Help installing HID fog lights - Dodge Charger Forums
Exterior Discussion/Modifications Discussion of exterior modifications belongs in this section, even if the visual modification slightly affects performance (ie. spoilers, etc)
post #1 of 16 Old 12-22-2010, 10:20 AM Thread Starter
Damcharger
Senior Member
Damcharger's Avatar
(Thread Starter)
So I thought there was a thread (with pictures) on how to get to the fog lights but I can't seem to find it.
If someone could point me in the right direction that would be great.
I have the option of using a car lift so I am not sure if it is easier to go through the wheel well or through the bottom of the car because the lift won't help if I have to go through the wheel well.
Thanks in advance for any help
Whatever man we just gotta roll with it...
Damcharger is offline
post #2 of 16 Old 12-22-2010, 10:22 AM
DjMere
Senior Member
DjMere's Avatar
Garage
http://www.chargerforums.com/forums/...1&postcount=11
2009 HEMI ORANGE SRT Super Bee
Basics: Fully Loaded, Nav, Rear DVD System w/ Headphones, Sunroof, Etc Predator 91CAI Tune / QB Fluids / ACES IV
DjMere is offline
post #3 of 16 Old 12-22-2010, 11:06 AM Thread Starter
Damcharger
Senior Member
Damcharger's Avatar
(Thread Starter)
thanks for the quick response, hopefully I can get this done tonight.
post #4 of 16 Old 12-22-2010, 04:07 PM Thread Starter
Damcharger
Senior Member
Damcharger's Avatar
(Thread Starter)
I am trying to take out the lock pins in the wheel well and they are not coming out, any advice on how to do it before I break one...
post #5 of 16 Old 12-22-2010, 04:17 PM
DjMere
Senior Member
DjMere's Avatar
Garage
depending on the year
i have a 2006, i used the flat end of a screw driver
my uncle has a 2008, they have hex screws
DjMere is offline
post #6 of 16 Old 12-22-2010, 04:20 PM Thread Starter
Damcharger
Senior Member
Damcharger's Avatar
(Thread Starter)
I have an 08, the 3 on the side look like there is a threaded rod through it but I don't understand how to grab ahold of it to unscrew it
post #7 of 16 Old 12-22-2010, 06:10 PM
hjriveraRT
Senior Member
hjriveraRT's Avatar
Garage
Quote:
Pal, I have an '08 too, try to remove at least four screws from the pan below the fogs, then pull off the two or three clips in back of the pan and front of the tire (not the ones in the fender lip). In that way I can reach the fogs from below without removing the plastic lock pins. The ballasts can be installed from above, if you have a thin arm and a lot of patience like me. Try it and let us know... Its not easy, but in that way I don't have to buy new plastic lock pins.
2008 Bright Silver R/T Road & Track Edition, full equipped
MODS: 40% tint all, LED Interior lights, BT Oil Catch Can, K&N drop-in air filter, Projectors with Halos and HIDs (5000K lows and 6000K fogs), driver's door handle w/o key cylinder, reverse HIDs w/remote, hood struts.
QuantumBlue
custom blended oil and ACES IV
hjriveraRT is offline
post #8 of 16 Old 12-22-2010, 08:12 PM
Charger RT 2010
Senior Member
Charger RT 2010's Avatar
When I did my fogs, I removed 3 of the center pin plastic rivets, not the solid ones in the upper lip of the fender well, Then I removed the forward skid shield. It had about 10 hex head screws and dropped the entire front cover. This gave me complete access under the lower nose area and easy access to the fog lights.
I then used double sided 3M tape and mounted the ballasts to the lower frame section (like a little shelf) of the metal fender brace.
I was able to do all of this without jacking up the car or removing the wheels. Ive done this both on my car and a friends 06 Daytona.
2010 RT R&T Brilliant Black Crystal Pearl, All options except Factory HIDs
Born Date June 10, 2010
5% Tint back, sides and winshield visor, 15% front sides.
DDM Tuning 8000k HID Lows and Fogs
Partial debadged tail (Dodge lettering),Demolded
Red painted calipers, Black Painted Rotors, MOPAR Hood Prop Struts
Blinker Mod, OEM SRT Hood, Custom Front Emblem, Tinted Side Marker Lights
Charger RT 2010 is offline
post #9 of 16 Old 12-23-2010, 12:57 PM Thread Starter
Damcharger
Senior Member
Damcharger's Avatar
(Thread Starter)
thanks for the help guys. I was able to get the 3 push pins and one of the bottom ones out to then use my flashlight to hold the wheel well away from the front fender. This allowed me to get my hand in there and plug everything in, zip tie the wires and mount the 2 boxes on the 2 frame railes that run the lenght of the front end.
I was only able to do the driver side though because it got dark and I was doing this in the Michigan winter....tonight I tackle the passenger side!
post #10 of 16 Old 02-07-2011, 02:52 PM
NeckCuttA
Member
Does anyone know what size bulb / hid kit replaces the fogs on the 2010 chargers? It's not the same as previous years. My 9145 kit did not fit at all.
Black 2010 Charger R/T. Mopar CAI, Flowmaster Force II cat back, 15% Tint. Kicker system.
NeckCuttA is offline
  Dodge Charger Forums > Dodge Charger Discussion > Exterior Discussion/Modifications
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Installing fog lights? DALLASCHARGER Exterior Discussion/Modifications 3 01-22-2009 06:00 PM
HID Fog Lights MIAboi1221 General Charger Discussion 3 08-20-2008 12:13 PM
installing fog lights houldv V6 Specific Discussion 17 12-29-2007 06:49 PM
Just got done installing my new mopar fog lights! JMies419 Exterior Discussion/Modifications 6 08-06-2007 02:43 PM
Installing Dodge Charger Fog Lights jesuslazaro General Charger Discussion 4 01-15-2007 01:50 AM
You may post new threads
You may post replies
