door for my Wife, so she doesn't scratch the paint with her nails!
Manicmechanic is offline
post #7 of 24 Old 05-23-2011, 06:05 AM
sector 2
Senior Member
sector 2's Avatar
Great write up, bro. Just had mine changed out...both ball joints were fried. I went w/ SPC adjustable arms. Had I known all this, woulda done it myself and saved 200 bones!! Anyways, SPC set up is nice as the alignment is done from the ball joint itself...and unlike the stock set up, the ball joint is serviceable. My Pedders set up really screwed up my alignment, now all is well......hey MNUNES....put this on your everything thread.
2013 Charger R/T
Gone and missed...2007 RT
"We sleep soundly in our beds because rough men stand ready in the night to visit violence on those who would do us harm."--George Orwell
sector 2 is offline
post #8 of 24 Old 05-23-2011, 06:18 AM
GLHS837
Super Moderator
GLHS837's Avatar
Its already there
GLHS837 is offline
post #9 of 24 Old 05-24-2011, 04:08 AM
sector 2
Senior Member
sector 2's Avatar
......duh....hello McFly!!
sector 2 is offline
post #10 of 24 Old 05-24-2011, 12:26 PM
D's 08 RT
Senior Member
D's 08 RT's Avatar
Smile
Nice write up . There's another way to release the spindle w/o damaging the boot if your just doing a spring /coilover swap. In the third picture you can see a round flat spot on the spindle,loosen the nut holding the ball joint,but don't completely remove it, then get a large ballpein hammer and hit the flat spot sharply several times and the ball joint stud will release from the spindle,D.
'08,R/T, R&T, Mopar CAI,strut brace & rear air diffuser,Diablo 91oct CAI tune,BT catch can,waterneck,fuse box,strut & underhood covers,Jet 180* t-stat,RE hood/trunk strut covers,Painted ABS cover,radiator shroud,tank & firewall,Stainless braided lines,3Gs engine cover inset,22" staggered Lexani lx-15wheels,UAS,Accuair,Progress sways, Koni shocks,BWoody end links,SPC UCAs front, JHS Adj. rear camberlinks,BFX HID 6000k Hi/Lo beams &3000k fogs,flashtech halos,Tinted windows,Tinted tails,Sequential tail lights,VDI doors, Red led interior & trunk lights,Billet pedals,Hurst billet shifter,R/T logo trunk liner,Flowmaster super 40s,Blastin' bobs resos,4" stainless DW tips .
D's 08 RT is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
SPC upper control arms charger, magnum shyane Parts For Sale/Wanted 1 07-14-2010 09:40 PM
FOR SALE: New in box SPC adjustable upper control arms carchitect Parts For Sale/Wanted 1 06-16-2010 09:01 PM
Painting Rusty Upper Control Arms Cuda340 Detailing/Washing/Waxing 4 05-12-2010 11:45 PM
Pedders upper and lower control arms R/T shyane Parts For Sale/Wanted 1 07-22-2009 07:21 AM
F/S brand new in box Front end camber kit/adjustable upper control arms SJCHARGER Parts For Sale/Wanted 16 05-11-2009 06:36 PM
You may post new threads
You may post replies
