Diagnostic trouble codes - Dodge Charger Forums
post #1 of 3 Old 01-04-2011, 08:44 PM Thread Starter
Binns
Senior Member
Binns's Avatar
(Thread Starter)
here you go
P0016-crankshaft/camshaft Timing Misalignment 2.7l
P0016-crankshaft/camshaft Timing Misalignment 3.5l
P0016-crankshaft/camshaft Timing Misalignment 5.7l
P0031-o2 Sensor 1/1 Heater Circuit Low
P0032-o2 Sensor 1/1 Heater Circuit High
P0037-o2 Sensor 1/2 Heater Circuit Low
P0038-o2 Sensor 1/2 Heater Circuit High
P0051-o2 Sensor 2/1 Heater Circuit Low
P0052-o2 Sensor 2/1 Heater Circuit High
P0057-o2 Sensor 2/2 Heater Circuit Low
P0058-o2 Sensor 2/2 Heater Circuit High
P0071-ambient Air Temperature Sensor Performance
P0072-ambient Air Temperature Sensor Circuit Low
P0073-ambient Air Temperature Sensor Circuit High
P0107-manifold Absolute Pressure Sensor Circuit Low
P0108-manifold Absolute Pressure Sensor Circuit High
P0111-intake Air Temperature Sensor Performance
P0112-intake Air Temperature Sensor Circuit Low
P0113-intake Air Temperature Sensor Circuit High
P0116-engine Coolant Temperature Sensor Circuit Performance
P0117-engine Coolant Temperature Sensor Circuit Low
P0118-engine Coolant Temperature Sensor Circuit High
P0121-throttle Position Sensor 1 Performance
P0122-throttle Position Sensor 1 Circuit Low
P0123-throttle Position Sensor 1 Circuit High
P0125-insufficient Coolant Temperature For Closed-loop Fuel Control
P0128-thermostat Rationality
P0129-barometric Pressure Out-of-range Low
P0131-o2 Sensor 1/1 Circuit Low
P0132-o2 Sensor 1/1 Circuit High
P0133-o2 Sensor 1/1 Slow Response
P0135-o2 Sensor 1/1 Heater Performance
P0137-o2 Sensor 1/2 Circuit Low
P0138-o2 Sensor 1/2 Circuit High
P0139-o2 Sensor 1/2 Slow Response
P013a-o2 Sensor 1/2 Slow Response - Rich To Lean
P013c-o2 Sensor 2/2 Slow Response - Rich To Lean
P0141-o2 Sensor 1/2 Heater Performance
P0151-o2 Sensor 2/1 Circuit Low
P0152-o2 Sensor 2/1 Circuit High
P0153-o2 Sensor 2/1 Slow Response
P0155-o2 Sensor 2/1 Heater Performance
P0157-o2 Sensor 2/2 Circuit Low
P0158-o2 Sensor 2/2 Circuit High
P0159-o2 Sensor 2/2 Slow Response
P0161-o2 Sensor 2/2 Heater Performance
P0171-fuel System 1/1 Lean
P0172-fuel System 1/1 Rich
P0174-fuel System 2/1 Lean
P0175-fuel System 2/1 Rich
P0196-engine Oil Temperature Sensor Performance
P0197-engine Oil Temperature Sensor Circuit Low
P0198-engine Oil Temperature Sensor Circuit High
P0201-fuel Injector 1 Circuit
P0202-fuel Injector 2 Circuit
P0203-fuel Injector 3 Circuit
P0204-fuel Injector 4 Circuit
P0205-fuel Injector 5 Circuit
P0206-fuel Injector 6 Circuit
P0207-fuel Injector 7 Circuit
P0208-fuel Injector 8 Circuit
P0221-throttle Position Sensor 2 Performance
P0222-throttle Position Sensor 2 Circuit Low
P0223-throttle Position Sensor 2 Circuit High
P0298-engine Oil Temperature Too High
P0300- Multiple Cylinder Misfire
P0301-cylinder 1 Misfire
P0302-cylinder 2 Misfire
P0303-cylinder 3 Misfire
P0304-cylinder 4 Misfire
P0305-cylinder 5 Misfire
P0306-cylinder 6 Misfire
P0307-cylinder 7 Misfire
P0308-cylinder 8 Misfire
P0315-no Crank Sensor Learned
P0325-knock Sensor 1 Circuit
P0330-knock Sensor 2 Circuit
P0335-crankshaft Position Sensor Circuit
P0339-crankshaft Position Sensor Intermittent
P0340-camshaft Position Sensor Circuit 2.7
P0340-camshaft Position Sensor Circuit 3.5
P0340-camshaft Position Sensor Circuit 5.7
P0344-camshaft Position Sensor Intermittent 2.7
P0344-camshaft Position Sensor Intermittent 3.5
P0344-camshaft Position Sensor Intermittent 5.7
P0401-egr System Performance
P0403-egr Solenoid Circuit
P0404-egr Position Sensor Performance
P0405-egr Position Sensor Circuit Low
P0406-egr Position Sensor Circuit High
P0420-catalyst Efficiency (bank 1)
P0430-catalyst Efficiency (bank 2)
Binns is offline
post #2 of 3 Old 01-04-2011, 08:45 PM Thread Starter
Binns
Senior Member
Binns's Avatar
(Thread Starter)
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0443-EVAP PURGE SOLENOID CIRCUIT
P0452-EVAP PRESSURE SWITCH STUCK CLOSED
P0455-EVAP PURGE SYSTEM LARGE LEAK
P0456-EVAP PURGE SYSTEM SMALL LEAK
P0457-EVAP SYSTEM - LOOSE FUEL CAP
P0461-FUEL LEVEL SENSOR 1 PERFORMANCE
P0462-FUEL LEVEL SENSOR 1 CIRCUIT LOW
P0463-FUEL LEVEL SENSOR 1 CIRCUIT HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT
P050B-COLD START IGNITION TIMING PERFORMANCE (ETC)
P0501-VEHICLE SPEED SENSOR 1 (NON-ABS)
P0503-VEHICLE SPEED SENSOR 1 ERRATIC (NON-ABS)
P0501-VEHICLE SPEED SENSOR 1 (EQUIPPED W/ABS)
P0503-VEHICLE SPEED SENSOR 1 ERRATIC (Equipped ABS)
P0506-IDLE SPEED PERFORMANCE LOWER THAN EXPECTED
P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXPECTED
P050D-COLD START ROUGH IDLE
P0513-INVALID SKIM KEY
P0520-ENGINE OIL PRESSURE SENSOR CIRCUIT
P0521-ENGINE OIL PRESSURE SENSOR PERFORMANCE
P0522-ENGINE OIL PRESSURE SENSOR 1 CIRCUIT LOW
P0523-ENGINE OIL PRESSURE SENSOR 1 CIRCUIT HIGH
P0524-ENGINE OIL PRESSURE TOO LOW
P0532-A/C PRESSURE SENSOR CIRCUIT LOW
P0533-A/C PRESSURE SENSOR CIRCUIT HIGH
P0551-POWER STEERING PRESSURE SWITCH PERFORMANCE
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0571-BRAKE SWITCH 1 PERFORMANCE
P0572-BRAKE SWITCH 1 STUCK ON
P0573-BRAKE SWITCH 1STUCK OFF
P0579-SPEED CONTROL SWITCH 1 PERFORMANCE
P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW
P0581-SPEED CONTROL SWITCH 1 CIRCUIT HIGH
P0585-SPEED CONTROL SWITCH 1/2 CORRELATION
P0591-SPEED CONTROL SWITCH 2 PERFORMANCE
P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW
P0593-SPEED CONTROL SWITCH 2 CIRCUIT HIGH
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0606-INTERNAL ECM PROCESSOR
P060B-ETC A/D GROUND PERFORMANCE
P060D-ETC LEVEL 2 APP PERFORMANCE
P060E-ETC LEVEL 2 TPS PERFORMANCE
P060F-ETC LEVEL 2 ECT PERFORMANCE
P061A-ETC LEVEL 2 TORQUE PERFORMANCE
P061C-ETC LEVEL 2 RPM PERFORMANCE
P0622-GENERATOR FIELD CONTROL CIRCUIT
P0627-FUEL PUMP RELAY CIRCUIT
P062C-ETC LEVEL 2 MPH PERFORMANCE
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM KEY NOT PROGRAMMED IN PCM
P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW
P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH
P0645-A/C CLUTCH RELAY CIRCUIT
P0652-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
P0653-SENSOR REFERENCE VOLTAGE 2 CIRCUIT HIGH
P0660-MANIFOLD TUNING VALVE (MTV) CONTROL CIRCUIT
P0685-AUTO SHUTDOWN RELAY CONTROL CIRCUIT
P0688-AUTO SHUTDOWN RELAY SENSE CIRCUIT LOW
P0700-TRANSMISSION CONTROL SYSTEM (MIL REQUEST)
P0703-BRAKE SWITCH 2 PERFORMANCE
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1004-SHORT RUNNER VALVE CONTROL PERFORMANCE
P1005-MANIFOLD TUNING VALVE CONTROL PERFORMANCE
P1115-GENERAL TEMPERATURE RATIONALITY
P1128-CLOSED LOOP FUELING NOT ACHIEVED - BANK 1
P1129-CLOSED LOOP FUELING NOT ACHIEVED - BANK 2
P1239-ENGINE OIL TEMPERATURE TOO LOW
P1404-EGR POSITION SENSOR RATIONALITY CLOSED
P1411-CYLINDER 1 REACTIVATION CONTROL PERFORMANCE
P1414-CYLINDER 4 REACTIVATION CONTROL PERFORMANCE
P1416-CYLINDER 6 REACTIVATION CONTROL PERFORMANCE
P1417-CYLINDER 7 REACTIVATION CONTROL PERFORMANCE
P1501-VEHICLE SPEED SENSOR 1/2 CORRELATION - DRIVE WHEELS (NON-ABS)
P1502-VEHICLE SPEED SENSOR 1/2 CORRELATION - NON DRIVE WHEELS (NON-ABS)
P1501-VEHICLE SPEED SENSOR 1/2 CORRELATION - DRIVE WHEELS (EQUIPPED W/ABS)
P1502-VEHICLE SPEED SENSOR 1/2 CORRELATION - NON DRIVE WHEELS (Equipped ABS)
P150D-COLD START ROUGH IDLE - OPEN THROTTLE START
P1521-INCORRECT ENGINE OIL TYPE
P1572-BRAKE SWITCH STUCK ON
P1573-BRAKE SWITCH 1STUCK OFF
P1593-SPEED CONTROL SWITCH 1/2 STUCK
P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION FAILURE
P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1618-SENSOR REFERENCE VOLTAGE 1 CIRCUIT ERRATIC
P1628-SENSOR REFERENCE VOLTAGE 2 CIRCUIT ERRATIC
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P1897-PCM PROCESSOR
Binns is offline
post #3 of 3 Old 01-04-2011, 08:46 PM Thread Starter
Binns
Senior Member
Binns's Avatar
(Thread Starter)
P1897-PCM PROCESSOR
P2008-SHORT RUNNER VALVE (SRV) CONTROL CIRCUIT
P2016-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT LOW
P2017-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT HIGH
P2066-FUEL LEVEL SENSOR 2 PERFORMANCE
P2067-FUEL LEVEL SENSOR 2 CIRCUIT LOW
P2068-FUEL LEVEL SENSOR 2 CIRCUIT HIGH
P2072-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE
P2077-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT LOW
P2078-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT HIGH
P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
P2097-DOWNSTREAM FUEL TRIM SYSTEM 1 RICH
P2098-DOWNSTREAM FUEL TRIM SYSTEM 2 LEAN
P2099-DOWNSTREAM FUEL TRIM SYSTEM 2 RICH
P2100-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT
P2101-ELECTRONIC THROTTLE CONTROL MOTOR PERFORMANCE
P2107-ELECTRONIC THROTTLE CONTROL MODULE PROCESSOR
P2108-ELECTRONIC THROTTLE CONTROL MODULE PERFORMANCE
P2110-ELECTRONIC THROTTLE CONTROL - FORCED LIMITED RPM
P2111-ELECTRONIC THROTTLE CONTROL - UNABLE TO CLOSE
P2112-ELECTRONIC THROTTLE CONTROL - UNABLE TO OPEN
P2115-ACCELERATOR PEDAL POSITION SENSOR 1 MINIMUM STOP PERFORMANCE
P2116-ACCELERATOR PEDAL POSITION SENSOR 2 MINIMUM STOP PERFORMANCE
P2118-ELECTRONIC THROTTLE CONTROL MOTOR CURRENT PERFORMANCE
P2122-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT LOW
P2123-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT HIGH
P2127-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT LOW
P2128-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT HIGH
P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION
P2138-ACCELERATOR PEDAL POSITION SENSOR 1/2 CORRELATION
P2161-VEHICLE SPEED SENSOR 2 ERRATIC (Equipped ABS)
P2166-ACCELERATOR PEDAL POSITION SENSOR 1 MAXIMUM STOP PERFORMANCE
P2167-ACCELERATOR PEDAL POSITION SENSOR 2 MAXIMUM STOP PERFORMANCE
P2172-HIGH AIRFLOW / VACUUM LEAK DETECTED (INSTANTANEOUS ACCUMULATION)
P2173-HIGH AIRFLOW / VACUUM LEAK DETECTED (SLOW ACCUMULATION)
P2174-LOW AIRFLOW / RESTRICTION DETECTED (INSTANTANEOUS ACCUMULATION)
P2175-LOW AIRFLOW / RESTRICTION DETECTED (SLOW ACCUMULATION)
P2181-COOLING SYSTEM PERFORMANCE
P2271-O2 SENSOR 1/2 SIGNAL BIASED
P2273-O2 SENSOR 2/2 SIGNAL BIASED
P2299-BRAKE PEDAL POSITION / ACCELERATOR PEDAL POSITION INCOMPATIBLE
P2302-IGNITION COIL 1 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2302-IGNITION COIL 1 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2305-IGNITION COIL 2 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2305-IGNITION COIL 2 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2308-IGNITION COIL 3 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2308-IGNITION COIL 3 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2311-IGNITION COIL 4 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2311-IGNITION COIL 4 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2314-IGNITION COIL 5 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2314-IGNITION COIL 5 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2317-IGNITION COIL 6 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2317-IGNITION COIL 6 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2320-IGNITION COIL 7 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2323-IGNITION COIL 8 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2503-CHARGING SYSTEM OUTPUT LOW
P2610-PCM INTERNAL SHUTDOWN TIMER FAST RATIONALITY
P3400-MDS RATIONALITY BANK 1
P3401-MDS SOLENOID 1 CIRCUIT
P3402-CYLINDER 1 DEACTIVATION CONTROL PERFORMANCE
P3425-MDS SOLENOID 4 CIRCUIT
P3426-CYLINDER 4 DEACTIVATION CONTROL PERFORMANCE
P3441-MDS SOLENOID 6 CIRCUIT
P3442-CYLINDER 6 DEACTIVATION CONTROL PERFORMANCE
P3449-MDS SOLENOID 7 CIRCUIT
P3450-CYLINDER 7 DEACTIVATION CONTROL PERFORMANCE
P3497-MDS RATIONALITY BANK 2
U0001-CAN C BUS
U0101-LOST COMMUNICATION WITH TCM
U0103-LOST COMMUNICATION WITH ELECTRIC GEAR SHIFT MODULE
U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE
U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE
U0155-LOST COMMUNICATION WITH CLUSTER/CCN
U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (SKREEM/WCW)
U110A-LOST COMMUNICATION WITH SCCM - CAN - C
U110C-LOST FUEL LEVEL MESSAGE
U110E-LOST AMBIENT TEMPERATURE MESSAGE
U110F-LOST FUEL VOLUME MESSAGE
U1110-LOST VEHICLE SPEED MESSAGE
U1113-LOST A/C PRESSURE MESSAGE
U1120-LOST WHEEL DISTANCE MESSAGE
U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL RECEIVED
U1411-IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED
U1412-IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED
Binns is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
How-TO: Pull diagnostic codes and get EVIC data and engine hours GLHS837 Charger Problems/Assistance 54 09-27-2014 03:07 PM
Warning Lights and Diagnostic Codes Question KSMIKE Charger Problems/Assistance 35 02-03-2009 10:05 PM
Why do I only get 4 digits on my display when I check diagnostic codes? jmckenzie Charger Problems/Assistance 3 04-07-2008 09:06 AM
My Diagnostic Codes Wakito Charger Problems/Assistance 1 06-13-2007 03:56 AM
trouble codes!!!!!!!!!!!!! dvdhotboy Charger Problems/Assistance 2 05-14-2007 05:20 PM
You may post new threads
You may post replies
